Page 11 of 22 FirstFirst ... 78910111213141521 ... LastLast
Results 1,001 to 1,100 of 2162
  1. #1001
    Wow never thought of that the numbers related to V8 engines. big blocks motor..... it must be 05 then... I never run rock shox on my bike b4, this is the 1st time. Thanks for the tip mate.
  2. #1002
    Reputation: bringdoom's Avatar
    Quote Originally Posted by D8lover
    Same with the argyles, 302 (ford 5.0) 318 (chrysler smallblock) or 409 (ford bigblock, chevy had a short lived 409 also but the fords was more well known.)
    06 mongoose ritual for sale, pm me for details.
    Quote Originally Posted by JBsoxB
    this is fucking stupid
  3. #1003
    I'm currently building a street machine with a 350 ZZ4 small block chevy.... it's a pick up so I can carry my bikes hehehehe... if you want to take a peek of the project here's the link http://myholden.com/gall2/v/holdenutes/1983/ sorry a bit OOT
  4. #1004
    Quote Originally Posted by zephyr11
    new frame (08) or the old one?
    '05 Frame.
    Mark
  5. #1005
    Street Soldier.
    Reputation: ETBA's Avatar
    Oct 2007
    This is my friend Justin's Riot.
    It's super dialed, thought you guys might wanna see it.
  6. #1006
    Thats class my friend...Love it props...
  7. #1007
    Reputation: buckoW's Avatar
    Feb 2007
    anyone ever have problems with Profile hub pawls slipping? Solutions?
  8. #1008
    mtbr remember
    Reputation: BikeSATORI's Avatar
    Quote Originally Posted by buckoW
    Haven't had any problems with my profile slipping, but just looking at the driver, I can see how if you packed it with too much grease that may effect pawl spring return... or it could be just weak springs or worn pawls... Simple design, those are the only probs I could think of that reasonably could occur.
    ETBA, for how many blkmrkts there are out there today that one is spec'ed out very nicely, I like it.
    Schralp it Heavy.
  9. #1009
    Calm Like a Bomb
    Reputation: pipes10's Avatar
    Quote Originally Posted by DAvo
    Nicolai 2MXTB baby! booyah!
    that's a sweet ride!!!
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
    https://www.instagram.com/jayparrington/
  10. #1010
    @wishEMT
    Reputation: gwillywish's Avatar
    Quote Originally Posted by ETBA
    that bike looks better than some women
  11. #1011
    @wishEMT
    update
    swapped out the fork, a 60mm DJ4
  12. #1012
    Calm Like a Bomb
    here's the updated pics of my '08 devinci district 2...i added some stroker rydes and deity bars/stem
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
  13. #1013
    very sweet bike there!
    what tires are those?? are they suitable for dirt jumping? thanks!
  14. #1014
    Feb 2007
    [QUOTE=BikeSATORI]Haven't had any problems with my profile slipping, but just looking at the driver, I can see how if you packed it with too much grease that may effect pawl spring return... or it could be just weak springs or worn pawls... Simple design, those are the only probs I could think of that reasonably could occur.
    Not an issue with the grease being too thick. It is almost like the pawls wore down the teeth on the inside of the shell. It has happened to 3 profile different hubs. One 6 speed and 2 nine speed. I might have had a grease that was too thin? I tried everything I could after it started but then it was too late. They didn't have an easy life. Another one broke inside at the aluminum axle where the axle studs thread into. I still like Profile though. I might try and make one out of all the parts.
  15. #1015
    mtbr remember
    Quote Originally Posted by BikeSATORI
    That is rough man.
    I've never run any of the multi-speed Profile stuff so I'm not sure if the internals are much different. If they weren't modified or beefed up any over the SS stuff, the extra width on the cassette body might be tweaking the teeth/engagement in hub body.... but that's a lame excuse.
    I would think Profile might help you out on this, but being over the atlantic there, might be hard to get much done with them in florida.
    Also, I've heard a lot about avoiding their 3pc axle designs... weakspot in the design. You could go full chromoly internals, even the 3pc chromo might be stronger. But, not sure of availability for 135mm spaced hubs. I know you could probably get their 3/8" outer chromo axle studs to fit a 10mm mtb dropout with little modification. Which part of the axle did you break?
    Good luck with that.
    Schralp it Heavy.
  16. #1016
    Street Soldier.
    Oct 2007
    Yeah, he always has the most dialed bikes, I'm going to East Texas to ride with him next week. I'm gonna be putting all my new stuff on my bike then too, so I'll try to get some more updated pics for you guys.
  17. #1017
    Feb 2007
    That is rough man.
    Hey Bike Satori
    I ripped the hub almost in half. I drifted into a berm and then slingshotted out the other side and the tire started rubbing on the frame. I thought it was the rim or spoke tension but the hub split in 2 and the cassette fell off with the body and half of the alu axle and the axle stud still inside. The aluminum axle broke at the end of the threads for the axle studs or between the cassette and hub shell if you will. This hub didn't have any slippage yet and I want to salvage the body because the teeth are still good but the axle is so mangled inside there that, that project is on hold for a very rainy day. I have moved on and have been having other problems with other hubs but I still haven't given up hope on the Profile hubs. The fronts are still running strong though. I would try and get parts from profile but I don't want to pay to find other problems. It is more how, how much and where I ride that is the problem not theirs. The DT Swiss hubs with their ratchet ring is working ok for now. If you want to see pics I have to upload them so just ask othwise I don't like to post broken stuff. Thinking about the single speed stuff....you might be right about the length of the cassette body on the multi geared hubs flexing the aluminum axle leading to shell tooth wear. They worked well for a long time so I am not disappointed.
    Sorry for the derail. Back to the topic at hand.
  18. #1018
    Grand Poobah
    Reputation: minus9's Avatar
    Update on stem, bars, pedals, and some other stuff
  19. #1019
    "Carpe Diem"
    Reputation: teoz's Avatar
    Oct 2007
    I don't really like jackal frame because of that "hump" it has but this looks really niiiccceee!!! well done!
    "RIDE FOR LIFE"
    "Don't judge a man by his opinions, but what his opinions have made of him." - G. C. Lichtenberg
  20. #1020
    Street Soldier.
    Oct 2007
    Those dropouts look pretty crazy too.
  21. #1021
    Reputation: A Grove's Avatar
    Nov 2006
    Quote Originally Posted by minus9
    Jackals have never been my thing.. But if you lost the front brake, got a "taco" style bash, and a pivital seat/post, that thing would be so dialed. It looks like she rides well on the DJ's... Street may be another story. Nice ride.
  22. #1022
    Rb
    Rb is offline
    Feb 2007
    27 lbs
    Notable changes from before:
    1. I re-laced/built the Halo SAS up front with alloy nips and DT Supercomps to save a little weight. (I know, I have too much time/patience.)
    2. plastic pedals (probably the best 12 bucks I've spent on my bike in recent memory)
    3. Panaracer 2.1 UST XCPro in the rear
    4. XT 4-piston rear with 140mm rotor
    I can shave even more weight in the future with a different front wheel (the rebuilt SAS front still weighs 2 lbs and change), tubeless front, and a new fork (somebody buy my 4x). But none of that will probably happen because a) I don't care enough and b) money is tight.
    But all in all, this thing hauls ass.
  23. #1023
    Reputation: paintballeerXC's Avatar
    Jun 2005
    RB whats the front tire and does wrenchscience actuly have a store??? might want to come by some day
  24. #1024
    Rb
    Rb is offline
    Feb 2007
    Quote Originally Posted by paintballeerXC
    It's a smallblock 8.
    Yes, we do have a store.
    1022 Murray St.
    Berkeley, CA 94703
    Drop by sometime and I'll give you da tour. Because of the way our business works (EVERY bike is a custom one-of), we keep a constantly-rotating stock and there isn't always necessarily *cool* stuff to look at. (don't expect a bunch of 303s hangin' on the wall...) But if you drop by when the riding season starts to ramp up, I can promise you'll never see so much X.0, XTR, Dura-Ace, and Red under one roof again.
  25. #1025
    Jun 2005
    haahah ya ill stop by sometime you doing that underground race in B town tomrrow night?
  26. #1026
    Rb
    Rb is offline
    Feb 2007
    No. I called it off. (check the rideSFO forums if you have an account there...)
    Somebody narc'ed to the pigs.
  27. #1027
    mtbr remember
    Quote Originally Posted by Rb
    27 lbs
    yeah, looks fast man. Original build, that's for sure. I kinda like the tractor tire out back, just for roost points, haha, not my thing though.
    I see you are moto too...
    Never seen the twisty pc's on a 4X style bike either... most racer heads are out there droppin' benji's on the high dollar plats. Loved the old XT m755 brakes too... one of the only mineral fluid brakes that I actually wish I didn't sell off.
    by the way, your shop has got the mojo! most I've ever seen in one room together, haha.
    Schralp it Heavy.
  28. #1028
    Jun 2005
    damnnnnnnnn will inform my fools we should ride some time man
  29. #1029
    Rb
    Rb is offline
    Feb 2007
    Thought somebody would say something about my seemingly 'off' rear tire choice... I needed something cheap, tubeless, and narrow, with bite for the dirt around here.
    Ody plastic pedals are the real deal. I can't see myself buying an expensive pair of boutique pedals when these work just as well, if not better, paired with just about ANY shoe.
    We sold nearly 100 Mojo's last year. Seems everybody wants to get their hands on one -- including myself. Should've seen the 13 Mojo SL's we had here last week....
  30. #1030
    Mar 2006
    Versus Jab
    <a href="http://s253.photobucket.com/albums/hh77/dionbeauchamp/?action=view&current=IMG_1641.jpg" target="_blank"><img src="http://i253.photobucket.com/albums/hh77/dionbeauchamp/IMG_1641.jpg" border="0" alt="Photobucket"></a>
  31. #1031
    Nov 2006
    Quote Originally Posted by kash$
    That yoke looks.... mehh. And the BB looks incredibly lowwww. Just my opinionn.
  32. #1032
    mtbr remember
    Quote Originally Posted by A Grove
    haha, I thought that chainstay yoke was the best part on the whole frame! I just like that style... reminds me of my molly just a hair. But this one here looks like a big wrap-around, almost like you have to deflate the tire just to put it on if you run a fatty out back...
    But yeah, bb does look low, that's what I was questioning in the other thread on this bike...
    Schralp it Heavy.
  33. #1033
    Street Soldier.
    Oct 2007
    upgraded Xenia
    I posted a seperate thread with more pics, but thought I would post a couple pics in here as well. I can't say enough good about the Argyles, so smooth.
  34. #1034
    My Mob and a lowered Pike 70mm travel
  35. #1035
  36. #1036
    Jun 2005
    ^^^ dope colors. i like alot
  37. #1037
    What are you looking at?
    Reputation: R1D3R's Avatar
    Jun 2005
    That's a great looking bike... Love the matching frame and fork colours...
    Orange Heckler
    Blue Pinscher
  38. #1038
    Calm Like a Bomb
    that's a nice bike!!!
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
  39. #1039
    mtbr remember
    Quote Originally Posted by hellbilly
    what is the foundry bike co sticker? why on the mob?
    The simple color looks pretty cool, clean, but you should have shaved the forks disc tabs before you painted. Rat-can it?
    Looks like a lightweight build, like the twisty pc's.
    Schralp it Heavy.
  40. #1040
    Living Ghetto Fabulous!
    Reputation: Uncle Cliffy's Avatar
    First gen. Mob? It doesn't have the disk brace between chainstay and seatstay...
    Quote Originally Posted by kidwoo
    The internet sounds like a tough place to ride.
  41. #1041
    Foundry Bike Co is my bike shop in Euless TX. Why on the Mob i love this bike its the best feeling frame ive ridden. i thought about shaving the disc tabs and yes it is spray paint. There is no TI on it and it weights 29.5lb
  42. #1042
    That bike is sweet. What kind of paint did you use? It looks pretty cool.
  43. #1043
    Nov 2007
    27 lbs
    can we have more pics of that sweet lookin bike in the front in white pls...
    looks wicked!
  44. #1044
    My Identiti P-45 "Omen"
    Bigger pics and more info here: www.arfreeriders.com
    The Build:
    * Frame: Identiti P-45
    * Forks: Rock Shox Pike 454
    * Headset: FSA Pig Unsealed
    * Rims: Rhyno Lite 24”
    * Rear Hub: KHE Reverse Freecoaster 36 hole, 14mm axle, 9 tooth
    * Front Hub: Marzocchi 20mm 32 hole
    * Tires: Kenda K-Rad 24”
    * BB: Profile 19mm
    * Cranks: Deity Vendetta
    * Sprocket: Odyssey MDS
    * Chain: KHE Collapse w/halflink
    * Pedals: Atomlab Aircorp
    * Seat Clamp: Identiti
    * Seat Post: Identiti
    * Seat: Deity
    * Stem: Deity
    * Bars: Deity
    * Bar Ends: Deity
    * Grips: ODI Longneck
    * Levers: Avid Speed Dial 7
    * Rear Brake: Avid Single Digit 7
    * Front Brake: Avid BB7 08
    * Peg: Odyssey JPG Light with Gland MkIII hub guard
  45. #1045
    Locs on Spokez
    Reputation: Iggz's Avatar
    Nov 2006
    Brad @ Nempro - Why would you lower the old 66's? That fork is like 8 pounds, its heavier than your frame >.>
    XSL_WiLL, STP frames can't clear 203mm rotors.
    Ground Steeze. @iggy_strbac
  46. #1046
    Meh.
    Reputation: XSL_WiLL's Avatar
    Wow... that question was asked like 2 years ago when I was thinking about buying one. And it actually does clear a 203mm rotor.
  47. #1047
    mtbr remember
    Quote Originally Posted by ilikemybike011
    Not exactly sure what you are replying too here..... but,
    ...Brad slammed 66's before you were probably even pondering riding a big bike in the park. He was pretty ahead of his time on what he was doing back then. I'm pretty sure he must have realized how overkill that fork was, even at that time of bomb-proof trends, but it gets attention, no doubt about it... it spread some word.
    People wanted more and more and more travel at that time, putting dual-crown forks on hardtails while he was busy slamming forks for shorter A-C lengths and steeper head-angles, more bmx like, where most other huckers were aiming at choppers. And look where we are now. slamming your Fox XC fork to keep the weight down and make it handle more like a bmx...
    Schralp it Heavy.
  48. #1048
    Rb
    Rb is offline
    Feb 2007
    looks wicked!
    it's an Ellsworth Ride.....
  49. #1049
    Calm Like a Bomb
    this will be my dj/4x/ss bike....this is her all built up in the shop...it should be shipped to me by next week sometime (hopefully)
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
  50. #1050
    mtbr remember
    Quote Originally Posted by pipes10
    did you buy it as a complete?
    ...they completely assembled your bike before shipping?
    Schralp it Heavy.
  51. #1051
    Calm Like a Bomb
    yes i bought it as a complete...transition gives u many options and i chose their freeride single ring kit, rp23, and pike 454 air u-turn....transition sent all the parts and the shop had to assemble it....they could have just sent me everything and i could have assembled it myself but they decided they would assemble it and ship it like all complete bikes are sent (handlebars off, front wheel off, front caliper off, pedals off, etc...) so i will just have a quick 5 min setup and i'm good to go
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
  52. #1052
    Reputation: brian242's Avatar
    there it be
  53. #1053
    Reputation: spzero's Avatar
    Pics from today
    just messing in the park flatlanding
    2008 Spesh P.1, Hope mono M4's
    Kona CoilAir
    Marin ??
    Prev
    MountainCycle SanAndreas
    Orange MsIsle
    Orange o2
  54. #1054
    Reputation: V-Dub's Avatar
    SuperCo Charger. Just a frame so far. All the parts are on the way.
  55. #1055
    Rb
    Rb is offline
    Feb 2007
  56. #1056
    Higher Exploration
    Reputation: EggsnBacon's Avatar
    This is my new urban/ss/dj bike, This setup weighs 34.59 lbs. (150mm spacing) With some further light weight modifications, (SLR saddle, Ti spring, wellgo pedals, mono mini pro brakes, xtr cranks) She could easily get down to 31-&-change
  57. #1057
    Locs on Spokez
    Nov 2006
    Quote Originally Posted by EggsnBacon
    Thank god you're getting lighter cranks. I was scrolling down and I saw the top of your bike then the middle and was like shitttttttttttttt thats ****ing nice.... and then I saw the cranks. Buzzkill. Amazing build though, specially when you get the new parts
  58. #1058
    Higher Exploration
    Haha, thanks. I built it up for DH riding first, and it originally weighed in at 40lbs So all this new stuff will be the light side of the spectrum, for AM, urban, and DJ type riding. I already ordered the spring and the pedals, the next upgrade will be the cranks for sure.
  59. #1059
    mtbr remember
    I don't know why those cranks would be a "buzzkill", they are a staple item in this area of biking, unlike this bike as a whole, haha.
    The only buzzkill I would find is the fact that it has a few too many gears to make it an "ss", haha... maybe you mistyped?
    edit: I'm an idiot... been in this forum too long. Didn't realize you meant SS = slopestyle, I was thinking SingleSpeed, my bad. In that case, you're right on point with that one, no doubt about it.
    ...a bit too much squish for "urban" riding too IMO. ...urban, man I dislike that word, almost as useful here as it is in referring to "urban" music.
    Intense bike though, that's for sure.
    Schralp it Heavy.
  60. #1060
    Ahahaha
    Oct 2007
    wow dude, thats intense.
    haha
  61. #1061
    Higher Exploration
    ...a bit too much squish for "urban" riding too. ...urban, man I dislike that word, almost as useful here as it is in referring to "urban" music.
    You know the name of the bike is SS (as in slopestyle) right? My bad, I must've forgotten this isn't the Intense forum, where SS refers to the slopestyle, instead of single speed
    "Urban" does suck as a term, but its the only way to be broad enough to cover all the types of riding people do in an urban setting. I prefer the ability to do more free-riding whilst riding on an "URBAN ASSAULT!!!!" (inside joke I guess), where as a lot of you guys posting here seem to enjoy the bmx style more. Its all personal preference, and how you use the (lame-ish) word 'urban'.
  62. #1062
    mtbr remember
    I'll be honest, I haven't paid much attention to the Intense offerings since the days of the mighty M1. They have always been out of my pocketbooks reach, and a bit too "racerboy" for me anyway. Always great products I'm sure though.
    And while it sho' ain't no SS SuperSport with a Bigblock LS6, it does look fun as hell.
    respect.
    Schralp it Heavy.
  63. #1063
    Meh.
    Mmmm... LS6. My new whip was supposed to be a LS1 powered TransAm. Same basic block architecture as the LS6, was going to do long tube headers and LS6 intake manifold... Then I decided to run it by my insurance agent... Well... it's now out of the question. I might have to get an import... Can't find a clean s14 240sx... might have to settle for a Teggy or a Lude... I would love another Celica All-Trac... but they're not easy to find. And I'm not a fan of the Subaru... some of the stuff isn't thought out too well... I guess I could get an LT powered Camaro or TA... Insurance is about what I'm paying on the daily driver right now... But I prefer the newer styling.
    The LS is small block design though... The Camaro SS is the only SS that got an LS motor. Well... the 06+ Monte Carlo and Impala SS got the LS4... but it's still a transvserse FWD.
    The Impala SS had an LT1 motor. And the LT is still a small block.
    Both motors are brilliant, I love them.
  64. #1064
    mtbr remember
    you're thinking too recent my friend.
    69/70 Chevelle SS had option for the legendary LS6 454. My father had one as a crate engine, re-built it in his bath-tub and put it in his 69' vette (after blowing the stock 427) and ran mid 10's on street tires, and this was in the early 70's mind you. Would torque the whole frame over and lift the front off the ground, he called it the leapin' frog since it was dark green.
    I also had a '96 Impala SS, all black with blue ghost flames... fun car, but it was a boat, actually glad I got rid of that when I did.
    My brother had one of the last TransAm WS6's ever built.... sold it off for some cash for another investment... he now has a pristine '01 Z06. I think he regrets selling the TA though.
    Schralp it Heavy.
  65. #1065
    Higher Exploration
    Yeah definitely should've held on the WS6, especially since it was one of last ones. Much less 'racerboy' than a vette too... jk
  66. #1066
    mtbr remember
    haha, agreed... but then again, this Z06 is from the first model year of it's new return. this is the only reason it still remains stock, no exhaust or cam, etc...
    I've still got some unused brand new full leather seats from that WS6 sitting in my barn too. My bro worked for Lear, so he had extra seating for just about every vehicle we've ever owned just because it was free... gonna hit ebay soon... got some for an 02 z71 sierra too if anybody's interested.
    ...neither car is really my style, but hey, I don't complain about the vette being "racerboy", even if I did agree, it's currently parked in my garage and I can take it out any time I want! only problem is, it doesn't do well in snow here. haha, but seriously, everytime I drive the vette, I just get all these ridiculous nasty looks from people, looks of either hatred for burning extra fossil fuels, or looks of pure jealousy (not to mention cop magnet)... but either way, it just makes me feel like an as$hole even if I'm not driving like one... I don't dig it. Low-key sleeper is more my style.
    Schralp it Heavy.
  67. #1067
    Meh.
    Ha... yeah... I am thinking a little too recent. You're right.
    I loved those Impala SS. My buddy's ran 13 seconds with all of his audio gear loading down the back.
    I'm not a big fan of the C5 Corvette. The C6 is a different story though...
  68. #1068
    Feb 2007
    standard practice. Assemble it, test it so everything works, disconnect the bars, pedals, seatpost and front wheel and ship.
  69. #1069
  70. #1070
    Grand Poobah
    Street machine
  71. #1071
    Locs on Spokez
    Nov 2006
    Street machine
    That looks like a trials bike that got fooled into thinking its a street machine
  72. #1072
    Grand Poobah
    Well shhhhhhhhhh....
    Don't tell it!
    It works fine the way it is
  73. #1073
    Nov 2006
    Thats 'cuz thats what it is my friend....
  74. #1074
    Rollin' twenties.
    I vomited the moment I saw those tires.
  75. #1075
    Reputation: floorguy724's Avatar
    Lenosky STP!!
    Finally finished up my build! Comes in at a hefty 25.6lbs. This will also be my dedicated SS, so don't mind the front brake and the Candy's they will come off when DJing.
  76. #1076
    mtbr remember
    Quote Originally Posted by floorguy724
    A "hefty" 25.6, haha!
    Last I time I weighed my Molly she was around that with a rigid front fork and no front brake.
    Schralp it Heavy.
  77. #1077
    Meh.
    He is running XC wheels, tires, clipless pedals, and a Pike 454.
  78. #1078
    Ya your right Will, I have SB8's but very muddy around here right now so the MotoRaptors will due. The pedals will come off on the days when I go DJing. Can you imagine the weight if I were to put my Float 100rl and Crossmax's on this thing. Please don't flame me on the Mavics, it's the only QR wheels I have sitting around.
  79. #1079
    Locs on Spokez
    Nov 2006
    That totally beat mine, but Ill put it up anyway ahah
    Also, what ratio are you running on yours?
  80. #1080
    Rb
    Rb is offline
    Feb 2007
    Whoa....25 lb XC'ed out STPs...?
    I might have to put my hardtail on a further diet...
  81. #1081
    Yeah I know it's light, but this is also my SS for xc/am. I am running a 23/13 ratio because I am going to be riding on the trails around here (Fort Ord) and I wanted a micro drive and this was the closest that i could find to a 32/18 which I normally run. I should'nt be posting this in this forum but.......I know I could drop another pound or two without sacrificing durability.
  82. #1082
    Grand Poobah
    Now this one is the pure trials bike...
  83. #1083
    Here's my bike!
  84. #1084
    Reputation: GravityWins's Avatar
    Dec 2005
    My P bike and I at the greatest place on earth
  85. #1085
    @wishEMT
    Cleveland rocks!!!!
  86. #1086
    Locs on Spokez
    Nov 2006
    Yeah you will as long as theres no carbon, ur good
  87. #1087
    @wishEMT
    I was actually wondering about carbon for fro applications [cruiser, dh, 4x]
  88. #1088
    Thrower
    Reputation: karmapolice's Avatar
    recent pic, haven't ridden much if at all lately due to cold weather and rain and school. I want to get a stationary trainer just got no money for one.
  89. #1089
    Meh.
    Booo on the zero tolerance sign! Slightly ironic that you're riding a BlkMrkt and there's a zero tolerance sign in the background.
  90. #1090
    Nov 2006
    I believe it says "school safety zone." Redundant in many ways.. best is that my guess is he was shredding the school
  91. #1091
    my jackal in the cozey confines of the gondola at mammoth. haven't gotten around to extracting the front brake. lazy? yes.
  92. #1092
    Locs on Spokez
    Nov 2006
    Quote Originally Posted by mild beast
    That at Mammoth ?
    - wow my bad, didn't read the caption
  93. #1093
    Thrower
    yeah thats why I took it there
  94. #1094
    Killer of Chains
    Quote Originally Posted by karmapolice
    Most raddest picture yet.
    So simply sick.
  95. #1095
    Nov 2007
    lovin it...
    was it yours that was with a dart before?
  96. #1096
    Thrower
    yeah I put the dart on it to mock it up while I was waiting for the dj1 to come from ups
  97. #1097
    May 2005
    that is my baby
    that beauty is for sale, dhmtb7@yahoo.com
  98. #1098
    My p1:
    Just switched from rigid to a Sherman Jumper.
  99. #1099
    Nov 2006
    holy slack angle there bud....
  100. #1100
    Reputation: gkenshin's Avatar
