Results 1 to 6 of 6
    May 2014
    Running a 10 speed chainring SS
    im trying to get a smaller chainring for my dj, never replaced a chainring before. if i buy a 10 speed chainring(raceface turbine), will it work as a single speed chainring? i know its best to run narrow wide, but will a 10 speed still work?
    thanks all
    That should work fine, regardless whether it has pins or not. So long as your chainline is ok, and everything is tensioned ok, you shouldn't be dropping any chains.
    Like you already said yourself, obviously for a single speed, you'd be better off with a single narrow/wide ring from raceface, but both will work.
    Reputation: cmc4130's Avatar
    Are you running a singlespeed chain or a chain for gears?
    May 2014
    I'm running a kmc 1/8 single speed chain
    That chain will do the job fine then.
    If you're buying new anyway, why not just get the N/W?
    Sinister Bikes
    Wraith Bicycles
    Sunday River Mtn Bike Park
    NEMBA
    Wachusett Brewing Co.
  1. 8 speed freewheel with 9 speed chainring
    By BigDriveLittleWedge in forum Singlespeed
    Last Post: 03-17-2014, 08:05 PM
  2. Replies: 28
    Last Post: 11-17-2013, 07:16 AM
  3. Anyone running Renthal SR4 chainring? Questions
    By csermonet in forum Downhill - Freeride
    Last Post: 11-06-2013, 05:23 AM
  4. SLX FC-M660 9 speed and 10 speed chainring interchangeability
    By Avua in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-20-2013, 01:28 PM
  5. Anyone else running a 28 tooth middle chainring ?
    By phoenixbikes in forum 27.5 - 650b
    Last Post: 09-24-2012, 01:02 PM
