    Reputation: Tag1's Avatar
    Mar 2006
    Rigid fork for 24" with v-mounts
    I'm going to build a 24" bike soon, and was thinking to go with an 80mm fork, but now I'm leaning towards rigid - problem is, I can't find a rigid fork for 24" wheels w/ V-mounts...any ideas?
    Mar 2006
    Closest I've found so far is this DMR Trailblade:
    http://www.dmrbikes.com/?Section=pro...itemid=FRKTB29
    However, I was hoping for 14 or 20mm axle - is 9mm bolt on strong enough for park/street use? Also, anyone happen to know the axle to crown measurement on this fork?
    You are going to have a hard time finding a suspension corrected fork with v-brake mounts for 24" wheels. Your best bet is to buy whatever fork you like and add/move the v-brake mounts.
    HB - The God Damn Flying Dutchman
    Chicago Freeride
    Elgin, IL
    train gorilla
    Reputation: ---->SWERVE76<----'s Avatar
    Jun 2005
    The 20mm trailblade 2 has a 440 a2c height. Not sure about the others. And bolt on 9mm axle would be fine for park and street.
    The officer saw the words, "This Bike Is a Pipe Bomb" and became concerned.
