Results 1 to 9 of 9
    quick release to bolt on... how easy?
    hey i was just wondering how easy would it be to change from quick release to bolt on? could i just go to a hard wear store to buy a new threaded axel?
    and comments would help
    thanks
    Mar 2005
    bu yourself some cone wrenches and remove the QR axle and install your bolt on. BTW, the last bolt on axle I installed broke after two sessions (I have never broken a QR axle)
    Meh.
    Reputation: XSL_WiLL's Avatar
    If you have a sealed cartridge bearing hub, it's not as easy as just the cone wrenches. You'll have to press the bearings in and out.
    Just go to your LBS and buy the right axle. It's not worth it to half ass it and risk getting the wrong diameter and thread.
    Local Paperboy Hero
    Reputation: Cru Jones's Avatar
    Yeah, it's not that hard, but you won't be able to find the axle at a hardware store. Just pick up one of these...
    http://www.jensonusa.com/store/produ...ring+Axle.aspx
    10X1X180mm should be good.
    Too Kool for Skool
    Reputation: theg1ant's Avatar
    If you get that axel will it come with bolts or should you buy a pair?
    Quote Originally Posted by coma13
    it's short but it's pretty.... just like a guatemalan hooker...
    Mar 2005
    you may need to get sum nuts
    Local Paperboy Hero
    Yeah, get some nuts. Haha. I picked up some on Jenson. I think they were called Problem Solvers. Make sure they're the right size, 10mm.
    Too Kool for Skool
    not 9mm?
    Meh.
    There's 9, 9.5, 10. And in standard there's 3/8. And there's 5 or 6 different thread pitches. Go to your LBS. They'll get you the right one. If your hub uses sealed cartridge bearings, none of those will work, you have to get one specifically for cartridge bearings.
