Results 1 to 7 of 7
    quick measurment?
    i cant get on the specialized site,i was wondering what the top tube length on an '04 P. is on the size long?...i have the chance to pick one up cheap,but i'm not sure if it'll be suitable...and also for comparison,whats the length on th short?
    so this is how you add a signature!!
    anyone?
    Local Paperboy Hero
    Reputation: Cru Jones's Avatar
    Not sure of the length, but I can measure when I get home. I think it's around 23. How tall are you? I'm 6' 1" and it fits me perfect.
    hmm...might be too long,im only 5'6".but if you could check,id really appreciate it.
    I post too much.
    Reputation: snaky69's Avatar
    Mar 2005
    You definitely don't need the long one at 5'6'' unless you like to be stretched out. I'm the same hieght as you and would definitely not want to go over 22,5'' with a 40mm stem.
    Local Paperboy Hero
    Measured it. Actual top tube length from center of head tube to center of seat tube is 22.75". Effective top tube length, the horizontal dist from center of head tube to center of seat post (if you had it that high), is 23". Like Snaky said, it's probably too long for you. But, you could get used to anything.
    hmm...i better not,im a short 5'6"...well i guess i should just buy a new vagrant...
