Results 1 to 9 of 9
    a question of forks
    Is there a suspension fork that would be great for street AND allow me to use my existing 24" cruiser wheel? I just built a new wheelset for my cruiser and have decided to make the jump to a mtb since I just feel more comfortable on a mtb. I would really like to just run the existing setup and not have to buy a new front hub. Ability to use a peg would be a plus too.
    Thanks in advance!
    Meh.
    Reputation: XSL_WiLL's Avatar
    Any QR or 3/8 dropout fork will allow you to use your wheel.
    Obviously you'll want a frame that takes a 24" rear wheel to go with it.
    I thought they were a different sized axle? Will I have to grind down the dropouts to fit, or the axle?
    Meh.
    No.
    Bikes Rule
    Reputation: Demo-9's Avatar
    Mar 2006
    Yep Same size.
    I ask because isnt a 3/8 hub really 9.5mm ?
    Bikes Rule
    Mar 2006
    3/8" and 10mm are interchangeable.
    but aren't QR dropouts 9mm? I'm not trying to make this harder than it should be, I'm just seeing 9mm on all the forks I look at.
    Meh.
    It will work.
