Results 1 to 7 of 7
    Loves His Sunday
    Reputation: mxrider489's Avatar
    QR to 10mm TA ????
    How do I convert my standard rear shimano quick release hub to 10mm Thru Axle? Is there a kit?
    SAYNDESYN on the Iron Horse Sunday,
    "There is no weekness. It is the bike that Jesus built after he gave up carpentry."
    I post too much.
    Reputation: snaky69's Avatar
    Mar 2005
    I believe all you have to do is to replace the skewers with proper sized bolts, but I'm not sure.
    Just Ride
    Reputation: zerossix's Avatar
    go to yoru lbs ask for a wheels manufacturing 10mm solid axle for a shimano whatever hub. should take about a week fi they dont got it in stock then if you know how to overhaul hubs it just pops right in. if not, drop the 15 bucks orwhatever at the shop and let them doit for ya
    nOOb now rOOkie
    Reputation: Str8NoobYo's Avatar
    mtbr remember
    Reputation: BikeSATORI's Avatar
    nope, chigau yo.
    here's a good example: http://www.unrealcycles.com/item.php?view=141
    but like zerosix said, you should be able to get one at your lbs.
    oh you know what, I just noticed you specified "thru-axle". As far as I know, that is not possible with a shimano qr hub. Unless you get a Saint. The above link I posted is for a 10mm bolt-on, which is just as strong and solid, but the axle is not free to slide out of the hub, once you rebuild the hub, it will be permanently in there...
    Schralp it Heavy.
    Stray Bullet
    Reputation: Nagaredama's Avatar
    Meh.
    Reputation: XSL_WiLL's Avatar
    You can't do a thru-axle, but you can do a bolt-on.
    Nvm... BikeSatori beat me to it.
    It's about 10 bucks for the axle and 10 bucks for labor.
