I'm looking to get a bike for the pump track in the +/- $1,500 range (complete). I won't be doing any DJ (too old for that s#!%), so this is for pump track duty and farting around on flat ground doing wheelies and such. I'm on the tallish side (6'0 and 34" cycling inseam). Any thoughts on which of these 3 bikes would best fit the bill? Any others I ought to consider?
The size L Jackal has a top tube length of 597mm, the L Amp's is 605mm, and the L P.3's is 572mm. (However Specialized says the TT measurement is actual, the Banshee measurement is effective, and the SC site doesn't say one way or the other.)
The parts specs seem roughly equivalent, the main difference being the forks: the P.3 comes with an Argyle RCT, the Amp's MSRP is a couple hundred higher but has the Circus Expert, and the Jackal has the lowest-spec fork (Circus Comp) but you get a front brake, unlike the other 2. Not sure if the difference between the forks is a big deal for my purposes.
