Results 1 to 3 of 3
    Pike 454, 426 or 409? Air, dual air or coil?
    I've got a jackal frame on the way and don't know what the best fork would be Pike 454, 426 or 409. Also what is better air, dual air or coil? Cheers
    Meh.
    Reputation: XSL_WiLL's Avatar
    Dual Air loses the U-turn travel adjust.
    I would avoid the 454 for Park/DJ riding. The 454 uses a hollow crown and aluminum steerer. It's lighter, but sacrifices durability. The 426 has "external" Floodgate, while the 409 has "internal" Floodgate adjust. The 409 Floodgate can be adjusted by a 2.5mm allen without removing the top cap. In fact, the rebound knob can pull off and adjust the Floodgate. The 409 uses the solid crown and steel steerer. A bit heftier, but more solid.
    Reputation: the_godfather's Avatar
    i'd stay away from the 454 because like xsl-will said it has a hollow crown and aluminium steerer. Dual air doesnt have travel adjust does it? I thought it was just stuck at one height. I thought the Air U-turn was the adjustable air travel fork. And yeah it is supposed to lose its travel. I'd go with the coil personally as not a lot can go wrong with it
    i ride my bi*ch hard
