Results 1 to 8 of 8
    outlaws and suburban
    ok i just got an 09 suburban and 09 outlaws. i wanna put a bolt on axle in the back but the 20 mm conv doesnt fit the dropouts. does anyone make a smaller throughaxle that i can put in my outlaws to make this work?? thanx
    Reputation: quickneonrt's Avatar
    no you would need a 135x10mm bolt-on hub like a Hope, Chris King, Woodman makes a 15mm slotted for 10mm dropouts, DT-Swiss, or a Hugi
    Meh.
    Reputation: XSL_WiLL's Avatar
    Quote Originally Posted by quickneonrt
    Wrong.
    The 20mm caps are for the front. You need to buy a Momentum axle. It steps down from 12mm to 10mm to fit your dropouts. It is a bolt-on.
    Wrong.
    were do you get a momentum axle, I am looking to do the same thing with my outlaws if it can be dom 10mm bolt-on?
    also off topic but will i did what you said and put the x-firm spring in my Pike but the travel adjustment is ver difficult. is this because of the stiffer spring? I greased the heck out of it before installed it.
    Meh.
    Google "Momemtum axle" Oh wow... look at all those results...
    Meh.
    The coils are probably wound a bit tighter.
    allright allright I just didn't know you could step the outlaws rear axle down to a 10mm and was wondering how it would be done.
