Results 1 to 6 of 6
Thread: Nano Drive.....
    go huck yourself
    Reputation: jimage's Avatar
    Nano Drive.....
    hi just wondering a few things
    will i be able to fit a dmr 20t nano drive sprocket on deity vendetta cranks?
    and is there a 9t driver to fit hope pro 2s?
    thanks for the help
    Dirt jumps come and go, but dirt junkies will dig forever.
    Meh.
    Reputation: XSL_WiLL's Avatar
    The Vendettas are compatible with Nano drive.
    There is not a 9t driver for the Pro 2.
    go huck yourself
    oh is there any way of running a nine tooth then
    oh and what gear calculator do you use?
    thanks for the help
    Meh.
    No way of running a 9t on a Pro2 hub unless you have a custom driver machined.
    Gear calcuator? Front/Rear*Wheel diameter
    go huck yourself
    is there any good online ones?
    Meh.
    Why do you need a calculator? Front gear divided by rear gear times the wheel diameter. Is that not simple enough?
    If not. search for it on google.
    In case you don't know the website, it's www.google.com
