Results 1 to 9 of 9
    Mar 2005
    Light tires and tubes...good or bad?
    Right now my urban/DJ bike weighs about 35 pounds and I wouldn't mind lightening it up a bit. It has 24" wheels currently with Hookworms (1000g each) and Maxxis downhill tubes (450g each). I was thinking of switching to some K Rads with normal tubes and saving about 2 pounds which is huge in the wheels.
    The setup I have now is pretty bomber and I am worried about flats with my new planned setup. Am I worrying about nothing or should I just stick with the setup I have now? I weigh 150 if that matters. Thanks guys.
    Premium Member
    Reputation: Ojai Bicyclist's Avatar
    Definately run K-rads and XC tubes. With high pressure (50+ PSI) and your weight you'll have no problems. Spins and such'll be easier without those boat anchor wheels.
    tuck-n-roll master
    Reputation: pavement_hurts's Avatar
    Quote Originally Posted by Ojai Bicyclist
    What he said.
    I post too much.
    Reputation: snaky69's Avatar
    Mar 2005
    A cheap way to lighten the bike is to go single speed too.
    Mar 2005
    It is already a singlespeed...a pig of a singlespeed. I will be replacing the terrible MZ Comp that is on there now with an 07 Gold Label. That should help as well.
    Reputation: cummings's Avatar
    May 2005
    yes, get rid of the massive hookworms. about the 07 gold label, is there any difference between it and the 06?
    I post too much.
    Mar 2005
    I dunno, the model year maybe? If it had any teething problems, maybe manitou has fixed them. I haven't heard of any broken gold labels though.
    Mar 2005
    Ah, they have new colors...a pearlescent white and a lime green I believe. I got the white. Not sure about any real mechanical changes but I do know someone that broke an 06 Gold Label.
    USB Rep'n
    Reputation: namaSSte's Avatar
    depends on the use. KRads have weak sidewalls. Get the Kiniptions instead, mch stronger sidewall and they go all the way to your rim. I run a Kiniption in front and a Specialized Comp in back (slick for urban) and they are pretty bomber without stupid weight like the worms. The Specialized are cheap too, like $12! Best urban rear tire I've tried.
    though hope is frail, it must prevail - Taj Weekes
    betam eh-wud-eh-HA-lehu y
    eh-nay Ityopia!
