Results 1 to 5 of 5
    Caution;  Merge;  Workers Ahead! le toy frame III 04' specs???
    what's up fellas?
    Anyone have the specs on le toy III 04' frame??? I need seat post size, seat collar size and what BB reducer I need to run a Saint crank set. Please help
    Slacker
    Reputation: yohxc's Avatar
    Feb 2007
    hi,
    seat-post : 30.9mm
    seat-clamp : 34.9mm
    and it's an u.s(bmx) bb, you need a converter for your crank
    2004 le toy III frame rear hub question
    what type of rear hub do I need?? I know the spacing is 135mm but do I need a quick release hub?
    I post too much.
    Reputation: snaky69's Avatar
    Mar 2005
    Quote Originally Posted by 39cents
    Did you try e-mailing 24 cycles? They have all those answers. As far as the rear hub is concerned the only frame I've see in real life is the porn king so I can't really answer about the Le Toy.
    Feb 2007
    you can use a quick release or an axis with nuts. look at this:
    http://img209.imageshack.us/my.php?i...ict2863id0.jpg
    young 'till I die
