Results 1 to 6 of 6
    Reputation: YamiRider1316's Avatar
    Mar 2011
    Inexpensive single ring crank
    Building up a DJr and need some suggestions on a durable single ring crank that won't break the bank. Preferably something with 175mm crank arms and my frame takes 73mm BB. thx
    Sent from my LG-P930 using Tapatalk 2
    Reputation: Ganze's Avatar
    go to dan's comp and check out the bmx cranks.
    Reputation: jmmUT's Avatar
    Buy used off pinkbike or something. If you don't mind weight it's easy enough to find take off stock cranks from when people upgrade
    Reputation: Doughnut Spaghetti's Avatar
    What style do you want BMX or MTB? Also what ratio?
    MTB is going to be cheaper and have more options.
    Reputation: manual63's Avatar
    Nov 2006
    What does "inexpensive" mean?
    I like to buy U.S. Made stuff when and where I can. Support the regrowth of our economy and so on.
    Profile is the best there is and price isn't too bad, especially for quality US Made goods.
    Profile Racing E-Store
    Mar 2011
    Thank you for the suggestions. Was able to sell some old parts I had lying around so ended up with a little more $$ to spend than I was initially planning on. Went ahead with a Deity setup.
