Results 1 to 6 of 6
    Jul 2016
    How many spacers under stem? 40MM too much? what should the height be from flow to ba
    Need some help determining stem / bar height and such.
    I am 5'11" I ride mostly DJ with some park and street. I use the bike to commute short distances to work where I rise my seat up a fair bit. I also use it occasionally on some single track trails.
    Just wondering how how things should be or what advantages is there to a lower stem/bar height vs a higher one?
    any advice would be great!!
    Jul 2016
    oh my bars are 50mm rise just an fyi, if that changes anything
    Reputation: Junersun's Avatar
    Jun 2014
    For DJ i enjoyed being as upright as possible to be centered over my bb. 40 mm is going to be no problem but it's a matter of how balanced you feel over it.
    DJ to commuter is a very big change in geometry so I'd just focus on the DJ feel then do what you do with the raised seatpost. Rather be comfortable in the air then down on the ground just pedaling to work.
    Current Bikes
    2018 Santa Cruz Chameleon 27+
    2016 YT Tues AL
    2016 Banshee Rune
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    yeah. leave the bike in regular mode and just raise the seat when needed...
    Reputation: DriverB's Avatar
    Apr 2014
    Unfortunately it's a thing where you have to just run different spacer configurations back to back until you find the best feel. I personally like riser bars and run high bars even on my mtb. High as in several inches above seat set at full pedal height
    Sent from my SAMSUNG-SM-G925A using Tapatalk
    Marin County, CA
    Reputation: cmc4130's Avatar
    I ride these 4" bmx cruiser bars, with an 80mm travel fork.
    I used to run 3.25" bars spacered up (and later had a top load bmx stem instead of that front load one)
  1. how many headset spacers is too many?
    By futurerocker1 in forum Beginner's Corner
    Last Post: 08-22-2017, 01:33 PM
  2. Replies: 4
    Last Post: 08-20-2016, 01:30 PM
  3. best budget stem 40mm or under?
    By Landon Klausing in forum Downhill - Freeride
    Last Post: 01-03-2015, 01:53 AM
  4. best budget stem 40mm or under?
    By Landon Klausing in forum Bike and Frame discussion
    Last Post: 12-13-2014, 06:37 PM
  5. How Much is Too Much - Stem Spacers
    By TrailMaker in forum Frame Building
    Last Post: 01-27-2013, 09:42 AM
Members who have read this thread: 32
