Thread: Help with kona
    Help with kona
    where can i get a single speed drop out for a 08 Kona Cowan. because i don't want to use a stupid chain tensioner anymore.
    thanks
    I think that it is the FIT Y
    Reputation: the_godfather's Avatar
    does the 08 cowan even have the adjustable dropout system like the 05/06/07 models. Even if you have the one with adjustable dropouts you dont need the single speed version. just chop of the derailieur hanger on your current one or leave it there. doesnt really make any difference unless you cut too much off. so id just leave it there
    does it have droputs like that. if not i dont believe you can have a single speed dropout as they are vertical dropouts on the newer konas. just run a half link chain and that should get rid of all your problems with messing about with tensioners etc
    i ride my bi*ch hard
    Meh.
    Reputation: XSL_WiLL's Avatar
    Contact Kona or a Kona dealer.
    Mar 2005
