Results 1 to 8 of 8
    Oct 2012
    Help with dj build
    So I demo'd a dj over the weekend and decided they are amazingly fun and have decided to build one up. I have a few parts in mind but the majority of components I have no idea what make good dj parts. I will be a standard build, SS with only a rear brake.
    These are the parts I have in mind.
    Frame: Canfield dj
    Rims(don't know about hubs): Sun ringle inferno 29 or 31
    Fork: manitou circus expert
    Pedals: canfiled Crampons
    That's pretty much it. Goal weight would be around 25lbs.
    Reputation: CrozCountry's Avatar
    Mar 2011
    Looks like you got good components, what help do you need? Rear brake I recommend Shimano Deore. Cheap and sick. I also recommend tensioning the wheels properly. If you can't do that take the wheels to a good bike shop, its a cheap service. Make sure when you go to the shop to say a few times "tensioning" and not just trueing and explain why.
    Tires are important, go to the local tracks you intend to ride, see what other riders are using. Ask them questions about which tires work best there. Important to ask questions and not just copy what they have.
    29er
    I second the deore brakes
    Oct 2012
    Thanks for the info. I have built a few wheels myself and can tension fairly well. My lbs also does a really good job at building wheels if I feel lazy. I suppose I was more wondering about crank width, gearing, and other technical bits like that.
    3 piece cranks, bmx or mtb, I am currently running fly dolemen bmx cranks on a press fit(mid) BB cryptkeeper. I run 30-12 with a hope SS rear, demolition Bulimia front hub. running old as **** 36mm wide 36 hole transition rims. rigid fork, 2" rise bars on a 50mm stem. micro knobby front tire specialized rhythm rear tire.
    Your bike sucks
    Reputation: Carl Mega's Avatar
    I have almost this exact bike as detailed here:
    Canfield Project DJ - Uncharted territory
    It's been a great project and I look forward to riding it whenever I can. I didn't know crap when I started and now, I barely know much more but all in all, everything worked out super.
    I have 175mm XO DH cranks which are 168 Q factor. Running a 28T ring. I wouldn't go bigger than 30 tho as you'll be tight on ring to stay clearance.
    Let me know if you have any questions.
    I'm looking at this frame as well. Any reason not to use a REBA XX since I have one laying around? It's 500mm atc but thats at 120mm travel. If I drop it down to 100mm I should be good to go, unless I'm missing something. Thoughts?
    electron any update on this build, like to hear how it turned out, thanks
  1. First SS bike/build, putting together build list...
    By Nubster in forum Singlespeed
    Last Post: 06-15-2013, 07:12 AM
  2. niner build help newbie to build world
    By desflurane in forum Niner Bikes
    Last Post: 12-18-2011, 04:19 PM
  3. 1996 Dirt Research Kobuk Build (Updated build pics!)
    By fallenleafs in forum Vintage, Retro, Classic
    Last Post: 09-18-2011, 03:28 AM
  4. Soul Cycles Clydesdale Build: My First Bike Build
    By Shocker99 in forum Clydesdales/Tall Riders
    Last Post: 06-21-2011, 03:16 AM
  5. Yeti 575 2010 build Sram xo build
    By britishboy in forum Yeti
    Last Post: 05-02-2011, 04:28 PM
