Results 1 to 11 of 11
    having trouble removing my cranks
    i am no weakling,but for some reason.. on one side of my hussefelt cranks the allen bolt refuses to come out,any suggestions?
    Reputation: f0ggy's Avatar
    alright this may sound kinda stupid, but make sure the allen is all the way in there, and that its perfectly flat, thats the only thing i could think of
    no
    no its not that, the bolts are in even, it is just so damn tight
    i got the bolt off,now the ****ing crank arms don't want to come off!!! this is ridiculous
    dirt rules
    Reputation: sittingduck's Avatar
    Apr 2005
    you are using a crank puller, right?
    Meh.
    Reputation: XSL_WiLL's Avatar
    Are you sure that it's not because you're a hack at working on bikes?
    I post too much.
    Reputation: snaky69's Avatar
    Mar 2005
    You need a crank puller. else that crank ain't goin' nowhere.
    also make sure its the right crank puller
    mtbr remember
    Reputation: BikeSATORI's Avatar
    Quote Originally Posted by f0ggy
    but he might need the left crank puller.
    Schralp it Heavy.
    i have a crank puller,and i was using it, it was just super tight for some reason... wierd.
    supertight? If you have to use most anytype puller to extract something it will invole a tolerance fit,which in many cases means that ,yes, it will be "supertight".
