Results 1 to 6 of 6
    MyBikeStand.com
    Reputation: WingNutt's Avatar
    Have a 9 tooth driver....what to run on front?
    ok I am needing some help.....I have a new set of hubs with a 9 tooth driver...just not sure what to run on the front...I know usually its 2:1 ratio but would a 22/9 be too hard to pedal or step it down to a 20 in front....on 180s
    Reputation: cmc4130's Avatar
    Quote Originally Posted by WingNutt
    2:1 ratio is more of an xc guideline for SS.
    in DJ/Park/Street, you would want more like 2.1 : 1 ; 2.2 : 1, maybe 2.3 : 1.
    i would recommend a 20t for the front. (assuming we're talking 26" wheels).
    dirt rules
    Reputation: sittingduck's Avatar
    Apr 2005
    I prefer a somewhat steep gear, about 60 gear inches is the sweet spot for me.
    http://software.bareknucklebrigade.c...it.applet.html
    A 20/9 with 26x2.35 tires would be 58.7
    20T will require a special crank, or a splined (no bolt) sprocket....
    MyBikeStand.com
    Thanks guys, looks like I may need to just pony up and get the 11 tooth driver. I figured the 20/9 would be the ticket but now I am looking at new cranks too if I go that route. I found a 22 I could get on my cranks. But from the software SittingDuck supplied either a 24 or 25 / 11 would work much better.
    Note these are prototype hubs I am doing a review on for 26" wheels
    mybikestand.com
    dirt rules
    Apr 2005
    You might take a look at this calculator as well: http://www.ridemonkey.com/forums/sho...ainstay+length
    It will give you exact chainstay lengths and gear ratio dependent upon how many links of chain you will use.
    You might avoid having to use a half-link!
    Gold it's the new Pink!
    Reputation: Crimson's Avatar
    I am running a 25t front with a 10 tooth driver and 180 mm cranks. I love it and no problems at all.
    Stephen
