Results 1 to 18 of 18
    Dec 2005
    Handling difference between rim and disc brakes?
    So I was looking at my bike today contemplating things and I got to thinking...for a bike to be easier to toss around, you'd want the mass of the brakes closer to your center of gravity and at less opposite ends of the bike. Seems like if you have a disc and caliper on the end of your fork instead of rim brakes 1 foot closer to the handle bars, the bike will be harder to throw around because of the mechanical advantage the disc has compared to the rim brake (as in the lever between your handlebars and mass of the brakes). Has anybody noticed a handling difference when going from one to the other?
    I post too much.
    Reputation: snaky69's Avatar
    Mar 2005
    A V is less heavy than a disc brake, I think that what you are stating would only be true if a disc and a V brake had the same mass and that the rotor wasn't rotating(another force which you didn't take into account).
    Basically the handling difference would be seen mostly due to a weight reduction rather than a slightly different placement of mass on the frame.
    Reputation: rocpyro's Avatar
    Feb 2005
    Quote Originally Posted by sovietspyguy
    Nope!
    AW_
    AW_ is offline
    locked - time out
    Reputation: AW_'s Avatar
    No, but I have noticed I can pedal faster when I am not wearing socks due to decreased rotating weight and increased aerodynamic efficiency.
    Reputation: Hardtails Are Better's Avatar
    May 2005
    Quote Originally Posted by AW_
    I hope you're being sarcastic.
    The difference would be so minute (for both of these examples) as to be imperceptable.
    Meh.
    Reputation: XSL_WiLL's Avatar
    Depends on what brakes and how you set them up.
    Dec 2005
    Only unlike what you said, what I asked was completely legitimate and reasonable.
    Rollin' twenties.
    wow! i cant believe im not the only one who noticed the connection betweeen socks and speed!
    AW_
    AW_ is offline
    locked - time out
    Are you inferring that I am incorrect? I did the math. I can pedal faster without socks.
    Portland, OR
    Reputation: todd_freeride's Avatar
    Aug 2005
    I really wish my bike had V brake mounts. if it did, I would just always run rear V brakes. a lot simpler, when set up right they can stop just as good as mechanical and even some hydrolic brakes. also just cool, because no one runs them much anymore.
    Ibex bikes
    2007 Ibex Trophy SS
    2006 Jamis Komodo 3.0
    2006 Ibex Zone FR-1
    2004 Special-Ed P.2 A.1
    Reputation: ebfreerider510's Avatar
    as someone already said....the difference in what you are talking about will be so small that you shouldn't notice.
    Dec 2005
    Quote Originally Posted by todd_freeride
    Hydraulic rim brakes are pimp. Will have to try those one day...
    Local Paperboy Hero
    Reputation: Cru Jones's Avatar
    Sockless...
    Quote Originally Posted by aggiebiker
    Word. Sockless works for me!!!
    Me hates pinchflat
    Reputation: 545cu4ch's Avatar
    Aug 2005
    I can bunny hop 3% higher if I do not grow my mustache
    Quote Originally Posted by sriracha
    "jesus would huck it"
    Quote Originally Posted by FoShizzle
    i have found the 1.5" headtubes to be slightly larger in diameter than 1 1/8", plus or minus
    I post too much.
    Mar 2005
    I can 180 2% faster if I remove dirt and grit from my tires, less rotating mass.
    I think I shouldn't be spamming.
    Dec 2005
    Ok, ok, but seriously if people complain about an extra 200g on their tires, I'd think someone might notice an entire pound moved a foot to the rear making the bike harder to swing around.
    I post too much.
    Mar 2005
    The weight on tires is artificially increased by the fact that they are rotating.
    F = ma, or force = mass * acceleration, so the bigger the mass, the more force you need to get the same acceleration going. That's what light tires are for.
    On the other hand, moving weight around on the bike will slightly change the center of gravity's location, but the change will be so minute that it'd be hard to notice. removing 200g of brake on the rear of my norco 416 wouldn't do much, when the whole bike weighs in at 15 900g.
    (200/15 900)*100, we're talking a 1.15% difference in weight, and the weight is distributed more towards the center of gravity of the bike. So yeah, the difference would be hella small.
    Me hates pinchflat
    Aug 2005
    Quote Originally Posted by snaky69
    Me neither Actually, the OP's question was valid...
