Results 1 to 10 of 10
Thread: Gold label
    Too Kool for Skool
    Reputation: theg1ant's Avatar
    Gold label
    Can an 06 manitou gold lable 2 set at 100mm be internally switched down to 80mm my moving spacers?
    Quote Originally Posted by coma13
    it's short but it's pretty.... just like a guatemalan hooker...
    Portland, OR
    Reputation: todd_freeride's Avatar
    Aug 2005
    Quote Originally Posted by theg1ant
    yep, most of the maniyou's can be set to 80mm
    Ibex bikes
    2007 Ibex Trophy SS
    2006 Jamis Komodo 3.0
    2006 Ibex Zone FR-1
    2004 Special-Ed P.2 A.1
    Meh.
    Reputation: XSL_WiLL's Avatar
    It spaces out the negative travel assembly.
    Too Kool for Skool
    so it can be done? sweet.
    resident dumbass
    Reputation: dirtyharry's Avatar
    so an 80 mm could be set down to 60?
    I'm out of things to say . . .
    Too Kool for Skool
    I think its only between 100 and 80 but im not positive.
    Meh.
    A few "aftermarket" mods and you can set that sucker down even more. I've gotten 150mm Shermans down to 65mm.
    an 80 mm gold label couldnt be brought up to 100 right?
    I post too much.
    Reputation: snaky69's Avatar
    Mar 2005
    Actually I thin they could. They probably just have a spacer in there to make them 80mm. Remove it and it would probably become a 100mm.(Just an educated guess)
    Meh.
    But if the 80mm Gold Label uses shorter compression rods you can't do anything.
