Results 1 to 23 of 23
Thread: General Issue ?
    Reputation: mesier's Avatar
    New question here. General Issue ?
    Hi!
    What you know about frame Atomlab G.I. Street ?
    Tough?
    Good for street/dj ?
    What about this frame with 24" wheels?
    Is this frame the same Pimp2 ? (except dropouts).
    Any opinions needed!
    Reputation: paintballeerXC's Avatar
    Jun 2005
    its a very sweet frame ebfreerider has uses it with it i think. good company
    Reputation: ebfreerider510's Avatar
    Quote Originally Posted by paintballeerXC
    i actually run the trailpimp frame, which i believe has the same geo as the GI and Pimp2, just different tubing. it's a very dialed frame
    Rb
    Rb is offline
    Feb 2007
    Quote Originally Posted by mesier
    Hi!
    Tough?
    Tough?
    Haven't seen a broken Atomlab yet....
    Sure. Are you?
    Why not?
    Same bike. Straight-gauge CrMo instead of the butted Daytona stuff...
    Reputation: WhitePony's Avatar
    Oct 2007
    So basicly the trailpimp is an upgraded version (lighter) than the GI?
    I have been looking at the atom labs stuff for awhile now. It looks pretty bad ass.
    I whip these -
    07 Yeti DJ, 08 Marx 4x WC
    05 SC Bullit, 05 Marz 66
    http://pointoneracing.com/
    www.anthonybest.com
    Reputation: Graydog's Avatar
    Quote Originally Posted by WhitePony
    GI has vertical dropouts / Trailpimp has horizontal dropouts
    Do it with style
    Reputation: EVIL E's Avatar
    Feb 2005
    I have a TrailKing and i love it....park,dirt,street,good even for droppin the cliff at falls city
    anyone have a pricelist for the atomlab frames?
    Quote Originally Posted by rcmay
    www.atomlab.com
    do you guys think the trailpimp could make a good street/urban bike? Possible to build it at or under 25lbs?
    Reputation: the_godfather's Avatar
    if you plan to run disks get a pimp2 as the dropouts tend to bend with the use of a disk brake
    i ride my bi*ch hard
    I post too much.
    Reputation: snaky69's Avatar
    Mar 2005
    The trail pimp is just that, a street/dj bike. So yes, it is good.
    25lbs? That'd be pushing it, but a 28-30lbs build could be achieved easily.
    snaky69, do you think I could build a 25 trailpimp with $2000?
    Im still uncertain about the frame, but the rest of the parts look like this:
    Marzocchi 4x reduced to 80mm
    atomlab trailpimp lites 24"
    Macneil seat and seatpost
    profile bmx race cranks w/ti bottom bracket
    thomson 50mm 4X stem(this could possibly change)
    unsure about what gear setup I wanna go with, but more than likely microdrive 9x24
    handlebar, tires and grips I'll figure out later
    Anything is possible. My bikes sits at 26.2 pounds it would be tough to get it to 25 without sacrificing some burlyness.
    Rb
    Rb is offline
    Feb 2007
    I like mine......
    It's possible to get it down to 25 lbs... just gotta spend the cash and be choice in your part-spec....
    I work for a shop, so I dont have to spend as much as some people. I am probably looking to spend $2000 retail. Can I run BMX hubs like profile on a trailpimp?
    mtbr remember
    Reputation: BikeSATORI's Avatar
    no bmx hubs (110mm rear spacing), but you can indeed run Profile 135mm rear hubs on your Atomlab.
    Shouldn't really equate dollar amounts to weight amounts here... That's not always a level comparison. It's not like because someone has a 24lb stp they spend 4K on it, but someone with a 35lb clifcat only spend $700...
    Everyone's build is going to be a little different.
    Graydog, I think I've said it before, but your ride is smooth. yeah, it would be kind of tough to drop much more weight from there, at least anything nearing a full #, from what I can see anyway.
    Schralp it Heavy.
    Quote Originally Posted by BikeSATORI
    so who make the BEST 135mm rear hub for an urban/park application? I love the profile stuff, and they are pretty local to me as well. But is there something out there that might be lighter AND stronger? Honestly Im more worried about weight, Im not that aggressive of a rider and Im relatively light weight(155lbs)
    mtbr remember
    "Best" is a relative term.
    Go with the profile, support your local company. Solid stuff, good engagement, great customer service, lots of parts available for'em.
    Are you going disc brake or non-disc hub?
    If you want 9t rear for your super micro-drive, you'll have to get a hub that can run a 1pc driver, most "mtb" style hubs cannot do this, and can only run 13/12t at the smallest on a cassette body.
    I run an old school Profile SS on my Molly, but that is 110mm bmx spacing. A bit heavy, but works great for me. I threw in an alu. bolt on race axle and a ti driver to lighten it up some, along with some new pawls and springs to start the season off right. She's been goin' strong for about 3+ years now.
    Also, if I were you, I'd look for a hub that is bolt-on, not for 9mm quick-release. Bolt-on will be more solid in your dropouts, hold its position longer, and stay stiffer as well.
    Schralp it Heavy.
    Reputation: cmc4130's Avatar
    hey graydog, what is the tt length on your trailpimp ? (center to center)
    @wishEMT
    Reputation: gwillywish's Avatar
    profile could do anything, they mke some of he best hubs around for any application, including a 9t mtb ss hub
    Thanks for your opinions, guys!
    Such frame was order a friend of mine.. Frame looks more cool in real life than in the picture. Damn lightweigt (2.5 kg), but all tubes seems to me very thin-wall. Was hear about one frame bend.
    Quote Originally Posted by cmc4130
    ??? Never measured it myself, but I'll check it out for you tonight. Atomlab list it at 22.3
