Results 1 to 2 of 2
Thread: The Gear Ratio
    Semi-Pro Ameteur
    Reputation: PacificPilot's Avatar
    Nov 2008
    The Gear Ratio
    Gear ratios.
    How do y'all feel?
    I like a micro 25 in the front for the weight and look - and somewhere around a ten in the back.
    Thoughts, opinions, rants, all that...
    Let's take Colorado and go chill with the British Isles.
    Reputation: cmc4130's Avatar
    55 gear inches is the classic BMX gear. 60 gear inches is fine if you want to haul asz--not good for gate starts at the track or short run up drop-ins at the skatepark. as you get less than 55 it gets spinnier.
    what size wheels do you have ?
    use the gear ratio formula:
    25/ 10 X 20" wheel = 50 gear inches. yuck.
    25/10 X 22" = 55. perfect.
    25/10 X 24" = 60 . haul asz.
    25/10 X 26" = 65 haul even more asz.
