Results 1 to 6 of 6
    Reputation: Yuengling's Avatar
    Front Wheel Question
    I have a marzocchi dirt jumper fork with an azonic outlaw front wheel with thru-axle on my Blk Mrkt Mob. I want to swap this for a rigid fork and bolt-on wheel. Problem is, I can't find a suitable wheel anywhere. Anyone have a good resource for a 26" bolt-on built wheel that can be used for dirt jumping?
    Cannondale Caffeine 2 29er
    Redline Monocog Flight 29er
    Fuji RC Team
    Kona Jake the Snake
    Blk Mrkt Mob
    why not just use a quick release? You can always swap the axle from a hub that uses a quick release with a longer solid axle.
    Meh.
    Reputation: XSL_WiLL's Avatar
    You can use the quick release adapters with a bolt-on skewer or a DT RWS skewer. It's not as secure as a true bolt-on. But you've already got the parts.
    All Shimano hubs can be converted to bolt-on. You can run a BMX hub. Atomlab makes a bolt-on hub. So does NS. I'm sure there are tons of others.
    dirt rules
    Reputation: sittingduck's Avatar
    Apr 2005
    I think his "thru-axle" is maybe a 20mm hub. If that's the case, just get a 20mm rigid fork..
    Quote Originally Posted by sittingduck
    Are you telling me I can I use my existing thru-axle on some rigid forks?
    Fuji RC Team
    Kona Jake the Snake
    Blk Mrkt Mob
    dirt rules
    Apr 2005
    I'm telling you your terminology is confusing.
    If you do indeed have a 20mm hub, YES you can get a 20mm rigid fork. DMR and Identiti make them, as I'm sure others do as well.
