Results 1 to 35 of 35
    the best of both worlds
    Reputation: fastNdirty's Avatar
    Fork Recommendations
    Looking to upgrade the fork on my '05 Specialized P2. I do both urban and light DJ. I weigh about 220#s. What travel length is best 80 or 100mm? Any recommendations are appreciated. Thanks
    Meh.
    Reputation: XSL_WiLL's Avatar
    What's your budget?
    There's about a dozen of these threads already started.
    Apparently since I'm a tool (per another thread), I'm going to recommend looking at the Pike and the Argyle. Ease of use, lots of adjustments, great dampening, very solid forks. Gold Labels and slammed Shermans are also nice. I would defiintely recommend a TPC+ Manitou Sherman. They're relatively light, you can permanently reduce the travel (lowest I've reduced one to is 65mm), shimstacks can be played around with to change the feel.
    Budget is around $350. I may be looking for a used fork to get more for my $. I'm pretty open right now, I know that I have to replace my Marzocchi Dirt Jam Pro because its a piece of $hit. Every time my front wheel leaves the ground it slams open. Feels like the lowers are going to just keep going right on past the stanctions.
    I post too much.
    Reputation: snaky69's Avatar
    Mar 2005
    Wow, that is a bad case of top out.
    My dj3's don't top out at all, mind you I barely have any air in them(I'm pretty light at 150lbs geared)
    Reputation: ebfreerider510's Avatar
    Quote Originally Posted by fastNdirty
    word bro, i just rode my friends new cowan yesterday that came with a dj3...exact same thing happened. caught me off guard when i was manulling it. there is another thread about this same subject where you could get a ton of info, but i will just say again that i recommend a pike
    Meh.
    Some Marzocchi SSV dampened forks have wicked top-out. Check oil levels, run less air pressure, maybe run a more viscous oil.
    350 can get you a Pike for sure. Unreal has the air model for 375 new (thus with warranty). But SRAM really isn't a stickler for warranty issues.
    my dj3's are workin fine on my hardrock
    im not sure how much they are but the new rock show totems look pretty cool and have got a big right up
    I post too much.
    Mar 2005
    Quote Originally Posted by rolling racer
    They are over a grand, plus, he's looking into an urban fork, not an 180mm hucking/downhill single crown.
    Reputation: cummings's Avatar
    May 2005
    Yea, remember, we're looking for a street dj fork, not a hucking monster. Anyway, there are many threads on this topic, not trying to be rude, but just do a search and you will get the exact same answers in those threads.
    Meh.
    Quote Originally Posted by snaky69
    Well said.
    Ended up getting the new Marz 4X. Feels way better than the Dirt Jam Pro amd much lighter too.
    I post too much.
    Mar 2005
    Thanks for guinea pigging it for us.
    May 2005
    nice. ride it and give us a review
    resident dumbass
    Reputation: dirtyharry's Avatar
    Yes, do. Personally, I don't think there is any difference between a 2007 DIrt Jumper and a 4x except 110 mm vs 100 mm, but that's based on the site info.
    I'm out of things to say . . .
    mmmm, caffeine!
    Reputation: Noonie's Avatar
    Feb 2006
    100, maybe more?
    May 2005
    Im pretty sure there is alarge weight difference
    I post too much.
    Mar 2005
    Quote Originally Posted by dirtyharry
    The crown is different, the 4x uses an air spring I belive.
    resident dumbass
    Brad's customed 4x uses an air spring, but i dunno bout the normal one. WHat's the crown difference?
    I post too much.
    Mar 2005
    Doesn't use pinch bolts and I think it is somewhat of a different shape. Check out marz's site.
    There you go, marz 4x, not pinch bolts and holes in the crown to make it lighter. http://www.marzocchi.com/Template/de...DOggetto=30798
    Dj3, pinch bolts and a slightly bigger crown.
    http://www.marzocchi.com/Template/de...DOggetto=30800
    Mar 2006
    Pike, Gold Label, or used Nixon. Used to run Marzocchis but the weight is killer and so is quality of the cheaper forks. Top out and bad rebound countrol in general also broke a DJ3 at the drop out.... P frames are heavy as hell to begin with, mine was a tank with a DJ3.
    resident dumbass
    Woah, P. frames heavy? Hold on there, my friends p.1 frame is crazy light, compared to mine of course. Mine is atleast 9 pounds (just the frame!).
    Meh.
    You just got straight out shafted then. My Coiler weighed under nine WITH THE SHOCK. Stab Supremes weigh around 9.5 with the shock. The Cowan is 5 pounds. My Addict is a hair under 5 pounds. Scott Voltage YZO weighs a hair under 5 with the thru-axle. Even the Azonic Steelhead is only 7.5 pounds. You get the idea.
    Mar 2006
    What kind of frame is it?!... 9lbs is a ton for a hardtail unless its made from Hi tensile lead?...
    Meh.
    He's got a Trek Bruiser.
    P1 is going to feel lighter because it doesn't have gears, front brake, other heavy stuff, etc.
    Mar 2006
    Ouch I have never liked those frames geo or I guess period.
    resident dumbass
    My bike's singlespeed! Either the tires are making it feel heavier than it is, or it's just plain heavy. I am not going to be taking all the stuff off to weigh the frame, but it's heavier than J-doggs steelhead by A LOT. But I've got some seriously large tires.
    Portland, OR
    Reputation: todd_freeride's Avatar
    Aug 2005
    P. frames arent heavy.
    mine weighs in around 5.5 pounds.
    complete my P. is 28 pounds.
    now tell me, is that heavy ?
    Ibex bikes
    2007 Ibex Trophy SS
    2006 Jamis Komodo 3.0
    2006 Ibex Zone FR-1
    2004 Special-Ed P.2 A.1
    resident dumbass
    I may be off a bit, but I'm going to back up the estimation that my bike is 45 pounds singlespeed.
    mtbr remember
    Reputation: BikeSATORI's Avatar
    lowers are different as well as everything else Snaky69 said- look at the drops on each and compare. More formed on the 4X. don't assume these things... at least look at the pictures before you do...
    Schralp it Heavy.
    mtbr remember
    I'm doubting this assumption as well dirtyharry...
    but, you know, this negative (reverse?) exaggeration is interesting though, most people at least attempt to make their own possesions sound better than they really are, instead of just throwing it out there that the sh!t is a brick....
    Schralp it Heavy.
    resident dumbass
    I'm not kidding. Tell you what, I'll try and weigh it. Of course, I have to find a scale.
    The bike may be heavy, but I sure do enjoy it. I'm learning to flick it around quite well. As soon as my soccer tournament is over, I'm going to go for the 15 footer (the next step up from what I'm jumping now). I did the current 8 footer so perfectly the other day. So, SO smooth, it was crazy.
    Meh.
    Use the bathroom scale, not the most accurate, but gives you a ballpark figure.
    eminence front
    Reputation: xray's Avatar
    May 2005
    The bike may be heavy, but I sure do enjoy it..
    There is no way your bike is 45lbs, thats just rediculous. My hard tail is a tank and its 36.5...
    45lb HT, geeze, maybe a monster T on a morphine would get you that high...
    resident dumbass
    i don't have a bathroom scale . . .
