Page 2 of 4 FirstFirst 1234 LastLast
Results 101 to 200 of 309
  1. #101
    VP/ Terrain Designer
    Reputation: NastyNick's Avatar
    Here are some pics of a jump park called The Lair in Bend, Oregon. We just finished our spring build sessions. We had 39 people show up to a weekend build day!!!
    Lower section of jump lines.
    Braun Enterprises LLC, Building Cool Stuff
  2. #102
    Reputation: Jason B's Avatar
    Nice!
    Transition Bank
    Transition ToP
    Transition Covert
  3. #103
    Reputation: cmc4130's Avatar
    Quote Originally Posted by NastyNick
    A lot of great-looking stuff there!! Maybe you could elaborate a little (as far as this being the DJ, Pump Track "plans") thread . . . with some of the measurements, spacing, techniques etc. used ?
    Do yall have a water source to water the jumps? Is that all native soil (if so, it looks surprisingly good)....
    I like how yall made landings a little stepped-up and big and wide--that will definitely help the durability.
  4. #104
    Quote Originally Posted by Flboy
    My freinds and I are going to build a DJ park and a Pump track. I have been doing a lot of research trying to find the best set I can find. So does anyone have and good suggestions of webpages or any links that could help me out. I did get the e-book from leelikesbikes.com.
    This ist the gayest thing Ive ever read. You need an instruction manual to dig and pack dirt.
    If it (roller, berm, whatever) sucks dig it up and move it.
    believe in yourself! I believe in you!
  5. #105
    Quote Originally Posted by Grizzy
    Sure, for someone who has already ridden different spots and knows the basic designs already, then a little trial and error is fine (and usually necessary). But, this whole thread is designed to assist beginners and people who want to try to get it better the first time.
    There have been so many times I have seen things built not right, get torn down and re-built not quite right again, then get abandoned. And I also have met quite a few experienced, rad riders, who can't design and build trails for sht. And I also know guys who are not great riders, but who are great designers/builders. Most people don't see what goes in to good design. Bystanders just see piles of dirt, while many riders don't think, just ride. A lot of times, a setup will work okay, but a different design could improve it immensely.
    Maybe I pay a lot of attention to measurements etc. because I've built a lot of ramps--from backyard half-pipes to private and public bike/skateparks... There's something to be said with looking at plans and doing stuff right.
    Here are some guys designing and building professionally:
    Inside Earth Ramp Dirt Park Construction
    http://espn.go.com/action/bmx/blog/_/post/5364197
  6. #106
    New city-sponsored jumps
    Tom Brown Park in Tallahassee, Fl.
    http://www.ridemonkey.com/forums/sho...d.php?t=242376
    this is a good example of how to improve a typical tabletop. ---> make it a step up, where the landing is taller than the launch. the reason step ups are so common in dirt jumping is that a bigger landing has more space for the wheelbase of your bike to land.
    note especially, the curved over landing-edge. much smoother than a hard-corner landing edge.
    here's are two other examples of the rolled-over or curved landing edge on a step up . .. this time at wood bikeparks:
  7. #107
    although some builders do build the sides and back of a jump almost vertically (see second pic below), it is more typical (and durable) to have your jumps somewhat Pyramid shaped. and if they're slanted, this means the base of your jump is going to be a lot wider than at the top, or the lip. this means that the base (or "footprint") of the launch is going to be like a big rectangle on the ground. you mark that out to start with and build the entire base and pack it down. then you add the next layer, pack it. then the next layer etc. like Aztecs or Egyptians building pyramids. this also makes for easier packing because it's a lot easier to pack downwards than to pack sideways later (trying to make a jump wider).
    Pyramid shaped jumps. very sturdy/durable:
    from
    Oregon Trails
    http://www.ridemonkey.com/forums/sho...d.php?t=233036
    Vertical sides & back. No question it looks rad, but it will be less durable. Especially if you're not using premium clay. Places that have amazing clay like in this picture are better able to stack and pack vertically.
    If you're doing the pit/bowl method of building (where you get the dirt from the riding line) you'll notice that a lot of the "base" of the lip is part of the natural earth already there . . . . this is the most efficient way of building.
    You can also find a natural decline and build a landing extension at the top of it, like this:
  8. #108
    another example of the "pyramid" sides to launches and landings . . . . brought to you by the All-Star digger crew for Odyssey's Texas Toast jam which is happening this weekend in Austin:
  9. #109
    Well I've got dirt coming this weekend. I'm getting 6 dump truck loads which is 72 yards and renting a skid steer. I'll take pictures and keep you guys posted.
  10. #110
    I guess this hasn't come up so far . . . . but it's worth mentioning that pump track style features can be made of lumber. Either in the freeride-ish planky style or in the smooth-plywood bmx park style.
    Ray's MTB has one of the best known:
    Here's an outdoor one (with the 2X6 planky style). . . at the Burnaby skills park:
    Good wood-berm view:
    Not real psyched on the particle-board, but has some good shapes:
  11. #111
    We want to build some dj's up in a forest spot we ride. This would all be done by hand using existing dirt and downed wood. Is there a recommended wood to dirt ratio? Thinking about base and 3/4 of lip/landing wood and the rest dirt?
    We could build the line using the pit/bowl method and eliminate most of the wood. But lots of planted trees and roots that make deep digging a real pain. Also, lots of rain during some months, so kinda worried about drainage issues with this method.
    Any advice would be awesome!
  12. #112
    pnj
    pnj is offline
    Dec 2008
    The less wood, the better. When the wood starts to break down/rot, your jumps will suffer.
    Also, if your dirt isn't thick enough, when you need to make repairs (and you will) the logs can often reveal themselves right where you don't want them. You can't shape a lip with a log sticking out of it....
  13. #113
    Oct 2010
    Lots of good info, thanks
  14. #114
    I know a guy who travels all over building pump tracks dj and all kinds of dirt features if any one is intrested. They Just came to tallahassee and did some stuff here.
  15. #115
    Just got done marking out a pump track in my backyard cant wait to get dirt and get started. Goona feature it on my site.
    Soil Taste Tester
  16. #116
    I'm thinking about building a pump track in my backyard. The area that I'm using is on a slight hill, so I'll have a natural drop in, but my big concern is getting back to the top without having to do a ton of work. Any suggestions as to how to build to get back up a little easier?
  17. #117
    Quote Originally Posted by K9Self View Post
    There are several options. Upgradient rollers do work if they are carefully spaced and sized (we have upgradient rollers at my spot); you can also have upgradient jumps, where each set is a step up. The best option in my opinion though is to build a large structure at the low point of the property which artificially creates elevation and therefore generates kinetic energy--it can be a roll-in, a bank, a large quarter pipe, a quarter pipe to wallride, etc. See: Roll-ins - Ridemonkey.com. This is frequently done in skatepark and bikepark street course design.
    Although it's at a skatepark--this is a weirdly accurate replica of bmx style step-up rollers, or what could be also called a rollable double. For your upgradient rollers, it will be good to use this type of shape, because in a sense, a step-up is like a ladder that is getting you up the elevation, yet still giving good backside for your wheelbase to compress on to pump you up the gradient.
    Check out SPA Skatepark Design&Build; they are an excellent contractor here in Austin. Although most people don't think about it, there's a lot of design principles which apply to both skateparks and pump tracks--in both spots, you are engineering flow, with curves and spaces designed to not require pedaling (or kicking, with a skateboard).
    SPA Skateparks: Professional Skatepark Design. Design/Build Skateparks. Skatepark Construction. Skateboard Park Contractor. Skatepark Consultation. Custom Concrete Skateparks. Wooden Skateparks. Backyard Ramps. Skateboard Production Events. Contests.
  18. #118
    Thanks cmc4130 - I think I'm going to try the rollers and see how that works out.
  19. #119
    cool, but i really think it's worth considering a wood build up at the low end of the property if you can. as i said there are a lot of varieties. look at it this way---it's actually cool that your area is not flat because you get to have a more unique setup....
    1. Wallride
    Highland MTB Park:
    2. Quarter pipe
    3. BMX-style Vert Wall (Quarter Blending into Vert Wall).
    This would be overkill for your pump track, but I'm including it just to illustrate the idea. BMX vert walls are one of the best speed-generators ever invented.
    4. Roll-in.
    I took this picture at Whistler Air Dome.
    5. Curved Slant Wall aka wood berm Technically a slant wall or "bank" is not a wall-ride; only vert walls are really walls. If you have a 180 berm on your pump track and it's at the lowest elevation of the your slanted yard, you may consider a curved slant wall all the way around the berm so that you can carve up it and get some height, generating more speed to go back up the gradient with.
    Winter Park:
    Diablo:
  20. #120
    CMC you've convinced me to go with a wooden berm. So I've been researching/reading up on how to build one. I'm thinking about doing a 7' x 3' high berm. Using 1x6 for the planks. As for the posts I'm going to bury them into the ground and connect them horizontally to complete the frame. Any suggestions or tips on building the frame? I'm a visual person so I started looking thru pics for some ideas on how to build I found this picture. I really like how the berm starts level with the ground. I'm not going to be going that vertical with mine, but I like that idea. Opinions?
    Attached Thumbnails Attached Thumbnails DJ , Pump Track plans-cf_wallride.jpg
  21. #121
    3' is pretty short. if you want a short berm (whether wood or dirt), then it has to be steep-faced to work well.
    like this:
    the other thing is that a large radius turn soaks up speed while a short radius turn can help you maintain or even generate speed. if you have a 90 degree turn pointed back up gradient, then it's gotta be something you can "whip" out of.
    i want to keep this thread as general "plans" though, so if you want to keep discussing your specific layout, let's make a new thread. take some pics of your spot. how much gradient is there?
    also check out this thread. it had a similar question:
    help with jump line into berm - Ridemonkey.com
    this is a photo i took of the pump track at Whistler:
    note how steep/transitioned the faces of the berms are. this is the best way. they need to look like skateboarding bowl corners. you can't "whip" around a mellow-faced berm. you have to be able to get pinned sideways if you want to go fast.
  22. #122
    New thread & pics of my area up - suggestions appreciated.
  23. #123
    here's a drawing i did to illustrate two potential roller designs. clearly, dirt doesn't have to be exact, but i'm working on a project right now where we'll be using lumber, so they've got to be more exact....
    note the 2 styles of "dome." on the second set, the domes are mirror images of the bowls. by knowing that you're going to use 30 degrees of arc for each section, you end up with a certain spacing--in this case 2 foot tall works out pretty close to 15 feet peak to peak.
    larger rollers like this are good when you want to feel the whole wheelbase of your bike going up and over. a typical wheelbase of a dirt jumper is about 42" (axle to axle) or 68" (5'8") for the bike length with the wheels. so you can imagine there are a little less than 3 bike lengths from low point to high point to low point in this wave pattern. (3 exact bike lengths would be 17 feet.)
    i paced these rollers at Whistler at 20'-22'-ish feet apart. so definitely keep in mind that when you're going fast (like on these Flow-DH trails), rollers can be well-spaced.
  24. #124
    great read here. this has helped a lot with my ideas for our local trail. while not a pump track i did pick up some ideas on designs for rollers and berms for our single track.
    thanks for this link cmc!
  25. #125
    Lightly salted
    Reputation: fuenstock's Avatar
    Quote Originally Posted by cmc4130 View Post
    for going up a slight incline or gaining speed from a slow speed consider an accelerating rollers design:
    I wish I would have seen this thread earlier, I just spent the whole day building rollers and I feel they are to close to each other. I think I'm going to re-work them and go for some accelerating rollers. Would the rollers you pictured here work with the small rollers going to large and then back to small? I would like to have the accelerating effect from both directions with a small gap jump at the largest roller that can also be jump in both directions. What would you recommend the spacing from peak to peak be for the 1',2',4' and 8' rollers?
  26. #126
    Reputation: weaverwins's Avatar
    Dec 2008
    pencil and paper I love, but sometimes you gotta start moving dirt and see how things come along. This "PT" will be very bmx trackish. Less leelikesbikes and more bmx rhythm section dimensions.
  27. #127
    Oct 2011
    Quote Originally Posted by Grizzy View Post
    I too thought it wouldn't be a big deal to move a roller/ reshape a berm, but it's much more difficult to move that dirt the second time (after it's been packed-watered-packed-watered-packed-watered etc) than to put it in the right place the first time. Good plans are imperative.
    We (my 14 year old son and I) built a pump track in our back yard. Had 3 1/2 truckloads of dirt hauled in and dug another 1 1/2 - 2 truckloads within the yard. Sixteen 18 - 24" rollers and six 36" to 48" berms. All by hand. We had to move a couple of the rollers and it was a major pain in the butt.
    My advice to anyone building a pump track would be to put the dirt in the right place the first time. The more times you have to move dirt, the less time you have to ride.
    2011 Canfield Yelli Screamy
    2012 Canfield DJ
    www.pumptrackaddict.com
  28. #128
    a pic of some rollers my bros Abel and Tony and I built recently (with help from Myles and El Paso friends). i did roughly 14' center-to-center spacing and deliberately made them a little taller and steeper than normal because it's an upgradient line (getting you back up to a starting area). may have to adjust a little after they get fully ridden in.
    Allied Compound -- End of the World Jam - January 2012
  29. #129
    Oct 2011
    That looks sick!
    Should definitely get your heart rate up.
    What's it like trying to make that curve at speed with no berming?
    Before we got our track dialed in we had a roller at the exit point of a berm that was tilted out and was literally throwing us off the track at speed because the next roller was set in a little to avoid a light post (yeah, we were being thrown into the light post). We tilted the roller to the inside and extended the berm on the outside of the roller and it made a huge difference.
    I know y'all have already built a bunch of lines, so you probably already know this.
    Will this be a part of the fastest lap for the End of the World Jam?
    2012 Canfield DJ
  30. #130
    Quote Originally Posted by mtlatham View Post
    good question. it works fine. the perspective is hard to get with the photos, but it's a pretty huge radius curve. the other thing is that you can have rollers around a curve without a berm per se because each time you get a little bit weightless over a roller you can adjust your bike position slightly (kinda like having tiny hip jumps). and yes, i definitely also recommend the tilted-roller design in the right circumstances. it's actually a lot more fun to pump things that have slight turns than to just pump a dead-straight line....
    and yes, Hippie Josh was talking about the pump track for the 'fastest lap' ! . . . .
    here's an old pic (fall '08) of our tilted roller-table going into the big pit at WCPT:
  31. #131
    Ride da mOOn Moderator
    Reputation: NEPMTBA's Avatar
    Good job!
    This thread should absolutely be a "Sticky"
    The sheer amount of dirt and wood sculpture from dedicated people spending hours and hours to accomplish their goals in this thread is nothing short of amazing
    Looking at the pics shows there are "Dirt/Wood Artists" that can shape stuff to work for whatever they have in their heads!
    Fantastic info and display...
    ... everyone take a bow!
  32. #132
    Oct 2011
    ditto!
    2012 Canfield DJ
  33. #133
    Dec 2011
    There are some really badass trails in some of those pics. Makes me wanna build in my backyard!
  34. #134
    Oct 2011
    Backyard Pump Track
    best use of backyard space = pump track
    We've lived in our house for almost 19 years. I've spent more time in the backyard in the last 6 months (we started building in June) than the other 18 1/2 years combined.
    Plus - cost is minimal if you do it yourself. Less than the price of landscaping one or two small flower beds. We did 16 rollers and 4 berms for less than $600. We're adding 2 berms, a table top, and 6 more rollers for another $200 worth of dirt (20 yards). Highest entertainment value per dollar spent ratio ever (oh, and you get most of it back just by canceling your gym membership...believe me, you won't need it anymore).
    Our plans and results:
    <a href="http://www.flickr.com/photos/73026863@N03/6595281107/" title="Backyard pump track plans by pumptrackaddict, on Flickr"><img src="http://farm8.staticflickr.com/7169/6595281107_5bfbde542b_b.jpg" width="1024" height="552" alt="Backyard pump track plans"></a><a href="http://www.flickr.com/photos/73026863@N03/6589630949/" title="Backyard Pump Track facing west (after) by pumptrackaddict, on Flickr"><img src="http://farm8.staticflickr.com/7019/6589630949_1693564bda.jpg" width="500" height="334" alt="Backyard Pump Track facing west (after)"></a><a href="http://www.flickr.com/photos/73026863@N03/6589630171/" title="Denton railing our backyard pump track by pumptrackaddict, on Flickr"><img src="http://farm8.staticflickr.com/7170/6589630171_1e08b8f5f0.jpg" width="500" height="333" alt="Denton railing our backyard pump track"></a><a href="http://www.flickr.com/photos/73026863@N03/6589631431/" title="Backyard Pump Track facing east (after) by pumptrackaddict, on Flickr"><img src="http://farm8.staticflickr.com/7026/6589631431_cca34ae4c7.jpg" width="500" height="334" alt="Backyard Pump Track facing east (after)"></a>
    2012 Canfield DJ
  35. #135
    Oct 2011
    This is a little video I put together showing the progress of the build and my son riding it (skip to 1:43 if you just want to see the riding part):
    <object width="420" height="315"><param name="movie" value="http://www.youtube.com/v/uypXMhdXSOU?version=3&amp;hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/uypXMhdXSOU?version=3&amp;hl=en_US" type="application/x-shockwave-flash" width="420" height="315" allowscriptaccess="always" allowfullscreen="true"></embed></object>
    2012 Canfield DJ
  36. #136
    Looks like it rides very smooth. What's the spacing on the rollers ? (I'm kinda confused by the drawing--the legend shows a distance as 6 feet,....)
  37. #137
    Oct 2011
    Twelve out of 16 rollers are 10 feet apart and the other four are about 8 feet apart. All rollers are 18 - 24" high. Berm radiuses are 9', 12', 8', and 12'. I used Lee McCormack's Pump Track Nation ebook for the measurements.
    It does ride pretty well, but we're still working on the track smoothness. We have at least 4 different kinds of dirt, so getting them all to play well together has been a challenge. We're already battling berm erosion. It doesn't take too many little rivulet channels across the track to greatly impact the ability to maintain speed.
    2012 Canfield DJ
  38. #138
    Reputation: JFoster's Avatar
    Apr 2005
    Wow, I want this in my back yard. You think these main rollers are about 4' high and 14' apart?
    Pump Track Session with Sik Mik - YouTube
  39. #139
    Quote Originally Posted by JFoster View Post
    No, they're def not 4' high. Pause the video and compare them to his wheel size.
    One thing that's worth mentioning, is that rollers can be taller and peakier IF you intend to manual them. Many bmx race tracks have this steep-and-deep style of rollers. However, if you want the kind of pump track that feels more like waves, where you pump both wheels on the roller, then they must be mellower/longer and more spread out. If you try to keep both wheels down on peaky rollers, you have to work to press your front end down. You'll also see bmx racers pick their front wheel up before a roller and set it down on the backside. In effect this type of speed manualing is a work-around for a roller that is actually too peaky to pump both wheels on.... Not saying bad, just pointing out the difference...
  40. #140
    Crackhead in Training
    Reputation: jfactor1's Avatar
    Great thread!!! I'm seriously considering building a pump track at my house this spring. I've got 2 acres of land and a perfect spot for one.
  41. #141
    Anyone know how much something like this COSTS?
    Im talking on a bigger scale though...NOT just a "backyard" park...but a "community, or commercial" park?
    Cheers
  42. #142
    Member of The Yeti Tribe
    Reputation: swan3609's Avatar
    If that was my setup, I would totally have a spot to set on/ step off the deck.. Just saying..
  43. #143
    Oct 2011
    Pardon my ignorance - "set on/step off"?
    We jump off the deck and bunny hop back on to it when we're just messing around, but I've been trying to figure out a way to incorporate it more into the flow of the track. I'm certainly open to suggestions.
    2012 Canfield DJ
  44. #144
    Exactly. Find a way to jump on and off the deck that would be very flowy.. Watching the video I wanted to hit a small jump up onto the deck and land in a manual across the deck and drop back onto the track.
    You sure have a sweet setup.
    Sent from my ADR6400L using Tapatalk
    Stop this Derailleur Madness!!.... De-Rail-er
    See what the God of bikes has to say about it..
  45. #145
    Ok here is our plan for a PT complex in Bagneres de Bigorre in France. Its 3 PTs that gradually have bigger jumps. Thanks for all the comments on this forum and especially the input from cmc4130. We will start with the smallest and probably adapt the plans for the bigger ones as we gain more experience. Have only built a couple of tiny PTs so far so will be a lot to learn. Original plan was to separate jumps and PT but seeing the posts and input from cmc4130 we've tried to integrate the jumps into the Pt so that you can ride a loop rather than a single straight of jumps. Will keep you posted as we start to build it.
    Pic here
    cheers,
    pat
  46. #146
    trying to inline a pic!
  47. #147
    Quote Originally Posted by fastfish666 View Post
    looks sweet!! I see so many spots where there could be epic transfers.. looks like a track that wouldnt ever get boring..
    Sent from my Transformer TF101 using Tapatalk
  48. #148
    cheers,
    pat
    very nice computer graphics. i need to catch up with that--still doing pencil/paper protractor etc. !!
    my number one suggestion for your jump loop is to have some sort of artificial elevation to roll-in from to hit the jumps (and to get back onto when you come back around). you may even consider, two artificial elevations--one on each diagonal corner of the rectangle.
    we have a natural hill roll-in at our spot, (see for example). most people roll in and do one lap, although it's possible to keep going (i've done 26 laps, i might hold the track record, not sure ). but, if you notice, almost all indoor bike parks and skateparks use some version of this concept. riders hate pedaling from a stand-still to hit a jump on flat ground. everyone loves rolling in and naturally having speed to hit jumps. at the same time, on flat ground it's not that fun to try to use small rollers to gain speed to hit a jump. it's doable--especially if each roller gets progressively bigger (see the "Accelerating Rollers" drawing I did earlier in the thread, or roller-tables, monster rollers etc. but still, i feel like most riders will hit 4 jumps a berm another jump another berm a bunch of rollers after that single loop they'll want to chill for a minute and let somebody else go. a platform where everybody hangs out would be ideal. the platform should ideally be more than 8 feet tall. less than 8 is not really gonna do shlt unless you crank up to it or crank down it. 10 or 12 is ideal. it doesn't have to be a scary steep roll-in.
    check out the very first part of this video from Ray's MTB park. (actually if you ever get the chance you MUST visit there). every bike park designer must make the pilgrimage. Ray&#39;s MTB bmx helmet cam session - Mar 2011 - YouTube
    Note how these guys roll-in from an elevation. Then they hit some rollers that are pretty spaced out, then appear to drop down in elevation again. A two-tiered platform could be an ideal way to do it. I think I said it before in the thread, but almost all skatepark street courses operate on the "basin" principle. You have high elevation all the way around the park, whether by quarter-pipes, flat banks, wall-rides, whatever. You drop in from any part of the perimeter of the park, then you flow over things in the middle area, whether they are jump boxes, pyramids, grind boxes, whatever... then when you get to the other side you have some elevation to get up on to turn around. The same principle can operate with a dirt park, except rather than turning around 180 degrees like a typical skatepark you turn left or right 90 with something that acts as a berm. It can be a wood berm, or a hip jump.
    Check out this thread where I have a bunch of pictures and discussion of a loop options:
    http://www.ridemonkey.com/forums/f61...o-berm-241208/
    Lastly, consider that the shape of the track doesn't have to be a rectangle with rounded corners where each berm is a 90. If you tilt a rectangle over (a parallelogram) you get 2 mellow turns and two over-90 degree turns. Or, if you make the track triangular, you could have three 120 degree berms (or one 90 and two 140's) or whatever.... Also you can bend the long sides of a rectangle in so it's slightly peanut shaped. This will get a little bit of hip action in, and you won't always be going straight or turning left.
    I think I need to do some more drawings !!!!
  49. #149
    thanks for the ideas. First up I only did the computer graphics because our local town planners wanted a 3D model so that they could calculate the volume of earth/dirt required to build the jumps, it was actually done in the Ship-Design software that I write for a living! I did all the original drawings with pencil and paper -- its definitely quicker! But I think the 3D models are quite useful when you are trying to present the idea to town planners etc who have no idea what you are on about. Actually -- originally I went one better and built a scale model (also occupied the kids and I on a rainy afternoon)
    If there is any interest, I was vaguely thinking about writing a plug-in for Google Sketchup to more quickly add standard rollers etc.
    Anyhow back to MUCH more fun discussion -- the track itself. The idea is that there are 3, essentially independent loops and the idea is that they get progressively bigger jumps and features. The loops are generally supposed to be ridden anticlockwise. There is a slight slope in the long direction of the loops -- you drop about 1m over the 55m length of the track.
    Its a bit lost in the perspective, but in the medium one the start hill is 1.5m (5ft) high and the main tables are 1m (3ft4in) high. I was planning similar in the big loop but I think I might have got a bit carried away and I think both the jumps and the start hill are a little under 6ft high. I might see about reducing the height of the jumps as the originally intended height was 5ft. Im a bit concerned about making the start too high as we do get quite a bit of rain here (and snow) and I was worried that it might all get washed away! But we are thinking of building the main features with rock/hardcore and just putting the final shape in with soil.
    Again I like your thinking of keeping it more "natural" -- the trouble with computer modelling is that its easier to do things in straight lines -- hence why its better to do it with pencil and paper :-)
    I remember the accellerating roller posts -- Have you tried them in a track? When I plotted them out, doubling the size each time seemed quite extreme? I was worried that it would be hard to make it over the last one if you were going up hill -- maybe smaller increments?
    thanks for all you help (my background isnt DJ, Ive ridden a bit of BMX race ovr the last couple of years, but Ive been mountain biking since the late 80s so thats more where Im coming from.
    cheers,
    pat
  50. #150
    papier maché model of a small pump track -- was useful in explaining to the town planners what we had in mind!
  51. #151
    slightly modified "Big" loop with smaller tables on main line and also sort of accellerating rollers on the bottom line (but only 20% increase in size for each one).
    My plan during construction is to start with the smallest loop first and use any experience gained to improve the design of the other two loops. Whether this will happen in practice is not certain as the town planners want their workmen to do the majority of the construction.
    Watch this space!
  52. #152
    Good stuff Fastfish! I like how motivated you are.
    First off, a 'big picture' comment: The Town wanting to use their own workers to do most of the construction is a red flag. The ideal situation is where experienced rider-designer-builders are simply given a huge pile of dirt and reimbursement for front-end-loader/Bobcat rental. At a minimum, make sure that rider-designer-builders are there to point where the town employee or contractor dumps each scoop of dirt, then you guys shape it. There is no way a non-riderdesigner can appropriately shape jumps and rollers. I have a lot more to say about that, but I'll leave it at that (and we can discuss privately or even talk on the phone).
    Next . . . Accelerating Rollers. You're absolutely right that each roller does not necessarily have to be double the size of the previous. They should be specifically tailored to the rider's speed (whether increasing or decreasing), the incline/decline, and to the style of how you want the track to feel. Watch 1:24 - 1:34 in this edit from our spot. This is the third side of a roughly rectangular pump track. It is slightly upgradient. It starts with two regular rollers out of the berm, then a bigger roller, then an even larger one ('monster roller'), then a roller table, then a full sized tabletop jump. It took several re-builds to get it right. The goal was to increase speed in order to be able to hit a jump.
    I have also used accelerating rollers on a decline. If you look at the left side of this pic, you'll see a small roller, then a larger 'monster' roller , then a "camel-back" table (aka rollable double). Because you're starting with some speed and the entire line is slightly downgradient, I made it so that the "dirt waves" (if you wanna think of them that way) stretch out. I have some video I can upload later.
  53. #153
    I realise that its not ideal but Ill be on hand as well as a few guys from the local BMX club. A mountain biking friend is also a minio-digger driver and has his own mini-excavator which will probably come in very handy. Im actually located in France, though my French isnt bad, its not perfect ... so more challenges! ANyhow the town came to us to see if we could build them something -- so I was hardly going to say "no" -- Will have to play it by ear and see how things pan out!
    Im not that experienced with buiding pump-tracks/DJ tracks so its a big learning curve! My plan is to start with the smaller loop and get that fine tuned and use what we learn there in the bigger loops where its going to be more critical. Apparently one of the town workforce is a mountain biker -- though Ive not met him. Will let you know how we get on ...
  54. #154
    pnj
    pnj is offline
    Dec 2008
    That thing looks awesome! what software did you use for those graphics?
  55. #155
    hi -- Im a developer for Formation Design Systems: www.formsys.com Its actually ship-design software!
    I wouldnt recommend it really for designing pump-tracks, but I know it well so was able to produce the drawings pretty quickly -- but Id already done some hand sketches with pen and paper -- but I needed some fairly detailed drawings to submit for approval. Ended up doing 2D drawings in autocad.
    Im thinking about seeing if I can do a plugin for Google Sketchup, but dont currently know the software well enough. If there are a number of people who would be interested on this forum, I might be able to find some time to look into it a bit more ...
  56. #156
    pnj
    pnj is offline
    Dec 2008
    Cost is a huge variable. I've build two pump tracks for home owners. We had 3-5 guys on the crew, paid for dirt, rented heavy equipment when needed.
    One cost $2800.00 and the other was $5500.00. If you involve the city it could go up dramaticly or be fairly low cost....
  57. #157
    this pump track is a good example of the rectangle-with-rounded-corners concept. it's much better than thinking of a track and field style oval. if you have a big track, you don't want huge oval-end berms.
    it's also a good example of integrating a pump track into the woods.
    Adventure Racer: Blessingbourne MTB Trail Centre
  58. #158
    Here's a shot of my buddy's pump track. It's a blast with some really good transfer options.
  59. #159
  60. #160
    Quote Originally Posted by jfactor1 View Post
    that video is a great example of how spaced-out larger rollers are much more fast and flowy than some of the tiny speed-bump designs that are out there. great job.
    i'm particularly looking at the line from 0:24 to 0:27. that set of 3 looks like they're spaced, i'm guessing at least 15' or 17' peak to peak. they appear to have about 3 bike lengths peak to peak.
  61. #161
    if anyone is interested I did a quick spreadsheet for plotting out rollers and tables based on some of the data from cmc4130
    The rollers are based on arcs of circles, as are the take-off and landing of the table. You edit the yellow cells. The table also shows you a trajectory (ignoring any rider input!) I should make it so that you input the speed, but at the moment ist just a parameter.
    cheers,
    pat
  62. #162
    FeeRideRules
    humble beginnings of the pump track our group have been working on heaps ore work been done since these pix but anyway
    ILIKENORTHSHOREANDICANNOTLIE
    glory, glory hallelujah...
    any1 guess what bike I ride?
  63. #163
    This is the first time I've checked out this thread and I'm stoked to see of of these pumptracks on here! I've built 5 tracks now, here's the latest one I just finished in my yard. the pictures aren't that good, but I'll take some better ones and post them up. I'll try to get some pics of the other tracks I've done too. Some of the pics were from the construction phase.
  64. #164
    Your comment on my design
    Hey, I am building a bit bigger dirt line, so here is my plan. Any comments and ideas would be appreciated,....
    Details can be seen in pdf,...:
    Attached Thumbnails Attached Thumbnails DJ , Pump Track plans-dirt-line-l.jpg
  65. #165
    Quote Originally Posted by bikezigo666 View Post
    I can't read that. Try posting something with higher resolution or a link to the .pdf you mention.
  66. #166
    Link to the pdf,...
    I didnt notice that the link was missing,... thanks
    Attached Files Attached Files
  67. #167
    looks great ! the only thing i noticed is that the second double has 1m (3.28 feet) longer gap than the first double. unless you're going downhill, that will cause you to have to struggle a little to make the gap without casing. you'd have to scrub-jump the first one and compress a lot and boost the second one. after a while that gets not as fun/flowy as having gaps that are matched, so you just can float through the line. if you don't want them matched, then i'd suggest have your longer jump first make it lower/flatter like race-style then make the second tall. that's a real common setup in bmx trails. long-and-low to booster.
  68. #168
    Dj
    Thanks CMC for your reply. I have the same thoughts that is why I have reduced the gaps in the second and third kicker. Furthermore I have also made the landing a little less steep - I have used a bit larger radius for the landing than in the original version so that it would be easier to catch the landing,... What do you think?
  69. #169
    I think that looks awesome. Note that although they're definitely cool and work well, landings don't always have to have a circular radius throughout. Theres the flat bank-to-transition style which is common. There are also elliptical and parabolic ones. With dirt , guys aren't actually measuring these shapes but a lot of times eyeballing it gets you pretty close to them.
    Rule of thumb though is that longer and mellowed is better. There tends to be a common mistake of people making landings too steep which shortens up the area you can actually land on. 30 degrees may sound mellow, but it actually works really well. That would be a 30-60-90 triangle where the landing is 6 feet tall and the surface length of the landing is 12 feet. Even 20-25 degree landings work well, especially for trick jumps where you don't want to be required to have an ultra precise nose-dive.
    these are about the steepest a landing generally should be. 45 degrees may sound mellow but it's not. similarly, landing into a 60 degree arc means that the riders trajector would need to be even more steep than that. you would only use a landing that steep if you have a jump where you boost straight up and then really dive down.
    this drawing, from rampplan.org, shows a landing with a 20 foot radius. notice how much more horizontal space there is to land on. especially if you're learning 360s, tailwhips etc.
    http://rampplans.org/forums/uploads/Box_Jump.jpg
    old school style bmx box jump. appears to be about 3 1/2 or 4' tall with about 8 to 10 feet down the slant of the landing. that would make it roughly 30 degrees or slightly less.
    parabolic landing:
    on your roll-in, i suggest making the transition at the bottom of the slant a little bigger. i took this pic at whistler air dome. one of the coolest roll-ins i've ever seen. note how the transition you roll into is as big as large launch. i'm guessing 6' tall and 12'-ish radius.
  70. #170
    May 2012
    dark muck
    Hi all,
    Does anyone have experience with black muck soil(see picture) for creating pump track. Seems like it never going to dry out. Its still pretty "mushy" after leaving it alone for a day.
    I`m almost finished with one roller consisting of lots of rocks(70%-ish of rocks) and this black muck soil. I also "sprayed" a little rocky-sand over the mud just in case. Probably wont make much difference?
    Will the black muck get hard enough? How long will it take to dry?
    I found some clay a little walk away. Some of it seem like 100% clay. Will black muck soil with a tin top layer of clay be good?
    I`m building in the forrest. Impossible to get any dirt from the place i`m building. To many roots. But there is this little swamp with black muck right by.
    Attached Thumbnails Attached Thumbnails DJ , Pump Track plans-skjermbilde-2012-07-28-kl.-00.01.14.jpg
  71. #171
    We've got a low area that sometimes turns into a pond when it floods. It's got good dirt/clay in the bottom of it (part of the reason it holds water for so long). Give it a chance to dry out and see what you end up with.
  72. #172
    Oct 2011
    Valmont Park Pump Tracks - Boulder, CO
    If you haven't been here, you should go. This is the sickest bike park ever. Skills area, Flow track, 4 dirt jump lines, 4 slopestyle lines, dual slalom, and 2 pump tracks. Professionally maintained.
    Go and take one of Lee McCormack's public clinics, or even better, set up a private training session or two. My son and I just spent 3 days with him. Awesome. Worth every penny and two days driving time - and more.
    (Lee Likes Bikes)
    Upper Mesa Pump Track
    <a href="http://www.flickr.com/photos/73026863@N03/7687321210/" title="valmont_upper mesa all by pumptrackaddict, on Flickr"><img src="http://farm9.staticflickr.com/8431/7687321210_93fc22d991.jpg" width="500" height="131" alt="valmont_upper mesa all"></a>
    Lower Creekside Pump Track (that's my son)
    <a href="http://www.flickr.com/photos/73026863@N03/7687130156/" title="lower creekside_denton by pumptrackaddict, on Flickr"><img src="http://farm8.staticflickr.com/7273/7687130156_0f822bd4f2.jpg" width="500" height="260" alt="lower creekside_denton"></a>
    Lee himself railing my Canfield Brothers Yelli Screamy 29er on both tracks:
    How to Ride a Pump Track - on a 29er (Canfield Brothers Yelli Screamy) - YouTube
    Two sweet flowing tracks, and the Creekside has a pretty small footprint which would make it a good pattern for a backyard track.
    2012 Canfield DJ
  73. #173
    May 2012
    Quote Originally Posted by WaveDude View Post
    Thanks, will give it a try. I should probably cover it with something so it wont rain on it? Its rare with more then a few days with no rain here, at least this summer it seems.
  74. #174
    The mixture of wood and dirt and the Texas Toast Jam in Austin in October was incredible.
    2012 Texas Toast Jam: Dirt Final Highlights - TransWorld RideBMX - YouTube
    Note the step-up... Landing higher than launch adds to smoothness. Rolled-over corner makes it case-friendly.
    Note how the wood berm wall is a 90 to flat to 90 rather than a semi-circle 180 design. This allows the rider to pump in the first corner, then pump again in the second corner. Because the radius of each corner is tighter than a full 180 would have been, it's much faster. Also the rider launches up into the wall and exits by dropping into a transition, which also adds speed.
    The jumps did not have massive gaps. I paced them to be roughly in the 13-15 ft. lip to landing range.
    On berm thing . . . remember when you need to turn 180 and get going the other direction in a set of trails, there are two ways (or more) to do it. You can do the full 180 radius. Or you can do 90, straight, 90. In skatepark terms, it's the equivalent of the difference between these two bowl endings. The 90-/-90 is definitily the faster of the two. If you're soaking up speed, use a full 180 radius. If you're wanting the rider to pump around it, use 90 - flat - 90.
    Like I've said before in this thread, you can learn a lot about pump track design by riding cement skateparks. Pay particular attention to bowl corners that are fast and ones that feel slow.
  75. #175
    Hi cmc, I'm currently building our back-yard pump track (still working on drainage and sorting one line out) and was wondering what the minimum radius would be for a 90º to flat to 90º rather than a straight 180º? We're limited by trees and have got a maximum 4m or 13ft outer diameter to play with for both berms.
    Track is for my young son as well as myself, so the radius can't be crazy tight
    Thanks for any advice.
    si
  76. #176
    Quote Originally Posted by si618 View Post
    si
    When you say "outer diameter," are you referring to the widest area that there will be any dirt (including the backside of the berm) or are you referring to the top edge of the riding surface (which would be equivalent to the coping in a skate bowl) ?
    Depending on how steep you slant the backside of the berm, the bottom of the backside of the berm could be another 2'6" (like in this picture) or more further out.
    So if your outer diameter of space to work with is only 13, then that only leaves you a 6'6" radius to the back of the berm, meaning the radius at the riding line might only be 4'-ish. IMO, that's just not going to work well with a 180 berm.
    That said, Lee McCormack's Welcome to Pump Track Nation e-book has a diagram of The Fix pump track (I guess from back in 2004 or so) that shows a super-tight 180 berm with a 38" radius to the riding line. I have talked with a friend who rode that pump track. He's a guy who used to win 4x races and he thought the Fix pump track was crazy tight/tech/difficult-and-not-in-a-good-way. But he also said that once you kind of got the hang of a full body tilt-should-drop-lunge into that tiny radius, you started to get the hang of it.... It kind of seems like the tighter a 180 radius gets, the more the face of the berm has to go to almost-vert. You really have to get sideways to pin it.
    I saw this pic on Facebook, of the Sombrio Ladies pump track jam, Whistler.
    Even though they're wood, these transitioned-face bowl corner style berms are rad. Note how they continued the transition up to almost-vert, just to ensure that no one is going over the top.
  77. #177
    YRG
    YRG is offline
    Feb 2012
    si
    CMC sums it up well. If you have a 6.5 radius, a 90 berm-pump-90 berm could work. With exit bumps, you could berm - double - berm which would be cool
    If you have to build inside the 13 then maybe going to a hybrid track would help. A smooth transition to a wall could give you enough vert to maintain (and increase speed on the exit). That way you can come straight at it and leave straight away from it. (think half a half pipe and tall )
    On our track, I don't want any 180 berms because I'd like every berm to pump and
    I don't want anything smaller than a 10ft radius to maintain a high speed track.
  78. #178
    good points YRG!
    i hope this doesn't derail the thread . . . but cement skatepark bowls / pools can be very inspiring with pump track design. visualize the line(s) your tires are going to take.
    This guy's taking what is kind of the green line above... Sideways pump first corner, ride the back wall straight across, pump second corner....
    Pool Archive - Longboardism.com
    okay now look at this.... what a call a low-high-low berm. you enter low you carve high and you exit low. that's what skaters typically do when carving bowls...
    (from Red Bull Pump Ride video)
    this is also a low-high-low banked turn:
    however, when you have a roller into a turn and a roller out... it's an attempt to reverse it. going down the roller into the berm, makes you go low around the middle of the turrn, then you start to go up again when you exit. even more extreme is a landing down into a turn... definitely makes you take a low line and means the berm does not have to be tall. like this one:
    this one is more like ribbon in, then horiztontal around, then ribbon out:
    see how this guy is taking a low line around this berm. (from Mark Weir pump track video):
  79. #179
    When you say "outer diameter," are you referring to the widest area that there will be any dirt (including the backside of the berm) or are you referring to the top edge of the riding surface (which would be equivalent to the coping in a skate bowl)?
    Widest area I have for dirt. On the west-side berm I might be able to squeeze another foot or two of radius, but east-side is maxed out without removing a big bush, which might not go down well with the better ½ ;-) since I've already cleared a fair bit of vegetation.
    I'll post some pictures in my next post, as my count will be 10 by then.
    One problem I can see is I've got a big pine tree on the east berm, and a big gum tree on the west berm, both are right at the exit points. I'm planning on using rollers on all entries and exits, but it could get messy if there's too much speed being created in the berms.
  80. #180
    Here's a picture of the east berm, note the pine tree and big diosma bush on the exits:
    And the west berm, on the right you can just see the big grey box gum tree on the exit on the right:
    One issue with widening the west berm radius is that whilst I could squeeze a bit extra on the northern side, the entry is quite narrow and due to the bushes, a fixed location on the southern side:
    So if it was widened, on entry there would need to be a small berm on the inside to kick you left before turning right, and conversely (to work both directions) the berm might have to keep going a little further than a straight 90º on the exit. Not sure how that would work.
  81. #181
    YRG
    YRG is offline
    Feb 2012
    Wow, that is tight and the better you make the berm to accommodate the tightness, the tighter it becomes.
    If it were me, I'd come in and cut anything in my way out, but your yard looks nice so that could pose a problem. Maybe wall hits will get you in and out of tight places and let you keep speed going in and out.
  82. #182
    Lightly salted
    I had a backyard pump track for the last 1.5 years and decided to level it because of the dirt it was built with. I dug my natrual soil to get the track dirt, but it does not compact well so made for a very high maintance track.
    This time around I am going to purchase better compacting soil and probably add a sprinkler system. I don't have a lot of space for the track, 88'x16' oval. My last track was an oval with the center filled in with rollers and a small tabletop so that I could change directions any where with in it.
    With my limited space, I want to see if anyone might have some input on raising the fun factor on such a small track? Here is a sketch. I know the size is not very big, but thats what I have to work with.
  83. #183
    Quote Originally Posted by YRG View Post
    I took your advice and dug another 50cm or so of dirt out of the hill side of the berm, and used rock to build up the low side, so it's now as wide as I can make it, and the berms should be able to be steeper and narrower now.
    It's taken ages to finish the problem area of the track, my place is on a sloping block so I had to cut a bench and build a drystone wall and infill in one section of the rollers to make it level and wide enough. Site access is a biatch, so no dingo diggers, all done by hand, but it's done now and the drainage is in.
    Took me a while to find a good local source of heavy clay soil, but just found some and hiring a tipper truck on Friday to transport it. Then have to shift 10-20? tonne from the top of our garden to the bottom!
    Really got no idea how much dirt will be needed, I'm going to start with 10 tonne and see how I go.
    Quote Originally Posted by fuenstock View Post
    With my limited space, I want to see if anyone might have some input on raising the fun factor on such a small track?.
    That's almost the same size as my track, my plan is to have a pimple roller/transition in the middle of the track, not sure what else you can do to up the fun factor?
    I hear you with the dirt woes, ours is pretty crappy so I didn't want to build with it, but a local graveyard has good heavy clay soil which should be ideal, and they are always wanting to get rid of dirt to make space for bodies ;-)
  84. #184
    Lightly salted
    Kind of your same Idea, I had a small 4' gap jump in the middle that could be hit in both directions. I also made multiple options to change direction within the track. Makes it alot more fun then just going in a circle. I've already leveled my track and will rebuild with good dirt this time.
  85. #185
    pnj
    pnj is offline
    Dec 2008
    curved wall rides at either end, spine in the middle.
  86. #186
    With my limited space, I want to see if anyone might have some input on raising the fun factor on such a small track? .....
    Quote Originally Posted by pnj View Post
    yeah definitely. i was going to say something similar... which is that the best way to increase the fun factor in a small area is to build UP vertically. you need artificial elevation on both ends of the yard. either in the form of platforms with roll-ins, quarter pipes, wall-rides, dirt tranisition up to wood slant, whatever.... then you can put something jumpable in the middle, like a box jump, dirt tabletop or double, a spine, etc.
    so even if you're not necessarily thinking of wanting ramps or riding in a bmx style.... just note how the elevation at both ends of this area allow you to generate speed.
    Steven Moxley Backyard Ramp Session - YouTube
    Roll-ins
    this now-dead pump track had a slant-wall-ride at the bottom end. riding up that slant and dropping down again gave you momentum to get back up the slight incline... You could make the wall less slanted if you want it to act more like a wedge than a wall ride. and, as pnj said, curved wallrides, which act like berms. Austin local Pierce:
    Ninth Street BMX, the official local's site -Austin, Texas. Non profit, Non biased, Digger run.
  87. #187
    YRG
    YRG is offline
    Feb 2012
    Waiting for spring
    Here is the work we started last fall. Got lucky and some local construction brought us about 100 dump truck loads of near perfect dirt. Can't wait to get it up and going. First phase is a pump n jump with a full jump line skirting the side.
    DJ , Pump Track plans-img_0366.jpgDJ , Pump Track plans-img_0380.jpgDJ , Pump Track plans-img_0381.jpgDJ , Pump Track plans-img_1956.jpg
  88. #188
    nice !
    you probably already know this, but i'll say it for everyone's benefit regarding building with a Bobcat: if you get dirt delivered and it's dry throughout . . . it really helps to have someone spraying water while the bobcat is dumping dirt... you need dampness throughout the pile for it to pack down properly. you can't just move all the dirt with a bobcat and then water at the end and hope it soaks through. that will just create a crust on top that looks packed, but later it may crack in big chunks, since it hasn't binded to the dirt underneath. even best is when you shape and pack as you go. so you'd basically water and pack in layers, which is basically what road builders and house foundation builders do.
  89. #189
    YRG
    YRG is offline
    Feb 2012
    nice !
    Thank you for the tip. I would be surprised if dry was a problem since it's all under snow right now, but the well is right next to the track.
  90. #190
    Jan 2013
    So I have just read through this entire thread and there is a ton of useful information on here! Thanks to all the contributors!
    I notice in this thread most people have very small space...I have the opposite problem I live on seven acres of property want to devote about 4-5 acres to build an awsome pump/jump slash DJ spot. The only problen is the property only has one natuaral hill thats about 30' elevation change and don't know how to utilize the rest of the property.
    One big plus I have is we have a family excavtion business and I have acess to heavy equipment free of charge but am unsure how to use my space the best
    any help is apperciated.
  91. #191
    YRG
    YRG is offline
    Feb 2012
    Quote Originally Posted by 1533clydesdale View Post
    30 feet is plenty to get speed. Once you have it is easy to keep if the track is designed well. Flat can be an advantage is some ways.
  92. #192
    This might seem like an extreme amount of effort, but I think it's worth talking about the concept anyway.... When you have only one elevation on a piece of land, it means that once you go down it, you have to turn around and hike/crank back up the hill. It's worth considering creating an artificial elevation opposite the natural elevation so that when you go down one, across some flat then up the other side, not only do you have something to turn around on, you can also hang out there for a breather, then drop in off it to crank back up your hill.
    In skatepark design, skateboarders often use a "basin" design, which means that there is elevation around the perimeter, then you drop into the middle area to hit stuff like pyramids grind boxes etc. then you use your momentum to get up the other side of the basin. The same can apply in biking situations.
    If you ever ride at Valmont, you'll notice the slopestyle hill . . . You hike up it, ride down... then have to hike up it again.
    Considering that they made several artifical elevations there, I'm a little surprised they didn't build a "turn-around" hill for the slopestyle lines....
    See how they created an artifical elevation with a platform to start from here:
    One year at Crankworx, they built a quarter pipe at the end of the runs. Besides being a cool thing to hit, it also operated as an artificial elevation that allowed riders to re-gain some gravity momentum to turn around and go back up to the top of the course.
    All this said.... even though you have a lot of space and access to heavy equipment, I advise just building one section or even just one jump at a time. Moving the dirt is only part of it. Shaping and packing takes just as much if not more effort. You want to build your lines progressively. If you try to lay out the whole track in the beginning, you can easily make mistakes on spacing and gap distances and have to rebuild stuff.
    This spot, my friend Abel primarily built with help from a lot of our crew.
    Allied Compound -- End of the World Jam - January 2012 He decided that down-gradient run was fine, without the turnaround aspect that I've been talking about.
    If you watch this video, you can kinda see the how the layout works. You end up at a lower elevation.
    Jumps heading downgradient can be fun though, because you get the opportunity for step-downs like this:
    Dual-slalom and 4-cross tracks tend to side-wind down a hillside.
    http://dirtdivas.files.wordpress.com...19_ddrf8-o.jpg
    heh, there's a lot to think about...
  93. #193
    YRG
    YRG is offline
    Feb 2012
    Little help please
    Got a question. I would like to put in a bmx style line (or 2) of rollers, step up rollers, and rollers with tables. (look at the 3 pics I took out of a vid). It appears the rollers are raised up from the rest of the track. Why is that? I would also like to know about spacing and height so we can have something fast (come in with speed and leave with maybe even more). Been reading as much as I can but would appreciate some input on this one particular aspect. Pulled the pics from here.
    Anyone shed some light as to why the rollers stay mostly above the bottom of the track?
    What is a good size, radius, and spacing for fast?
    DJ , Pump Track plans-bmx_roller.jpgDJ , Pump Track plans-bmx_rollers_with_table.jpgDJ , Pump Track plans-bmx_stepup_roller.jpg
  94. #194
    I'm glad you posted that. That spot is an EXCELLENT example of a bmx-racer-designed-and-focused pump track.
    Now watch this: Stowe Bike Park Pump Track - YouTube . Note the different style of riding. At the Stowe pump track, the rider keeps both wheels on the ground and does full-bike pumps...wheelbase up, wheelbase over, wheelbase down. It is more like surfing dirt waves.....
    The BMX race version is a lot more technical. Notice how he mostly manuals.... I love the BMX race style because you get to work on different skills like multiple roller manualing, pre-manualing (where you manual on the flat then press the nose down on the backside of a roller), speed-jumping roller sets, etc. The reason there are raised roller sets, is to add fun and difficulty of having more up-and-down elevation on an area that is otherwise flat; the other reason is that it provides more technical challenge--you have to double-up-manual and double-down-manual etc.
    I like to mix both these styles in my designs. Sometimes the rollers on BMX race tracks can be too peaky. I think this comes from the unique history of BMX tracks, where, like in motocross, the "whoop-de-doo" section was not designed to generate speed or be smooth, it was designed to mess you up !! The idea was to get through it with technical skill and not get bucked. Gradually the "whoops" were mellowed out into rollers that flowed better. BMX racers got really good at pressing the nose into the backsides and creating pump. But still, the idea was not exactly the same as full-bike "wave" pumping. Mixing the two styles together is an art form.
    The key design principle with rollers is "less is more." If it looks awesome/sweet/killer, it is probably too much (i.e. too peaky/too abrupt/too spine-ish/too speedbump-ish) !! MELLOW them out. I personally believe 10 foot peak to peak is a minimum distance, 11 seems to be great for slower speeds, 13 works awesome for general riding, and 15+ works well for relatively faster trails. Forget about speed bumps and think about waves. (However, if you want gap-able sets of rollers then pair them up... a set that is 7-9 foot spaced, then 11-13 foot bowl, then 7 foot again etc. You will then gap every short set. Multiple-gapping of evenly spaced rollers is a skill that expert and pro BMX racers have down, but is actually pretty tough.
    This is a shot from 4 1/2 years ago at my spot. They start close together and small and gradually get more stretched out and elongated:
    I did this drawing to illustrate domed-over rollers rather than peaky rollers. I'm not saying rollers have to be exactly to this design--there are LOTS of ways to do it, and tons of shapes are rideable. I'm trying to help/educate y'all to design ideas, not to provide one-size-fits-all plans ! Think about and experiment with your shapes... pack them in, ride them, change them . . . this sport is about creativity. It's not about cookie-cutter ! ! Nothing gets me stoked more than a new tweak to rideable landscape!
  95. #195
    YRG
    YRG is offline
    Feb 2012
    cmc4130 Thanks!
    I like the comment on creativity. What a great feeling having a blank canvas. I am looking to incorporate aspects from the "surf" style, bmx style and dj into one track. So the competition pump tracks (sea otter etc), bmx tracks and dirt jumps along with this thread are the source for ideas.
    I have a follow up question about your statement "one jump at a time", I've been getting mixed advice that falls into two camps.
    1) build a piece, then build the next so they flow
    2) lay out the design so that spacing and radii are consistent and go
    It seems that (in general) dirt jumpers favor the first school and pump track and trail builders favor the second. Since radius and flow are so critical in a pump track, I am leaning towards the second, but I hear you advocating the first. Could you please elaborate???
  96. #196
    pnj
    pnj is offline
    Dec 2008
    cmc is on point with his advice.
    as for your 1) and 2) ideas, I see them as the same idea. Layout the track but BUILD each thing/pump/jump/etc one at a time. Start at the beginning and work your way towards the end.
    it's ok if your layout changes a bit but DO NOT draw your design and randomly put the pumps in. I've seen tracks that had a good layout but were built with a 'work party' where 50 different people built the track. So the first jump didn't set you up well for the second and so forth.
    Also, remember that it is dirt so it's easy to change/fix. and as your skills increase you'll find ways to change the track. There is no perfect track.
    If you're in the NW part of the USA, I'd be happy to come help.
  97. #197
    YRG
    YRG is offline
    Feb 2012
    I was hoping for that kind of answer. Start with a design and then build one at a time and check for flow. Thanks for the offer. We are in Park City so if you find yourself out this way shoot a message and come ride
  98. #198
    anyone in the DE/PA/MD area who has built one of these? Looking to put one on my property and would love to see any local examples.
    Great thread
  99. #199
    Hey sorry if I missed this, but I looked through the thread a couple times but didn't see anything that addressed jump size and spacing when going down hill. A group of us are working with the city of Cottage Grove MN to build a bike park and the area we are working with has a 5% natural Grade loss as well we will put probably a 6ft tall starting hill for the jumps. The jump line we have around 400 linear feet to work with. I am looking for input on the spacing and jump size. We are looking to do more of the big step up style jumps and are really going for more of the lofty competition style jumps over the tight trail rhythm style jumps but not extremely huge so how far peak to peak for the jumps, how tall should the lip be to the landing and how far would you all recommend between jumps?
  100. #200
    I'm thinking kind of like the last jump in this video but smaller Martin Söderström and Xavi Pasamonte at Morrilla trails - Just for fun - YouTube
    dose like a 4ft lip and 7 ft landing with maybe 5-6 ft peak to peak seem appropriate for the first jumps in the line of probably 5-6?
    and this is the general lay out for the park that has been approved
    there will be a entrance/chill area, that box in the top right of the picture then a return line to get too the top and then a 4x track about 850-900 linear foot long, then that is the big jump line just below that, below that on the picture is the medium and small jump lines side by side and then the big box will be the MTB skills area, drops/skinnies/rocks that stuff. then on the right side will be 2 pump tracks and a tot track, the shapes of the pump tracks were hard to cad so we just put basics in there. they will be way cooler then that when done.
    here is a link to the FB page for this park https://www.facebook.com/pages/Cotta...96908407004866
    and here is the link to the park we built last summer, just a couple things to finish and that is located in Eagan MN
    https://www.facebook.com/pages/Eagan...77695292318263
    thanks for your help. We've never built a jump line with a down hill with that much grade loss
Page 2 of 4 FirstFirst 1234 LastLast
Members who have read this thread: 22
