Results 1 to 14 of 14
    Reputation: L3ONNOEL's Avatar
    May 2012
    DJ for $800 and under
    Im still looking for a bike, thats not a single speed and has similar specs to these and under $800. These are from the Avanti Derelikt type 3 2008 which is $799
    Frame: ADT 7005 FT Alloy w/ Adjustable Disc Dropouts
    Fork: Marzocchi Dirt Jump 3, 100mm travel, 20mm Thru Axle
    Front Derailleur: FSA Gravity Guide
    Rear Derailleur: SRAM X-7
    Brake Levers: Avid Juicy-3 Hydraulic Disc
    Shifters: SRAM X7 Trigger 9 Speed w/ Shimano Outer Casing
    Crankset: Truvativ Ruktion 1.0 w/ 36T Chainring, Galvanized Colour
    Brakes: Avid Juicy-3 Hydraulic Disc
    Hubs: Alloy Sealed Bearing 6-Bolt Disc, 20mm Thru Axle Front, Ano Colour
    Cassette: SRAM PG-950 11-32T 9-Speed
    Handlebar: Truvativ Hussefelt Riser 31.8mm, White Colour
    Grips: Dual Density ABD w/ Flange
    Handlebar Stem: Truvativ Hussefelt 31.8mm, Galvanized Colour
    Pedals: Alloy Platform w/ Repl Pins & Scratch plate, Sealed Bearings
    Rims/Wheel Set: Sun Ditch Witch
    Spokes: DT Stainless Steel
    Tyres: Kenda Krad 2.3
    Saddle: ABD Slim-Lite
    Seat Post: Alloy Micro Adjust 31.6mm
    Bottom Bracket: Truvativ Howitzer Splined
    Headset: FPD STS-2K Ahead 1-1/8" w/ Avanti Top Cap, Anodized Colour
    Chain: Shimano HG53
    Sizes: Short/Long
    Reputation: Endothermic Cavewalker's Avatar
    Take a look over here Mountain bike news, photos, videos and events - Pinkbike under the buy and sell. You will find a nicer used bike for $800 or less then you would looking for a new bike.
    May 2012
    Thanks, i had a look but sadly they don't have much in Australia
    Reputation: cmc4130's Avatar
    Quote Originally Posted by L3ONNOEL View Post
    So what happened? That Avanti is not available either? Or you just want to compare to other bikes?
    You're basically not going to get a new good brand geared dirt jumper with quality fork and parts for under $800. You could get a used one though.
    Here's the Trek Ticket, MSRP $1260:
    Ticket Exchange - Trek Bicycle
    2012 Giant STP -- $1600 approx
    STP (2012) - Bikes | Giant Bicycles | United States
    Comencal Absolut AL
    ABSOLUT AL
    Commencal Absolut AL Hardtail Bike 2012 | Buy Online | ChainReactionCycles.com
    how about this:
    felt straight shot dirt jumper - Pinkbike
    The Giant STP cost that much in the U.S.?! $1459 here in Canada.
    May 2012
    Quote Originally Posted by cmc4130 View Post
    Comencal Absolut AL
    ABSOLUT AL
    It's ok I found a giant stp0 2010 for $575
    May 2012
    Thanks again but I live in Melbourne, so that's way to far. But I found a bike already DDDDD
    *B*
    *B* is offline
    Reputation: *B*'s Avatar
    Quote Originally Posted by Endothermic Cavewalker View Post
    yup... they are not cheap. I paid $900 for my 2007 new. I really like my 2012 STP but it is pricey. 1600 is retail, you can get one for 1400 cash all day.... if ones available
    May 2012
    Its second hand and from Australia if you are talking about the link i gave. I managed to get it cheaper now
    did you notice that the FELT link i posted is in Australia ?
    May 2012
    The felt is from Hobart which is in Tasmania
    May 2012
    I got myself the 08 Derelikt type 2 with a 2011 abd frame 2nd hand for $600 NZL, similar specs to what you were looking at in basically new condition so yeah I'd say go for 2nd hand but maybe check it out first and also tighten everything. Managed to snap the crank shaft off on mine because i didn't tighten it but was an easy fix.
    May 2012
    Quote Originally Posted by Patrick16 View Post
    Thats pretty sweer
