Results 1 to 32 of 32
    AW_
    AW_ is offline
    locked - time out
    Reputation: AW_'s Avatar
    Cranks, bmx style compact chainrings
    Talk to me about cranks. I'm building up a singlespeed steel hardtail w/ 26" wheels for dj / urban / long distance skidding / occasional fr trails in the winter / etc. I have pretty much all the parts I need for the build except for the drivetrain.
    I am thinking I should go with a set of BMX style cranks for durability and the option to run a chainring smaller than 32t. However, I am really happy with my Saints, and they are being sold at blowout prices lately so I could always pick up another set.
    Profiles are kind of expensive, especially for euro BB. Are they just sticking it to the MTBers or what? What about these other cranks? Any brands I should avoid? I want something durable.
    Eastern 720
    http://www.danscomp.com/451025.php?cat=PARTS
    FSA Nasty Boy
    http://www.danscomp.com/451029.php?cat=PARTS
    Gearing... 34:16 felt good on previous bikes, that comes up to 56.1 gear inches.
    30:14 = 56.6 gear inches, sounds about right. Any recommendations on chainrings to use or avoid?
    THANKS!
    Meh.
    Reputation: XSL_WiLL's Avatar
    The Nasty Boys are pretty nice. I cracked my Profiles. Not saying that they're a bad product (they probably cracked because of missed grinds).
    Tree chainwheels are awesome. I like the Animal Lite V2s as well.
    i have the nasty boys on my dj/street bike and love them....had hussefelts on there before and the nasty boys are SO much stiffer...they get my vote
    Only One Way
    Sep 2004
    I love the micro drive setup I run, I use Deity but they are not cheep eather, A friend uses the FSA nad has no issues. I run a 25 / 14 and I have an 11 also, depends on the place I am at.
    I use the animal lite and it works well
    AW_
    AW_ is offline
    locked - time out
    Quote Originally Posted by MT Road
    What size wheels are you using with that gearing? What type of riding?
    Jun 2005
    search ebay high and low.. i got my profiles NEW with euro bb and the hop up kit for $150 shipped
    AW_
    AW_ is offline
    locked - time out
    Quote Originally Posted by fiddy_ryder
    Are the Profiles any better than FSA or Eastern?
    mtbr remember
    Reputation: BikeSATORI's Avatar
    if you are going BMX chromo cranks, make sure it has a 48spline spindle/crank interface = Profile / Wethepeople Royal / Odyssey 41thermal / some FSA / Deity / others...
    But, right now, my number one recommendation is by far, is the Odyssey WOMBOLT! Those are sick and LIGHT. not to mention, you don't have to use excessive amounts of threadlock/tape, or keep retightening, since these have a special wedge built in to keep it tight and only bolt on from 1 point anyway, therefore simplifying and losing weight. You can hardly find a pro out there that doesn't have these cranks on their bike.
    slightly pricy, but comparable to some profile set-ups and these are already lighter than the set-up with a Ti spindle (which is waay expensive). they take a 22mm euro bb, instead of the slightly more common 19mm.
    or if you have fat pockets, the Eastern Ti cranks, haha...
    oh I forgot to mention a couple of other options, which I've never seen in person, but look promising, are the Atomlab chromo cranks that use a Saint style external bearing cups, I think DMR has a version as well.... no idea on price or weight though.
    and I also currently run 28/12 X 24 = 56... but thinking of going 25/11 = 54.5 when the new tree lite hits.
    Schralp it Heavy.
    Reputation: cummings's Avatar
    May 2005
    Is that how you get your "gear inches #"? front ring divided by back cog, times wheel size?
    AW_
    AW_ is offline
    locked - time out
    Quote Originally Posted by cummings
    Yes...
    mtbr remember
    yep, basically... of course, your tire's outer diameter/volume will effect this slightly, as well as feel will be different with various crank arm lengths....
    I think it's easier this way compared to, well hey, some start at 2:1, so I'll try a little more, or a little less... that also gets complex and lost with 24" wheels...
    most current street mtb (micro-drives) are still based on approx. the bmx common usual of 55"
    Schralp it Heavy.
    AW_
    AW_ is offline
    locked - time out
    Quote Originally Posted by Merkyworks
    I am leaning towards the nasty boys simply because they are named after the Janet Jackson song of that title.
    Rollin' twenties.
    http://www.danscomp.com/453003.php?cat=PARTS
    i like those
    or sell your car and buy the ti's
    May 2005
    Quote Originally Posted by BikeSATORI
    I know I wouldnt use the same ration on 26 going to 24 (2:1) but would I use the the same gear inch? Like 32:16 (2:1 ratio) on 26" is a 52 Gear Inch. would I look for to find a cog/chainwheel with close to the same Gear Inch as 52 when I switch to 24" to get the same feel? (like 25:12 on 24"S is 50 gear inch)
    Only One Way
    Sep 2004
    26..
    Quote Originally Posted by AW_
    I run a 26 X 2.35 Tire
    Gearing is a 25 up front, and either an 11 (59 inch gear) or 14 (46 inch gear)
    I use the 11 at the DJ, I want to get a bunch of spead before I hit anything and after the first jump I am pretty much coasting anyway. At one skate park in town (6th avenue) I use the 11 because of the size and I like to take an outer line that hits a big wall ride and a nice quarter spine bowl type line - I use the 14 when I an on an Urban ride, when I get on something skinnie I like the gearing better for control and quick bursts of speed.
    I have posted before but here is a pic of the bike..
    AW_
    AW_ is offline
    locked - time out
    Quote Originally Posted by aggiebiker
    i like those
    Dude those are unicycle cranks.
    dirt rules
    Reputation: sittingduck's Avatar
    Apr 2005
    I have the nasty boy cranks with a 25T mosh guard sprocket on my STP, they are awesome.
    Rollin' twenties.
    ive been lookin at bmxs and noticed the completes that come w/ micro gearing typicaly are more expensive, whats the deal with that? is this a total newb queston?
    Rollin' twenties.
    what the crap those come STOCK on 2hip platboi's
    why the heck do you think there uni cranks? primos a BMX company
    its because the hub is more expensive
    Only One Way
    Sep 2004
    its all in the hub
    They use a hub wwith a casette much like a MTB only it holds one or two cogs only. the old style used a cheaper thread on freewheel. The new style is stronger and more reliable while offering gretter gear ranges
    AW_
    AW_ is offline
    locked - time out
    Primo started out making Unis. Check that unicycle video in the other thread, that one dude is running these same exact cranks.
    wow i can't belive what profiles are going for now i got mine for $100 back when i rode my bmx and just got a euro conversion from a friend for free. but wow 150 for the cranks isn't worth it. just get any 48 spline chromo crank. I love my profiles to death and have had the same set for 7 years now so you can't go wrong with them either. plus their warranty is top notch
    USB Rep'n
    Reputation: namaSSte's Avatar
    Quote Originally Posted by sittingduck
    been running the Nasty Boys for a few years myself and no problems whatsoever. Cheap and strong. Gearing wise, I run 25x11 with 24's rollin.
    though hope is frail, it must prevail - Taj Weekes
    betam eh-wud-eh-HA-lehu y
    eh-nay Ityopia!
    May 2005
    Anybody???? Just wanna know if I look for the same gear inch on 24 as 26, or if not the same, what gear inch on 24"s would be closest to a 52 gear inch on 26"s?
    Please, if you know, help me out, thanks.
    AW_
    AW_ is offline
    locked - time out
    Dude who is asking about gear inches 24 vs 26... go here: http://www.sheldonbrown.com/gears/
    Jun 2005
    Quote Originally Posted by boyfromthelak
    $150 is a steal for the cranks and euro BB.. they usually run $200....
    mtbr remember
    gear inch is universal for any, as long as you add tire size into the equation 20, 24, 26, 29, etc., that is the entire point. Use a calculator and some trial and error... 26/12
    Schralp it Heavy.
    Local Paperboy Hero
    Reputation: Cru Jones's Avatar
    I think I asked this before, but didn't get any feedback. Does anybody have experience with Odyssey Wombolt BMX cranks??? Would there be a problem with putting them on a mountain bike because they have an integrated spindle? So, the spindle is set at a fixed width for a BMX bike BB (whatever that is, there are different widths, right?). I've heard the 22mm spindle kind of sucks for euro BBs because you have to use thin bearings, but I plan on using them with a Spanish BB. Any thoughts???
    yeah i noticed i accidently posted the price for the american bottom bracket version. but that is still 50 bucks more then i spent 7 years ago on mine. plus if you buy like profile arms and spindle there are plenty of conversion bottom brackets to be had in the $30 range. and if you can find the arms and spindle for around 100 bucks you can get a pretty good deal on a bullet proff set of cranks
    Rollin' twenties.
    that in no way makes them uni cranks
    Local Paperboy Hero
    Quote Originally Posted by Cru Jones
    Oh crap, maybe I should read the whole thread before I post. Thanks for your input on the Wombolts BikeSATORI. But, what about the BB width??? Can someone drop a lesson for me. Do all euro BBs have the same width? BMX or MTB?
