Results 1 to 3 of 3
    pnj
    pnj is offline
    Dec 2008
    Couple of STP frame questions
    Does anyone know if the single speed version of the STP can be set up with gears? I'm guessing it's as simple as getting a new derailer hanger?
    Also, is it possible to set that frame up with a front chain guide? it looks like the single speed version of the STP doesn't come with guides on the BB for a chain guide..
    thanks.
    Reputation: off_road's Avatar
    Ya the frame of the SS STP is exactly the same as the geared frame so its just a matter of swapping the components.
    You may need a new rear hub becuase I think giant put a ss hub on the ss version. The frames are identical though. That is why giant sells bikes cheaper than other companies.
    Karate Kid 3 changed my life.
