Results 1 to 20 of 20
    Converting bmx hubs for 135 mm?
    Is it even possible?
    One idea of mine was to take the axle outta the hub, put a 135mm axle inside and use spacers fron an old cassette or something.
    If my method doesn't work, please explain how it works.
    Thanks dudes,
    Reputation: ServeEm's Avatar
    Jun 2005
    I see your logic in this, the only things that come to mind or question is, Could you find an axle that's 135mm and compatible with your bmx hub? I couldn't see an axle out there that would be compatible. The other is is chain alignment possible with the spacing method you have in mind? To align the chain would possibly require you to shift the whole wheel either to the left a tad or right a tad so the wheel wouldn't be physically centered in the stays making brakes more difficult, right?
    I see what you mean, but if you've got a BMX hib with a 14 mm axle, and a bike with a 14 mm axle, it shoudn't be a problem right? Also, using spacers you put the equal amount of spacers on each side so it stays centered.
    Correct me if im wrong! I'm only a junior hehe
    You could mill flats on the 14mm axle. That is how Husky made axles on their dirtbikes.
    mtbr remember
    Reputation: BikeSATORI's Avatar
    chainline will be funktified. It's been done, but not to a satisfaction level I'd be happy with.
    why would you want to do this anyway? Score a Nashbar SS hub if you're light on the coinage. Do you have disc brakes?
    btw,what? Husqvarna milled flats on 14mm axles to mount on their dirtbikes? seriously, I knew those bikes had major maintenance problems, but didn't know it was that janky... ?
    Schralp it Heavy.
    ye dude I'm SUPER tight on cash...
    Thing is I dunno what to do if I cant find a Nashbar hub...I'm just getting prepared you know?heheh
    Thanks dudes!
    Quote Originally Posted by BikeSATORI
    about the nashbar ss hub. in order to get it to line up right in the frame it must be dished properly, right? since most/all (clueless about this really) 135 spaced frames are offset for casettes?
    pretty sure the nasbar builds a 0 offset wheel where as normal hubs are offset correct me if im wrong
    Oct 2007
    I think that bmx hubs will work just fine. Go ahead and use them all the time.
    I post too much.
    Reputation: snaky69's Avatar
    Mar 2005
    A singlespeed hub makes for a dishless wheel, so no, it has no offset therefore your wheel will sit dead center with equal spoke lengths on both sides.
    mtbr remember
    Quote Originally Posted by sealclubber
    an offset Frame is actually very rare.
    Can be found on the ridiculous P bikes, but other than that, most frames are dead center with the seat-tube, just 25mm (~1") wider than bmx bikes.
    The dish is to offset the rim/spokes to align with the centered chainstays, not to work with an offset frame for a cassette.
    Schralp it Heavy.
    and of course i have a p.1 lol.
    mtbr remember
    ouch. well, no worries really, just requires some more special attention when building/buying a wheelset.
    Schralp it Heavy.
    Schmeow Productions
    Reputation: JBsoxB's Avatar
    get a hadley SS... especially if you're tight for cash
    mtbr remember
    Quote Originally Posted by JBsoxB
    Hadley SS hub is cheap? hmmmm, haven't looked at the price lately, but I don't remember it being on the cheap side. Also, you cannot run micro-drive with one as far as I know.
    I'd say atomlab, or Eastern26 among others.
    Schralp it Heavy.
    ye dude but i really can't get anything over 70 or 80 dollars for 2 hubs plus shipping...
    thanks though!
    Husky axles were quite a bit larger, duh! The flats slid into the horz. drop outs. The axles were f**king bulletproof.
    A 14mm axle with flats will be a lot stronger than a 10mm axle with threads all around.
    Reputation: combatkimura's Avatar
    I want a 30mm axle with 9mm flats!
    DMR Revolver Hub $55.50 at ride-this.com
    Why do you need a front hub too?
    well...yeah, but I see that nashbar has all the stuff I need so no worries =)
    Just like BikeSATORI said, why do you want to change the hubs again?
