Results 1 to 14 of 14
    Reputation: bringdoom's Avatar
    chromoly vs aluminum
    I have a question. I went riding today with my buddy that just bought a chase. I have a ritual and thought it was a little heavy, then I rode his and its way lighter and I like that.
    I searched and couldnt come up with what Im looking for. Would I be better off selling my frame and getting something like a used p1, or looking for a lighter chromoly frame.
    Im 200lbs and a total noob jumping small stuff. I hear people saying aluminum will break but I dont jump big enough to do much damage. My bike is also running 24s and I totally liked his 26s better.
    On that note, anyone want to trade frames and bottom brakets, lol!
    I post too much.
    Reputation: snaky69's Avatar
    Mar 2005
    Both materials have their strengths and drawbacks.
    Aluminum:
    -Pros: for the same strength it will usually come lighter than it's steel brethren, much stiffer material(can be good or bad), does not corrode
    Cons: harder to weld, cannot be welded again if it cracks unless heat treated(6061 only, 7005 is fine), not as cush of a ride as steel, tends to catastrophically fail(can also crack or bend, crack is more likely)
    Steel(aka chromoly, it's all the same, it's a steel alloy)
    Pro: A more cush ride, tends to absorb and dampen vibration and shocks, tends to bend rather than break(though breakage can occur), it looks nicer on a frame IMO. easier to weld
    Cons: Will be slightly heavier no matter what, rusts
    Dude...some steel frames are up to 2 KG lighter than aluminium bikes. Take the GT Chucker, its 15,6 KG!!! fíng heavy compared to a...blk mrkt riot bike, which is chromo and weighs 12.5 KG... pretty light. Weight isn't so much of an issue since both are about the same, just depends on the price.
    it seems this subject comes up alot
    each frame has its limitations
    i imagine if you found a good aluminum frame it would last forever if you dont abuse it
    and the same with chromoly. if you dont abuse you bikes either would be fine
    but then again why get aluminum just because you think its lighter when there are plenty of chomoly frames that are lighter than some aluminum frames
    the atomlab gi is under 6 lbs and pretty reasonable price
    Reputation: el_chupo_'s Avatar
    Quote Originally Posted by -.---.-
    The build is what makes it heavy. What Snaky is saying is that for equal strength, steel is heavier than aluminum. You can build up any frame as heavy or as light as you need/want/can afford. This has nothing to do with frame weight, or if one should get steel or alum.
    Meh.
    Reputation: XSL_WiLL's Avatar
    Comparing built bike weights to one another is not a fair comparison unless both have identical builds. A complete bike's weight may not be any indication of the frame weight.
    Comparing two bikes that are also at rather different ends of the spectrum is also rather pointless.
    Aluminum does corrode. A thin layer of aluminum oxide forms but it does not corrode any further.
    Some cromo frames are heat treated. Re-welding will change the temper of the metal. It would need to be heat treated again. The same goes for aluminum.
    Im pretty sure my GT Chucker isn't 15 kgs! I will check it out though!
    I post too much.
    Mar 2005
    I miswrote that, I meant that aluminum does not corrode in a destructive manner, the thin layer of aluminum oxyde is actually harder and stronger than the rest, but once it's there, the oxydation does not go any further, whereas steel will, in time, rust all the way through.
    Reputation: the_godfather's Avatar
    it is f**king heavy though. really really heavy
    i ride my bi*ch hard
    cost is a matter. Im thinking a p1 frame compared to my ritual. Im thinking about just doing what I can with components while giving my current frame a slight thrashing. Eventually Ill get a lighter chromo like a top or such.
    Reputation: trevorh's Avatar
    The top is considered one of the more heavier steel frames isn't it? 6.5lbs or something like that.
    woooooooooo
    Quote Originally Posted by the_godfather
    yup, but still too light for my liking..
    Quote Originally Posted by trevorh
    hmm maybe not, it does look clean tough.
    mtbr remember
    Reputation: BikeSATORI's Avatar
    steel can take more direct impacts and grindage than aluminum.
    I don't like the chase.
    Schralp it Heavy.
