Results 1 to 15 of 15
    Dec 2005
    Cable threading for barspins
    What's the name of that thing that you use so that you can thread your front brake line through the headtube? It's some kind of hollow bolt or something but I can't remember what it's called...
    Premium Member
    Reputation: Ojai Bicyclist's Avatar
    A hollow headset preload bolt. I don't think there's a special name for it.
    CURB HUCK!!!!!!
    Sst Oryg?
    Kona Coiler
    Premium Member
    No, that's for the rear. He's talking about the hollow bolt that goes ontop of your stem.
    Soviet, check your LBS or a close BMX shop.
    tuck-n-roll master
    Reputation: pavement_hurts's Avatar
    Quote Originally Posted by sovietspyguy
    Perhaps one of these?
    Premium Member
    $13?!?!?!
    Reputation: mrbray101's Avatar
    are you talking about a detangler type thing? so you can spin the bar without the cables getting twisted? I think you can pick them up for fairly cheap.
    Jesus Freak
    Quote Originally Posted by mrbray101
    The detangler is for a rear brake.
    He's needing a hollow bolt for the "end cap" that goes on the top of the steer tube. It allows the front brake cable to be routed down through the top of the steer tube and out at the bottom of the steer tube, routed down the fork leg and to the brake.
    Go to a LBS that sales BMX parts. They should be able to help.
    The correct technical term is "Potts Mod". Named after the BMXer that first did it. Chris Potts. Readily available from any LBS/mailorder that does BMX.
    HB - The God Damn Flying Dutchman
    Chicago Freeride
    Elgin, IL
    I picked one up from a LBS for about $6 a year or so ago.
    Reputation: ServeEm's Avatar
    Jun 2005
    I heard it called a star nut even tho it's a bolt. $13 seems a bit steep.
    Dec 2005
    Quote Originally Posted by ServeEm
    I presume you do need a new star nut as well?
    Jesus Freak
    Possibly.
    The star nut is what that bolt threads into. If the bolt has a larger diameter then yep, new star nut would be required.
    tuck-n-roll master
    C'mon people, all of the crap you need is in the link I posted. Geez...
    Jesus Freak
    Quote Originally Posted by pavement_hurts
    Point taken...The link way up at the start has all you need.
