Results 1 to 2 of 2
Thread: Buy or not?
    Reputation: L3ONNOEL's Avatar
    May 2012
    Buy or not?
    I've finally found a real cheap Avanti Derelikt, but would the components keep breaking adding more to the cost? The frame might be the model which had a recall because it snapped, which hopefully would mean i could get it replaced with a new 2011 ABD Flow frame. Im willing to spend $200-$300 dollars on it if anything should be upgraded.
    Avanti Derelikt Type three with aftermarket items | Bicycles | Gumtree Australia Boroondara Area - Balwyn
    May 2012
    Make sure you can get the frame replaced or if it already has it, otherwise it should be fine component wise, just make sure you tighten everything/ get it checked over at a bike shop first. Then go ahead haha ive got an 08 type 2 just bought this year and its holding up great and has the abd flow frame. Good luck
