Results 1 to 8 of 8
Thread: bmx hubs
    bmx hubs
    hey ive been having trouble with the rear hub om my haro sx 24 and ive been wanting to run smaller gears than the 41 18 on it now and ive got a bmx hub with a 8t driver on it so im wondering what size sprocket would work best with that on a cruiser or should i just get a new hub with a bigger driver and buy a bigger sprocket
    I post too much.
    Reputation: snaky69's Avatar
    Mar 2005
    Clicketh the linky in my siggy. All you need to know about gear ratios is there.
    buy the hub a 11 tooth driver and get a 25 tooth sprocket and you'll be good to go for your curent gear ratio
    oh i completely forgot i think i got what i need to know
    mtbr remember
    Reputation: BikeSATORI's Avatar
    you'll be running some SUPER micro drive with that. 8t is typical of flatland and some street riders... and that is with 20" wheels.
    Schralp it Heavy.
    i think id go with a 23t sprocket
    ive never really run anything smaller than a 13t on the rear and i was wondering with that small of a sprocket can you still get good speed
    I post too much.
    Mar 2005
    Quote Originally Posted by Formerbmx37
    Yep, the ratio is what matters.
    23:8 is going to be a significantly harder ratio then your current one . As long as your legs can push it then i say go for it otherwise you will most likely end up going slower because you can not crank hard enough
