Results 1 to 11 of 11
    Bmx Help Please?
    Hi
    Need a bmx for -160
    have found 1 that looks good from Local store(big one with webbie) 159.99 save 130 w0w
    Looking to DJ,Go to skate parc & commute with friends
    Nirve Flight Bike (2005)
    Mid-level Trails bike with a full 100% Cro-mo frame, Alex rims, Maxxis tyres and a 3pc crankset. A very high spec. machine at this price.
    New 4130 Cro-mo Trail frame
    Hi-ten Trail forks w/6mm dropouts
    New Tubular 3pc Cro-mo cranks
    Nirve alloy Drop stem
    CNC'd 39T sprocket
    14T Freewheel
    Tektro brakes (FX-15 U-brake on rear)
    Hi-ten 2pc Trail bars
    Nirve alloy hubs w/14mm axles & sealed bearings
    Alex MX-22 48h rims
    Maxxis MaxxDaddy 2.0 tyres
    Aluminum Platform pedals
    Cro-mo Micro-Adjust seatpost
    Nirve chain tensioner
    Nirve rear hub grind protector
    Oryg detangler
    1 pair of pegs
    Braided cables
    Colour: Matt Tan
    www.winstanleysbmx.com go on bikes then nirve an youll see it
    Help!
    Please c;mon
    To "Air" Is Human
    Reputation: The Agency's Avatar
    Jun 2005
    So...$302~. That Nirve is on target as far as price with a Haro Nyquist One or an Eastern Traildigger. The Nirve has a better frame and wheelset than other bikes of similar price. What is up with that front brake? Center clamp?
    Tires and frame sat they are trail oriented. I prefer a street geometry...that's just me. It's two years old and they need to move that sucker...go ride it and find out if you like the geometry.
    Thanks for that,
    But becouse it has trail geomitary will it still be usable and wont break at my gr8 local skateparc,
    Rhys
    I post too much.
    Reputation: snaky69's Avatar
    Mar 2005
    A bmx frame is pretty hard to break. You can trail ride or skatepark ride anything if you try hard enough. But having the right tool for the job is where it's at. If you will be riding more trails, go for it, if you'll be riding more skatepark, maybe look elsewhere.
    Rollin' twenties.
    dang it, euros and tires spelled wrong,
    i have no idea how much euros maks how many dollars so im not even gonna try, all i no is that that nirve looks like crap
    Quote Originally Posted by aggiebiker
    1 more question?
    Can anyone define trails (do they include dirt jumps e.t.c)
    $305 But its Half Price it's meant to be $533,
    (P.S thanks for that other post (forgot your name))
    Thx
    To "Air" Is Human
    Jun 2005
    Helpful post...the prices are in British pounds not Euros. Speaking of spelling, know is spelled know not no.
    It is a deal for a dirt jumper. Most street/park frames have a higher center of gravity built in them with a higher bb. Even running a bigger chainring like a 39/14 or 36/13 the bottom bracket on a street frame will be less likely to hit dropping in. Add a 25/9 or 30/11 and you are even better off.
    Dirt jumpers have a lower center of gravity to help push you through the rhythms. Many dirt jumpers also are short in the toptube too. Trails = dirt jumping. The frame will hold up just fine in a skatepark, as stated by snaky69 "...having the right tool for the job is where it's at."
    Ok Wait!
    They Dont Have Any . What About Alone Intimate 159.99
    To "Air" Is Human
    Jun 2005
    On that site your best bet is the Stolen Getaway or the Goblin for 169.99. The Goblin is a little lighter but I don't know the size on either one. Good Luck.
    What Makes Them Better Than the alone one which is 10 cheaper?
