Results 1 to 6 of 6
    Argyle 318 question
    Got my Eastern Night Train earlier this week. The "manual" for the fork doesn't have a guide for setting the compression or rebound. Any hints on this? This is my first Rock Shox. I am used to Fox where they give you starting points in the manual.
    JayMac
    Rebound is on the bottom of the right stantion(small knob) and the compression is on the top. Rebound, can't remember which way to turn it but just mess around with it and find your preference. The compression turns clockwise to make it more rigid. All the way to the right is lockout.
    Reputation: rogbie's Avatar
    SRAM has their manuals online. Here are the manuals for the Argyle.
    yeah I went through them...same stuff that came with the fork.
    Well, I set mine up by turning the compression to lock out, then I backed it off two "clicks". As for rebound, ride the bike off a curb with your full weight on it. If the front wheel hops reduce the rebound. Trial and error worked for me.
    I run my fork fairly stiff with less rebound. I've found less rebound keeps the forks from rebounding as I pop off a lip, and the same with landings.
    Good luck.
    I always ran my 318 with compression turned all the way up..
    *edit* rebound all the way up, compression one click from lock
  1. Argyle 318
    By noobie39 in forum Shocks and Suspension
    Last Post: 02-27-2011, 10:24 AM
  2. Reba Uppers on Argyle Lowers/Argyle Internals
    By phoenixnr in forum Shocks and Suspension
    Last Post: 11-07-2010, 08:46 AM
  3. 08/09 Argyle Question
    By kitsapfreerider in forum Urban/DJ/Park
    Last Post: 11-03-2008, 08:37 PM
  4. argyle question
    By BIKESerFUN in forum Urban/DJ/Park
    Last Post: 12-26-2007, 07:00 PM
  5. To Pike or to Argyle... THAT is the question.
    By snaky69 in forum Urban/DJ/Park
    Last Post: 11-04-2006, 09:21 AM
