Results 1 to 7 of 7
    nOOb now rOOkie
    Reputation: Str8NoobYo's Avatar
    another nOOb question i need opinions!
    alrite well my cranks keep coming loose and im about to take them out and throw them into a F'in wall... but before i do that what are you guys running? do yours come loose? after 10mins of riding? im a heavy guy but damn.... help me out before i go insane!
    Use this space for what?
    Reputation: Cozza's Avatar
    Try blue loctite ?
    nOOb now rOOkie
    seriously? do you think it will work? i believe i "heard" that you dont want to use loctite on crank bolts?
    Meh.
    Reputation: XSL_WiLL's Avatar
    If you're hesitant to use loctite, wrap the threads in PTFE tape (plumber's tape). Then really torque them down, use an extension to get extra leverage if need be.
    What cranks do you have?
    Aug 2005
    Put some red loctite in. However, if your cranks are warped, time to replace them. My old truvativs were like that. The left one would fall off because the square becameb into a circle.
    pUt Da LiMe In Da CoKe YoU nUt
    nOOb now rOOkie
    i did the blue loctite tonight. its chillin right now, ill smash around on my bike in the morning and if it comes loose im getting rid of them.
    are the Diety cranks worth it?
    Reputation: free rider's Avatar
    i just did the same thing yesterday and it worlks great ( soo far)...i put it on my chainring bolts as well as me crank arms
