Results 1 to 3 of 3
    addictcycles rear derailluer woes
    anybody know what exactly I can use to hang the derailluer on this frame.Any information would be nice,thank you.
    Meh.
    Reputation: XSL_WiLL's Avatar
    You should've gotten a derailleur hanger with the frame. If not, go to the Addict webstore and order up a hanger. They added it to the frames section after I asked. They're cheap. The hanger bolts onto one of the sets of 2 holes on the bottom of the driveside dropout. The forward set is for when you run the wheel further forward, the rear set is for when you run the wheel further back.
    ah yes,that makes sense now.Thanks for the reply will.
