Results 1 to 6 of 6
    Reputation: Toasted BLT's Avatar
    3/32" or 1/8" drivetrain?
    Are you running a 3/32" or 1/8" drivetrain with you std mtb cassette rear hub converted to single speed?
    If 3/32", whose sprockets turn you crank?
    I was planning to run a 28T Black Market Revolver Lite, but the 28T are sold out until May. There just don't seem to be many other options out there for 3/32" sprockets. Thinking of switching to 1/8" to open the door on a lot more options.
    If 1/8", what cassette cogs turn you crank?
    Surley and Endless Bike have a lot of 3/32" cogs available for ss converted cassettes, but there don't seem to be too many options out ther for 1/8" cogs for converted mtb cassette rear hubs.
    go huck yourself
    Reputation: jimage's Avatar
    i run 1/8 on a rear cog off my old bmx and a bmx sprocket up front
    its so much stronger i never snap chains anymore and you can run half link
    Dirt jumps come and go, but dirt junkies will dig forever.
    Quote Originally Posted by jimage
    What brand BMX cog are you running? Do all the splined BMX cogs fit the standard Shimano 9sp cassette?
    Bikes Rule
    Reputation: Demo-9's Avatar
    Mar 2006
    If using a 8/9 speed with a spacer kit, definately use a 1/8" set-up if you can. Get something like a Mosh 1/8" cog or a Surly. Even though the Surly is a 3/32", the base is about 3 times thinker where it sits on the cassette spline. It will not rip apart the cassette like a standard 3/32" will over time.
    Quote Originally Posted by Demo-9
    If using a 8/9 speed with a spacer kit, definately use a 1/8" set-up if you can. Get something like a Mosh 1/8" cog or a Surly. Even thought eh Surly is a 3/32" the base is about 4 times thinker where it sits on the cassette spline. It will not rip apart the cassette like a standard 3/32" will over time.
    I have a Surly cog coming, but they only seem to make 3/32. Do they work well with a 1/8 chain and front sprocket?
    Where do you get your Mosh 1/8" cogs? I have been looking for a source, but have not found one yet.
    Thanks,
    Bikes Rule
    Mar 2006
    You can run a 1/8" chain on a 3/32" cog. I found the Mosh somewhere one day but an Odyssey is bascally the same.
    Here:
    http://www.danscomp.com/461059.php?cat=PARTS
