Results 1 to 2 of 2
    Feb 2013
    2013 GT La Bomba vs 2008 Giant STP Pro
    As the title states, 2013 GT La Bomba vs 2008 Giant STP Pro. I have the STP atm but not sure whether its an upgrade or not.
    Feb 2013
    Specs for GT
    FRAME Monocoque/Hydroformed XM Metalâ„¢ Frame (TT/DT,ST), Forged Bottom Bracket and Dropouts, 142 x 12mm Shimano E-Thru Dropouts, 1-1/8" to 1-1/2" Tapered Head Tube w/ TT and DT gussets.
    FORK Fox Racing Shox 32 Float 26 CTD QR15, 100mm Travel, Open Bath Damper, w/ Adjustable Rebound & Lockout, & Tapered Alloy Steerer
    CHAIN DEVICE  e.thirteen LS+ Guide
    CRANKSET Shimano Zee, FC-M640, w/ 36T Ring
    BOTTOM BRACKET Shimano Zee
    PEDALS GT Slim Line Flat Pedal, Cast Alloy, w/ Replaceable Pins
    DERAILLEUR (R) Shimano Zee Shadow Plus, RD-M640
    SHIFTERS Shimano Zee, SL-M640, Rapid Fire, Right Side Only
    REAR COGS Shimano CS-4600, 10-Speed, 11-25T
    CHAIN KMC X10
    RIMS Alex SX44, w/ Eyelets, 32H
    TYRES (F) Maxxis Highroller, 26"x2.35", Folding Bead, (R) Maxxis Highroller, 26"x2.10", Folding Bead
    FRONT HUB (F) All Terra Alloy Sealed Bearing Disc, 15 x 100mm Thru Axle, (R) Alloy Sealed Bearing Disc Cassette, 12x142mm Thru Axle
    SPOKES 14/15g DB Stainless
    NIPPLES Brass
    BRAKES (F) Formula RX, w/ 180mm Rotor, (R) Formula RX, w/ 160mm Rotor
    BRAKE LEVERS Formula RX
    HANDLEBARS Kore xcd, Double Butted AL6061, 710mm Width, 20mm Rise, 31.8mm Clamp
    STEM Kore Repute, 3D Forged, 50mm Length
    GRIPS GT Wings w/ Waffle Lock-on
    HEADSET Gravity DX Pro, Internal Alloy Upper ACB, External Alloy Lower 1.5" ACB
    SADDLE WTB Volt Race
    SEAT POST All Terra AL6061
    SEAT CLAMP All Terra Alloy QR
    STP Pro
    FRAME ALUXX alloy: double butted, integrated gusset w/CNC BB yoke
    FORK Rockshox Pike 454 Air U-Turn w/maxle
    REAR DERAILLEUR Shimano XT Shadow high normal 9 speed
    FRONT DERAILLEUR
    SHIFTERS Shimano Deore rapid fire 9 speed
    CRANKSET Shimano Saint Hollowtech II 34T
    BOTTOM BRACKET Shimano Saint integrated, outboard
    SHIFT/CHAIN GUIDE E-13 STS Chain Guide with custom bashguard
    CHAIN Shimano HG73 9speed
    CASSETTE SRAM PG970 11-23
    BRAKES Avid Juicy 5 hydraulic w/6" rotors
    BRAKE LEVERS Avid Juicy 5 hydraulic
    HUBS Fr: DT 370 20mm / Rr: DT 370 9speed cassette disc
    RIMS Mavic EX729 disc 26" x 32H welded w/eyelets
    SPOKES DT Swiss 14G stainless
    TYRES Maxxis Holly Roller 2.4"
    PEDALS Shimano DX (MX30) platform
    H.BAR/STEM Raceface Diablous 31.8mm low ris/ Raceface Diablous D2
    SEAT POST SDG I Beam 30.9 freestyle
    SADDLE SDG I Sky freestyle
    GRIPS Giant lock-on metal
    EXTRAS
