    Ugly As F*ck
    Reputation: uglyguy2's Avatar
    Jun 2012
    2009 Commencal Absolut CG
    I posted this in the Commencal forum and got no replies so trying here. Could use some opinions/info on this bike, looking at a used one to buy locally.
    Is 400 an ok price for this bike? Am I correct in saying this bike is aluminum? Disadvantages to an alloy dirt jumper?
    Thanks.
    Reputation: cmc4130's Avatar
    Quote Originally Posted by uglyguy2 View Post
    Thanks.
    Yes, that is a good buy. Probably a Comencal Max Max. There was a rigid fork version of that bike that was 700?? ish. But with a Mazarcochhi DJ fork, it bumps the value/price up by 250-350. So $400-$700 seems to be the going rate for used good quality DJ bikes.
    Check whether the frame is a Small, Medium, or Large.
    Ugly As F*ck
    Jun 2012
    It appears that it is this bike:2009 Commencal Absolut-CG - BikePedia
    Everything should be stock. Even down to the reflectors.
    Thanks.
    For reference I paid $600AUD a few years ago for a mint condition Absolut AL-1
    Due to a frame failure on my dual suspension bike that I'd just finished building up (doh!), I replaced the DJ-2 forks with 2011 Fox Vanillas (spring cut, spacers added to lower to 100mm) and it also has 2012 XT brakes and shimano rotors, which is total overkill but better and quieter than the noisy Juicy 3s.
    Spank rims are nice and strong, as does the frame, no problems aside from the ease at which paint chips. The orange is way brighter in real life than most photos, so I'm guessing the green might be too.
    The main thing I don't like about the bike is the rear setup, if you get a flat (which the kenda k-rads seem to like doing) you have to disassemble both the brake and mech to take the wheel off, then piss around getting everything dialed in again. Other than that I like it.
  1. Commencal Combi Disc 2009 - geometry
    By 22-34 in forum Commencal
    Last Post: 07-19-2014, 02:30 AM
  2. Commencal CG?
    By uglyguy2 in forum Commencal
    Last Post: 07-16-2013, 10:02 AM
  3. 2009 Commencal Supreme DH WCS??
    By gticlay in forum Commencal
    Last Post: 04-13-2012, 09:31 PM
  4. Commencal 'Green'?
    By lornibear in forum Commencal
    Last Post: 10-05-2011, 11:45 PM
  5. Commencal Meta 55 2009
    By italianbike74 in forum Commencal
    Last Post: 12-31-2010, 08:12 AM
