Results 1 to 6 of 6
    Roc
    Roc is offline
    Reputation: Roc's Avatar
    2008 Eastern Thunderbird frame with 14mm dropouts NEED HELP!
    I just picked up a 08 Eastern frame that runs 135mm x 14mm instead of 135mm x 10mm Does anyone have experience with 3/8 to 14mm adapters? What kind? or any other suggestions to help make this work? Thanks.
    buddy of mine has a Nighttrain with a 14mm frame and 10mm wheel. he has the adapters and they suck..they always loosen up. i would say get a wheel thats got a 14mm axle
    Roc
    Roc is offline
    Thanks. Sounds like the best way to go
    Reputation: cmc4130's Avatar
    There are different types of adapters. Some are just a step-up washer that goes in the dropout slot. I have used these and they work fine.
    Like this:
    Others are like a 1 1/2 inch hollow threaded tube that you thread over the 3/8" axle....
    Note that mtb hubs have 10mm axles , whereas bmx have 3/8" (which is 9.5mm), so the threading is not compatible.
    PROFILE AXLE ADAPTORS (3/8" TO 14mm)
    Roc
    Roc is offline
    My bad. I meant 10mm.
    Roc
    Roc is offline
    Do you have any good recommendations for a 14mm hub or even better a 14mm wheelset? If they exist?
  1. Looking for U.S. source for 14mm base XM-L?
    By adrenalnjunky in forum Lights DIY - Do It Yourself
    Last Post: 01-04-2013, 07:27 AM
  2. eastern thunderbird/ broke crank arm
    By mxrcr222 in forum Urban/DJ/Park
    Last Post: 08-31-2012, 02:43 PM
  3. Azonic wheels and 14mm dropouts HELP
    By Hoka Hey in forum Urban/DJ/Park
    Last Post: 09-05-2011, 09:54 AM
  4. Replies: 4
    Last Post: 01-19-2011, 05:53 AM
  5. Is a Eastern Slash 7 frame worth buying
    By Blacksugar in forum Downhill - Freeride
    Last Post: 01-08-2011, 05:56 PM
