Results 1 to 9 of 9
    Reputation: A Grove's Avatar
    Nov 2006
    14mm 135 spaced hubs?
    What all is out there in the way of 14mm axle'd 135 spaced hubs? Looking to run pegs but need to keep mountain spacing...
    Reputation: the_godfather's Avatar
    halo DJ
    DMR revolver
    i ride my bi*ch hard
    Nov 2006
    thanks..
    Currently am running a KHE giesha MTN. They make 14mm axel studs to convert to run with 14mil drops.. but I doubt they will take the added abuse from pegs. True or false?
    I post too much.
    Reputation: snaky69's Avatar
    Mar 2005
    Doesn't eastern make one as well?
    yes. eastern does make a 14mm hub as well.
    depends what you are going to be doing with your pegs. many BMX'ers still run 3/8ths on the front and they use pegs
    train gorilla
    Reputation: ---->SWERVE76<----'s Avatar
    Jun 2005
    Quote Originally Posted by A Grove
    thanks..
    The axle studs are the same for the bmx and mtb freecoasters. They'll hold up. Just have to watch for wheel slippage.
    The officer saw the words, "This Bike Is a Pipe Bomb" and became concerned.
    Nov 2007
    Does anyone know where to get the eastern one? I have my local shop pulling their hair out. The guy wants to build me a 3/8" wheel and give me some adapters.
    lbs should be able to order one in.
    if not google it or try and get it direct from eastern.
    Nov 2007
    Yeah, my shop has been trying to track one down. It's possible they don't exist, or are no longer made, and the website just hasn't been updated in a very long time.
    In related news, Halo SAS DJD rear wheel is available with a 14mm axle.
