Results 1 to 2 of 2
    X-Post..PUSH & Fox F-series full travel question...
    I know a lot of the 'Homers are experienced with PUSH and since this is for my Flux, I thought I would look to you for advice.
    I've got an '07 F100RLC and the seals just started to let go. I was going to switch forks as I've never gotten full travel (probably 80-85mm max) and really want the full travel. I know these are notorious for not getting the full travel that's advertised (thanks Fox, another great job there!) but was wondering if anyway knows if the PUSH service will let me get full travel? If so, do I need the HV upgrade? Just trying to decide where to spend the few $ I've got left in the bike budget.
    cut the rod that holds the airchamber piston in the left fork leg. I trimmed 12mm and redrilled
    the hole. it took less than an hour.. while I was at it, installed the enduro seals( lower stiction
    than oem seals) and replaced the stock oil with synthetic fork oil. give it a try and save yourself some $$$$$$ and get full travel
