Results 1 to 18 of 18
    nocturnal oblivion
    Reputation: stumblemumble's Avatar
    Mar 2006
    Would a BB shell mount roller guide work?
    For all of us without ISCG running 1x9 or 1x10, in need of a roller, and having screwed up chainlines.
    How about a basic lower roller just like the Blackspire Stinger except with a clamp around the BB shell? Give the BB shell/clamp surface a sticky rubber sleeve and cinch that sucker down.
    Maybe it'd rotate at times when hit, but if you have a bashguard sandwich the roller would stop at the bash and roll with it. No biggie, wouldn't pinch the chain.
    I'm ready to yank the Stinger from my 5 Spot. I even modified my 11-34 into an 8 speed narrow 12-34 spaced out from the hub. Works fine but I miss my 11t.
    Whaddya all think? Saar has the mill ready...
    "...like sex with the trail." - Boe
    back in the day...
    MRP used to use set screws to hold their pre-ISCG chainguides to the outside of the shell. Problem with that is the gouges left by the screws when they were rotated was ugly, but would not disable a bike. A radial clamp would be a much better idea, then it would be a light scratching instead of a few gouges if it was smacked on the ground.
    Te mortuo heres tibi sim?
    Quote Originally Posted by stumblemumble View Post
    Why not just use a regular BB mount Stinger? Fine tune the rest of the chain line if need be with other thin spacers there if you have to, and move the ring inboard on you crank, use some thin chain ring bolt spacers if need be. Cheap, easy, and unless your chain line is completely whacked, ought to work fine.
    It should be pretty easy to space things for your chain line off the front ring to line up right with the middle of the cassette, one way or another.
    If you need to, give the Stinger plate an S-bend curve if you need the roller more in or outboard, or a longer bolt/washer combo.
    Now with flavor!!
    Reputation: kidwoo's Avatar
    Yes a regularly used piece of equipment designed for exactly what you're looking for will work fine.
    STRAVA: Enabling dorks everywhere to get trails shut down........ all for the sake of a race on the internet.
    nocturnal oblivion
    Mar 2006
    Quote Originally Posted by turnerbikes View Post
    Especially not a problem for a raw frame.
    Quote Originally Posted by scrublover View Post
    ^^^Stinger is bent and lines up fine. The problem with doing spacers is that I run a BBG bash/inner plate sandwich.
    With the sandwich the bash would have to be moved to the inside of the spider, otherwise if the ring is moved in the gap to the ring is too big and the chain can jam.
    It'd be a bit of a pita to space the ring off the bash with the bash on the inside, then also space the inner plate off the granny posts.
    It may work and it'll be my next trial. It's curious though that no one has a shell clamp guide though, seems like a simple solution.
    Thanks for the help.
    Now with flavor!!
    What about a BB mount LG1 plus a bashguard?
    Do you really need to run two plates?
    nocturnal oblivion
    Mar 2006
    Quote Originally Posted by kidwoo View Post
    I'm trying to ditch the BB mount plate to better the chainline. It's pretty screwy with a BB mount in there, works good without it but I like having a roller.
    Now with flavor!!
    I guess I'm still not completely understanding your problem. A BB mounted chainguide is accounted for in most BB setups, both 68 and 73mm mm shells. 68mm/two spacers 73mm/one spacer OR a bb mounted chainguide. With the chainring in the 'middle' position, the bashguard on the 'outer' position, you're essentially getting the same 1x9 setup that existed on dh bikes for eons.
    What frame is this?
    nocturnal oblivion
    Mar 2006
    What frame is this?
    I hear you. It's a 2010 5 Spot.
    A lot of guys (myself included) found that the single spacer is best placed on the non-drive side. DT felt that this was the best place for it in a past thread as well. This setup works well, especially on a trail bike where the majority of time and a lot of pedaling force is spent in the 32t cog climbing.
    From what I remember the above setup gives a 5th cog mid-cassette line-up with the ring. That spacer (or guide mount) on the driveside throws it out just enough to be funky in the 32t cog.
    I get a continuous grinding noise on climbs from the (SS-specific Salsa) ring and the cassette.
    In the meantime like I mentioned I ditched the 11t cog and spaced the cassette out off the freehub giving me a narrow cassette with 8 speeds. It works but it sucks not having an 11t.
    I'm totally open for ideas though. A compromise would be to find a BB mount guide that's very thin, though I couldn't find any threads discussing that.
    Now with flavor!!
    Let me look at my chainline when I get home on my 5spot. I'm running a dual setup but with a just a bashguard and a stinger, I remember it setting up pretty well. No spacer on the nondrive side...
    Reputation: KRob's Avatar
    The Heim (?) BB mounted roller was made of stainless steel and was very thin. I had one on my 6.6 a few years back. Do they still makes those.
    I've seen the threads about where to put the spacer and decided to leave mine on the drive side as directed. Chainline seems fine. 32 x 34 is a bit extreme but doesn't grind. I find if I just let go of some of my ego, 22 x 30 or 22 x 28 is about he same gear inches and lines up better.
    GUIDANCE COUNSELOR
    Reputation: NoahColorado's Avatar
    I confused. Why don't you want to run a standard BB mount guide? Chainline?
    NOAH SEARS
    MRP
    TECH QUESTIONS HERE: INFO@MRPBIKE.COM
    Now with flavor!!
    2011 spot, XT cranks, no spacer either side, BB mounted stinger, dual ring setup.
    If I can do it with two rings, you can do it with one with any of several readily available single ring chainguides.
    I wouldn't be surprised if that grinding you're getting was from running two plates.
    nocturnal oblivion
    Mar 2006
    Thanks for the pic and you're right, some of it is from the sandwich, though the ring does grind the chain a bit on climbs. I went with the sandwich and stinger because of cost, I'll try spacing the bash inside the spider though I'm not excited about it.
    If anyone has input on the thinnest BB mount guide plate I'm all ears, I think the Stinger is a bit on the thick side even for aluminum.
    The Heim guide maker was bought up by MRP from what I recall and is no longer available.
    It'd be great to figure out a shell clamp setup and be done with it though.
    In the meantime Downieville this weekend...
    Reputation: jncarpenter's Avatar
    Haha...I still have one
    You never know...I may need it again one day
    Stinger is a whopping 2.5mm - same as a standard BB spacer. If using a bash, get on of these. or one of these and mate it up with a BB mounts Stinger. Get creative with some bolts and washers, and it'll work quite well.\
    If dead seat on nothing between your frame and BB, then why not just use a seat tube mounted guide? Paul, MRP, e.13, and a couple other companies have things that would work. They don't always play nicely with bash rings though.
    Heim was bought out by e.13 - and still made, just a different version than the old. Not sure on the thickness, but looks like it may be thinner than the Stinger.
    So here you go. Pair that up with one of the guide bits above and see what you can come up with.
    Or get a Paul seat tube mount guide, and hack off the outer bit so it'll play nicely with your outer bash, not mess up your chain line, and still do the job.
    Or go to a local machine shop and have them make you a thin steel Stinger clone, stick your own roller on it and go nuts.
    If none of those options appeal, then suck it up and
    get a BB mount Straitline, MRP, e.13, Gamut, etc. single ring guide setup. A bit over $100 if you shop around, and it won't screw up the chainline too much. Really.
    IMO, on a single ring trail bike setup, an upper guide bit like that sort of stuff is more important than a lower roller. Keeps the chain from bouncing off the top, and keeps it quieter. If you do it right, there is nowhere for the chain do derail to.
    Now with flavor!!
    Mostly........
    THIS VVVV
    ^^^^^^That right there^^^^^^^
    Seriously. This ain't rocket surgery.
    nocturnal oblivion
    Mar 2006
    At the risk of sounding like a tard I don't see where you're going with the links, the roller lines up fine and is not the problem. The idea is to just ditch the spacing on the driveside.
    The n-stop won't work due to the height of the interrupted seat tube, I assume the Paul is the same. The E13 XCX-ST and such don't allow a bash guard.
    The Stinger btw is 3mm on my calipers, I know it's not a lot but I wanted to know if there were other options.
    I appreciate the input fellas, not downplaying anyone's ideas.
    I'm going to give some thought to making a shell clamp setup, I wanted to make sure I wasn't missing the obvious (aside that it's not entirely necessary). I think it's a neat idea if it works.
    The fact is that a 53mm chainline up front is not optimal, getting it down to 50mm I think would be better for a bike that spends most it's time climbing.
    Moving the bash inboard of the spider looks to be a big leap, probably too much.
    A clamp on the shell with a flange for ISCG sounds simple enough if I had access to a mill I'd modify a BB/ISCG adaptor and give it a shot.
    Thanks for the input, short of finding one of those DT mentioned I'll probably have to live with it.
  1. Chain guide/roller for 1x7 set up
    By DirtyR in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-23-2011, 12:28 PM
  2. RaceFace cranks, 73mm BB shell and BB mount chain guide
    By Ray Lee in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-18-2010, 09:38 AM
  3. Chain Guide / Roller Guide & Bash Guard
    By double_a in forum Downhill - Freeride
    Last Post: 01-10-2005, 11:27 AM
  4. Roller Guide?
    By RyBread in forum Downhill - Freeride
    Last Post: 01-09-2005, 11:33 PM
  5. Will I need a roller guide when going to 2 X 9 ???
    By Mapkos13 in forum General Discussion
    Last Post: 08-24-2004, 10:59 AM
