Results 1 to 6 of 6
    wich spring for the fat guy?
    I weigh 240 pounds can anyone recomend me a spring weight to go with my new turner 5 spot with romic? I would rather have a plush comfortable ride than a stiff big hit ready ride. thanks guys
    I think that the leverage ration on the 5spot is 2.5:1. If that's the case, a 600# spring sounds just about right. That's not too big. My RFX came with a 750# spring ...but then again, it has a 3:1 leverage ratio.
    DGC
    DGC is offline
    Reputation: DGC's Avatar
    spring
    Quote Originally Posted by tony0643
    The chart for the 5 Spot calls for a #650 at your weight. The chart goes like this:
    200-220 pound rider #600 spring
    220-240 #650
    240-260 #700
    so if you want a plusher ride the #650 is the best choice, and still run at least few clicks of compression.
    sping for the fatty
    thank you guys that helped alot!
    for skinny guy?
    What will be the correct spring# for a 145 lbs skinny guy then? thanks
    Quote Originally Posted by Stephen7
    400# should work.
    145 pounds? You should just run the kind that come in ball point pens?
  1. 550 by 2.0 or 2.2?
    By Jaybo in forum Turner
    Last Post: 02-28-2004, 08:10 AM
  2. When a spring is not a spring
    By WarrGuru in forum Turner
    Last Post: 02-11-2004, 08:53 AM
