when to rebuild?
Printable View
  • 12-04-2012
    CharlieC
    when to rebuild?
    Hey folks,
    I have an '08 RFX that has seen steady use its whole life, along with good maintenance. The O rings on the main pivot (attached to the rocker arm) have started to stretch a bit, and I don't think they're providing a great seal anymore.
    If I take it apart to replace the O rings, any reason to not replace the bushings and zerk fittings while I'm in there? None of the pivots have any play or performance issues.
  • 12-04-2012
    saturnine
    if the bearings are fine, no reason to replace. it may work better with new ones, but it depends on your budget.
  • 12-07-2012
    CharlieC
    Thanks Saturnine, appreciate the thoughts.
