Results 1 to 8 of 8
Thread: What size...
    Mt Wilson Motoboy
    Reputation: tedroy's Avatar
    Mar 2005
    What size...
    Qr seatpost clamp for an 04 Burner. I like those Hope qr clamps but I don't know the right size. Anybody got that measurement?
    "My people are the people of the dessert!"
    said T.E. Lawrence picking up his fork...
    Pixie Dust Addict
    It's a 32mm clamp.
    Yup, there is a good chance you have the 32mm seat tube diameter, thus a 31.8 will work but would be WAAAAAY to tight to use the lever comfortably. Ask me how I know because I did it for close to two years.
    Mt Wilson Motoboy
    Mar 2005
    So...
    Ask me how I know because I did it for close to two years.[/QUOTE]
    What did you end up doing? Did you find any qr's at 32mm?
    grumpy northerner
    Salsa make a 32mm QR seatclamp. The nearest Hope is 31.8, which sounds like it'll be too small for you.
    I haven't fallen off, I'm just having a rest.
    Turner Homer
    Reputation: dtrek4500's Avatar
    I think that the size is stamped on the underside of the stock clamp. I am not sure but you should check and see if this is true.
    Dave
    Quote Originally Posted by tedroy
    What did you end up doing? Did you find any qr's at 32mm?[/QUOTE]
    Well, I put the Hope on and backed the adjuster nut back as far as I could while leaving a safe number of threads in, then used all my might to put the lever in place. Got the Flux and it fits perfectly.
    Mt Wilson Motoboy
    Mar 2005
    Yup..
    [QUOTE=dtrek4500]I think that the size is stamped on the underside of the stock clamp. I am not sure but you should check and see if this is true.
    Yup...32mm Like Y'all said. Oh well so much for the Hope. Dang they look kewl..
