Results 1 to 46 of 46
    moe.
    What does your RFX weigh?
    Fo's is just under 35. Mine is an '06 with a DHX Air just under 32 w/slime tubes and nevegal 2.35s. I also have some carbon and am running DT 5.1s w/240s (TA). I did a search but didn't come up with anything. I will post pics of mine later when I am not at work.
    "These people take a dump that’s a bigger difference than the a 5 Spot and a Blur LTc." DT
    Rides Uphill Slow
    Reputation: The Hookler's Avatar
    I have an '06 and it came in at 33.82 lbs on the digi scale. Not bad considering I didn't go all crazy on the parts.
    you guys should mention if it's got a dhx air or coil as a first thing to compare apples to apples.
    Pivoteer
    Reputation: tiSS'er's Avatar
    ~37lbs.
    06 medium RFX
    DHX Coil with 550lb spring
    66SL
    King/Stans FR
    Maxxis DH 2 ply tires [tubeless (1350 grams each )]
    XTR derailluers
    XT shift pods
    XT cassette
    Juicy 7 with 203mm front/185 rear (galfer rotors)
    Race Face Evolve cranks
    Thomson post/stem
    Race Face DH bar
    Selle Italia flite saddle
    FSA Pig DH headset
    Employed by Pivot Cycles - www.pivotcycles.com
    not so super...
    Reputation: SSINGA's Avatar
    34.46lbs
    05 Small 6 Pack w/ DHX-A
    Basic Homer build
    Nothing to see here.
    Living the Dream
    Reputation: Alpenglow's Avatar
    When I lived in Tucson
    Quote Originally Posted by tiSS'er
    ~37lbs.
    I started out running heavy tires Panaracer DH Pro's, but that sh$t got old, fast. My last year I was running 2.35 to 2.5 nevegals or stickee kinetics at around 800-900 grams. I'm sure you have your reasons for your tires, but you could save 2-3 lbs in tires alone. BTW, I'm very interested in those new Stans ZTR FR rims that are comig out.
    "And I shout that your all fakes and you should have seen the look on your face"
    Lay off the Levers
    Reputation: Bikezilla's Avatar
    37.6lbs
    including
    EX823 rims (36h rear)
    Gravity dropper
    Control-Z platform clipless pedals
    2.3 UST tires
    DHX-C & 800# Spring
    but it pedals like it weighs ... oh forgetaboutit!
    Update: I just replaced both tires (one was UST the other std both had tubes) Now w/ 2.3 UST and no tubes 36.77# Weeee I'm a weight weeine now!
    BTW have you checked the RFX/Pack setup database?
    <TABLE style="WIDTH: 441pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=588 border=0 x:str=""><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="HEIGHT: 12.75pt" height=17>* Frame Size & Color:</TD><TD>RFX 06 Large Custom Paint: Sparkle Green on Black PC.</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="HEIGHT: 12.75pt" height=17 x:str="* Rear Shock: ">* Rear Shock: </TD><TD>DHX 5.0 800# spring</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="HEIGHT: 12.75pt" height=17 x:str="* Fork: ">* Fork: </TD><TD>Marzocchi 06 66 SL</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="HEIGHT: 12.75pt" height=17 x:str="* Brakes: ">* Brakes: </TD><TD>Shimano XTR Calipers, XT resivoirs, DangerBoy gold levers, Hope 2-pc 203mm/185mm Brake rotors
    </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="HEIGHT: 12.75pt" height=17 x:str="* Cranks: ">* Cranks: </TD><TD>Shimano XT / E-13 Supercharger bash ring</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="HEIGHT: 12.75pt" height=17 x:str="* Front Derailleur: ">* Front Derailleur: </TD><TD>Shimano XT</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="HEIGHT: 12.75pt" height=17 x:str="* Rear Derailleur: ">* Rear Derailleur: </TD><TD>Sram X0 '05</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="HEIGHT: 12.75pt" height=17 x:str="* Pedals: ">* Pedals: </TD><TD>Time Control-Z</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="HEIGHT: 12.75pt" height=17 x:str="* Stem: ">* Stem: </TD><TD>Thomson X4 120mmx10*</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="HEIGHT: 12.75pt" height=17 x:str="* Handlebar: ">* Handlebar: </TD><TD>Answer ProTaper / 31.8mm</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="HEIGHT: 12.75pt" height=17 x:str="* Seatpost: ">* Seatpost: </TD><TD>Garvity Dropper 1-4 inch / Homer approved</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="HEIGHT: 12.75pt" height=17 x:str="* Saddle: ">* Saddle: </TD><TD>Wtb Laser Ti</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="HEIGHT: 12.75pt" height=17 x:str="* Bottom Bracket: ">* Bottom Bracket: </TD><TD>Shimano X-type XT/XTR (one of each)</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="HEIGHT: 12.75pt" height=17 x:str="* Cassette: ">* Cassette: </TD><TD>Shimano LX</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="HEIGHT: 12.75pt" height=17 x:str="* Chain: ">* Chain: </TD><TD>Shimano XTR</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="HEIGHT: 12.75pt" height=17 x:str="* Headset: ">* Headset: </TD><TD>Chris King gold no thread</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="HEIGHT: 12.75pt" height=17 x:str="* Grips: ">* Grips: </TD><TD>Black Salsa Del Fuego Lock ons with Black Dangerboy Skull end caps</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="HEIGHT: 12.75pt" height=17 x:str="* Front Tire: ">* Front Tire: </TD><TD>Fat Albert 2.35 UST w/o stans</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="HEIGHT: 12.75pt" height=17 x:str="* Front Rim: ">* Front Rim: </TD><TD>Mavic EX-823 32 h</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="HEIGHT: 12.75pt" height=17>* Front Hub:</TD><TD>Chris King 20mm Gold</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="HEIGHT: 12.75pt" height=17 x:str="* Rear Tire: ">* Rear Tire: </TD><TD>Maxxis High Roller 2.35 UST w/o stans</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="HEIGHT: 12.75pt" height=17>* Rear Rim:</TD><TD>Mavic EX-823 36 h</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="HEIGHT: 12.75pt" height=17>* Rear Hub:</TD><TD>Chris King 72pt 36h Gold w/ Gold Hope skewer</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="HEIGHT: 12.75pt" height=17 x:str="* Shifters: ">* Shifters: </TD><TD>Sram X9 Trigger shifters</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="HEIGHT: 12.75pt" height=17>* Seatclamp:</TD><TD>Hope QR Gold</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="HEIGHT: 12.75pt" height=17 x:str="* Chainguide: ">* Chainguide: </TD><TD>E-13 DRS</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="HEIGHT: 12.75pt" height=17>* Cables</TD><TD>Galfer Braided SS hydro lines / Generic SS / Generic 5mm housing
    </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="HEIGHT: 12.75pt" height=17 x:str="* Weight: ">* Weight: </TD><TD>36.77
    </TD></TR></TBODY></TABLE>
    Faster is better, even when it's not.
    Pivoteer
    Quote Originally Posted by Alpenglow
    I've been running the DH tires for about 9 months now. I am used to the weight so it is not a problem. I have run the 800-900 gram tires with no success. I simply cut the sidewalls. The additional time it takes me to climb is balanced by the time it takes me to repair a tire. Before the DH tires, i was nearly flatting every ride. I've had zero issues with flats sonce the change. The weight is worth the reliability and peace of mind I get.
    Did you see my mini review in the other post on Stans' rims? I should note that my brother is running Olympic rims on his Moment with great success. He rides the same SOMO trails I do, but he is more graceful than I am. He weighs about the same I do.
    banned, again
    Reputation: The Chan's Avatar
    Nov 2006
    mine's at 17.8 lbs with the new Helium Tubeless setup.
    Reputation: krispy@go-ride.com's Avatar
    2007 RFX--30.75 lbs for this 125lb squirrell
    DHX-A (for now...)
    Z1 fork
    2.3 light tires setup w/maxxis strip n stans
    GD descender post
    xt cranks,x9 dt
    WTB wheels w/500g rims
    light aluminum parts otherwise
    click signature for pic
    Santa Cruz Bronson 2 27.5/Rockshox Pike/Sram XX1
    Salsa Mukluk/Rockshox Bluto/Sram X1
    Rides Uphill Slow
    Quote Originally Posted by Jerk_Chicken
    dhx coil.
    Neg reppers r my biatches
    Reputation: FoShizzle's Avatar
    Quote Originally Posted by mtntrance
    actually, after reweighing it today at the shop, for the second time in 2 days, 35.7 lbs
    Team Sanchez
    Reputation: El Chingon's Avatar
    2007 XL RFX weighs in at 37 lbs.
    DHXcoil
    66 SL ATA
    Gravity Dropper
    Avid Code disc brakes
    Brass Nipples!
    Reputation: Bob the Wheelbuilder's Avatar
    Sep 2003
    6 Pack, not an RFX, but...
    36.9 pounds in its current form with flat pedals and DH wheels and tires.
    I'm going to switch to my Time's, lighter wheels and tires, DHX-A and Thomson post to see how much weight I can drop for climbing days, I'm guessing it will be around 4 pounds.
    EDIT: the lighter configuration weighs exactly 5 pounds less at 31.9 pounds. Before and after diet pics below.
    {Principal Skinner} Hmm. Whoever did this is in very deep trouble.
    {Martin} And a sloppy speller too. The preferred spelling of 'wiener' is w - i - e - n - e - r, although 'e - i' is an acceptable ethnic variant.
    trail fairy
    BZ good weight dude
    Mine pedals like its 32lbs though and jumps like its 28lbs I like it a little heavier, though Ive put my mallet ms back on so I'll drop a few grams
    I couldn't get used to flats too unsafe for me on the big jumps where I have to pedal hard, just technique but Ive been clipped in too long so went and bought some 661 radars now I hopefuly can go bigger with confidence and get a little stylie
    I could easliy swap to my DT5.1s off my Spot and get to 35lbs I think but I don't know why maybe for a long ride.
    Ta's Light Freeride weapon
    <img src="http://i145.photobucket.com/albums/r211/trailadvent/TaRFX1014x760.jpg"> <o></o>
    <table x:str="" style="border-collapse: collapse; width: 441pt;" border="0" cellpadding="0" cellspacing="0" width="588"><tbody><tr style="height: 12.75pt;" height="17"><td class="xl27" style="height: 12.75pt;" height="17">
    </td> <td>
    </td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl27" style="height: 12.75pt;" height="17">* Frame Size & Color:</td> <td>RFX 06 Med Ano Green (TNT)</td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl27" style="height: 12.75pt;" x:str="* Rear Shock: " height="17">* Rear Shock: </td> <td>Cane Creek CCDB 550lb spring</td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl27" style="height: 12.75pt;" x:str="* Fork: " height="17">* Fork: </td> <td>Marzocchi 06 66 RC2X white</td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl27" style="height: 12.75pt;" x:str="* Brakes: " height="17">* Brakes: </td> <td>Magura Louise FRs 203mm/185mm/Braking rotors</td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl27" style="height: 12.75pt;" x:str="* Cranks: " height="17">* Cranks: </td> <td>Race Face Atlas/ RF bash Guard</td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl27" style="height: 12.75pt;" x:str="* Front Derailleur: " height="17">* Front Derailleur: </td> <td>Sram X Gen</td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl27" style="height: 12.75pt;" x:str="* Rear Derailleur: " height="17">* Rear Derailleur: </td> <td>Sram X9 07</td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl27" style="height: 12.75pt;" x:str="* Pedals: " height="17">* Pedals: </td> <td>Crank Bros Mallet Ms</td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl27" style="height: 12.75pt;" x:str="* Stem: " height="17">* Stem: </td> <td>Diety 50mm White</td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl27" style="height: 12.75pt;" x:str="* Handlebar: " height="17">* Handlebar: </td> <td>Diety White / 31.8mm</td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl27" style="height: 12.75pt;" x:str="* Seatpost: " height="17">* Seatpost: </td> <td>Garvity Dropper 4inch / Homer approved</td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl27" style="height: 12.75pt;" x:str="* Saddle: " height="17">* Saddle: </td> <td>Wtb Pure V camo</td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl27" style="height: 12.75pt;" x:str="* Bottom Bracket: " height="17">* Bottom Bracket: </td> <td>RF Integrated with Diablous BB</td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl27" style="height: 12.75pt;" x:str="* Cassette: " height="17">* Cassette: </td> <td>Sram PC 990</td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl27" style="height: 12.75pt;" x:str="* Chain: " height="17">* Chain: </td> <td>Sram PC 991</td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl27" style="height: 12.75pt;" x:str="* Headset: " height="17">* Headset: </td> <td>Chris King gold no thread</td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl27" style="height: 12.75pt;" x:str="* Grips: " height="17">* Grips: </td> <td>Oury Lock ons with Diety end caps</td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl27" style="height: 12.75pt;" x:str="* Front Tire: " height="17">* Front Tire: </td> <td>WTB Weirwolf 2.5
    </td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl27" style="height: 12.75pt;" x:str="* Front Rim: " height="17">* Front Rim: </td> <td>Sun MTX Snow Camo 34mm 32 h</td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl27" style="height: 12.75pt;" height="17">* Front Hub:</td> <td>Hadley 20mm Gold</td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl27" style="height: 12.75pt;" x:str="* Rear Tire: " height="17">* Rear Tire: </td> <td>Maxis Minion 2.35
    </td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl27" style="height: 12.75pt;" height="17">* Rear Rim:</td> <td>Sun MTX Snow Camo 34mm 32 h</td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl27" style="height: 12.75pt;" height="17">* Rear Hub:</td> <td>Hadley 36pt 10mm bolt through gold</td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl27" style="height: 12.75pt;" x:str="* Shifters: " height="17">* Shifters: </td> <td>Sram X0 Impulse shifters</td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl27" style="height: 12.75pt;" height="17">* Seatclamp:</td> <td>Turner</td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl27" style="height: 12.75pt;" x:str="* Chainguide: " height="17">* Chainguide: </td> <td>Blackspire Stinger</td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl27" style="height: 12.75pt;" height="17">* Cables</td> <td>Nokon
    </td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl27" style="height: 12.75pt;" x:str="* Weight: " height="17">* Weight: </td> <td>37.67
    </td> <td>
    </td> <td>
    </td></tr></tbody></table>
    MAXXIS 4C!
    Helmet for your neck
    Leatt FAQs
    trail fairy
    Bob nice rig dude, I didn't know you'd come over to the 6Pack/RFX army welcome buddy good to have ya fully on board, Burner Sultan and 6pack awesome, even some Sram on there Im impressed
    cheers ta
    FO
    FO after a chain guide and GD you'll make it to atleast 36.5 getting into real RFX territory awesome FO good work now get some ride picss up there of you going big.
    MAXXIS 4C!
    Leatt FAQs
    Quote Originally Posted by trailadvent
    cheers ta
    had a break in ride today....another mellow ride tomorrow unfortunately as I made plans some time ago for the ride. In any event, I will have about 50 miles over this weekend on the bike.
    roots, rocks, rhythm
    Reputation: Dawgprimo's Avatar
    I am posting just to make you guys all feel good about yourself.
    Warning-components selected very durable w/o considering of weight
    -44lbs
    -XL '00 RFX
    -Vanilla RC(pushed)
    -but it pedels like it weights 44 lbs lite.......
    wouldn't change a thing on it other than a new fork.
    K
    trail fairy
    so give us the break down how did it feel, did you like the ride, has it exceeeded your expectations come on fo ta wants a review dude you likey the fork brakes shock wheels bar stem combo
    Demanding ta huh
    MAXXIS 4C!
    Leatt FAQs
    aka DJ Papi
    Reputation: emrs0414's Avatar
    Apr 2005
    Smile Demo 07 RFX...
    Just sharing a pic of my Demo 07 RFX: 31 lbs flat. (some parts interchanged from my 05 Six Pack)
    * Frame Size & Color: Demo 07 RFX Med Black (TNT)
    * Rear Shock: 07 Fox DHX-Air
    * Fork: Marzocchi 06 66 SL
    * Brakes: Magura Louise FRs with Galfer Rotors 185mm- front 160mm rear
    * Cranks: 05 Shimano XTR
    * Front Derailleur: Sram X Gen 07
    * Rear Derailleur: Sram X9 07
    * Pedals: Crank Bros Mallet Ms
    * Stem: Thompson 70 mm
    * Handlebar: Easton Monkey Lite DH
    * Seatpost: Garvity Dropper 3 inch - Homer approved
    * Saddle: Turner Chro-Mo FR
    * Bottom Bracket: with Shimano
    * Cassette: Shimano XTR 11-34
    * Chain: Shimano Dura Ace
    * Headset: Chris King Black No Threadset
    * Grips: Specialized w/ Dangerboy end caps
    * Front/Rear Tire: Specialized Adrenaline Pro 2.1
    * Front/Rear Rims: DT Swiss Ex 5.1D
    * Front/Rear Hubs: Chris King with F- 20mm thru
    * Shifters: Sram 07 X9 Trigger shifters
    * Weight: 31 lbs.
    Large 06 with coil front and rear and good components.......35.9#....
    My new build begins..................RFX!!!
    Natl. Champ DH Poser/Hack
    Reputation: cactuscorn's Avatar
    well this got me interested in tryin to figure out what my med '07 might weigh so i added up everything in the build box, includin the super long steerer, stock heavyish demo wheels and tires and came up with 23.76 lbs. add to that a frame weight of about 7.2lbs, my e13 bash guard and cheesey chain guide and im just about 31.5 - 31.75 id say. toss my lighter 2.35 minion dhf's, a push ti bolt kit for the rockers and the possibility of some i9 endros and ill guess ill drop close to another pound or so. much better than i had hoped for. eat yer heart out bo kizzel!
    ’07 Turner RFX 6.5” travel
    ’07 Fox DHXA rear shock
    Chris King Aheadset
    ’07 Fox Float 36 fork 6.5” travel
    Wheels Manufacturing headset spacers
    Thomson Elite stem 100mm x 5 deg
    Easton Monkey Lite DH h/bar 26” x 1 ½” rise
    ODI Ruffian Lock Jaw grips
    ODI h/bar plugs
    Salsa Flip Off s/post qr
    Maxm MX5 seatpost
    WTB Shadow ti saddle
    Sram X-9 shifters 9 spd
    Sram X-9 rear derailleur long cage
    Sram X-9 front derailleur
    Shimano derailleur cables
    Bontrager 4mm derailleur housing
    Wheels Manufacturing alloy 4mm ferrules
    XT 970 175mm cranks
    E Thirteen Supercharger bash guard
    Heim 3 chain tensioner
    MRP LRP roller kit
    Crank Brothers Mallet M pedals
    SRAM PG-980 cassette 11/34
    SRAM PC-990 chain
    Lizard Skins chainstay guard
    Magura BAT brake levers
    Magura Louise rear brake
    Magura 160mm rotor
    Magura Louise front brake
    Magura 180mm rotor
    Goodridge hydraulic brake lines
    WTB Speed Disc Trail wheelset
    Maxxis Minion DHF MaxxPro 26 x 2.35 kevlar tires
    Bontrager p/v tubes
    Actual weight: 31.5 lbs aprox
    keep in mind im a 165lb 1st class huck wimp and this is most likely my only rideable fs bike for some time so it must behave like a trail bike, not nessesarilly a fr rig. that is till i can get another flux then look for it to develop a beer belly.
    No, I'm NOT back!
    rr
    rr is offline
    I don't do PC
    Reputation: rr's Avatar
    Some damn nice rigs here! The RFX is a very fun bike, mine weighs 37.3 with a set of Sun Ringle cheapo tank wheels, psyched about building a pair of wheels soon and losing a little weight.
    Displaying UGI Symptoms
    Reputation: murphie's Avatar
    Feb 2005
    What no GD?
    Quote Originally Posted by cactuscorn
    Chris King Aheadset
    ODI h/bar plugs
    Maxm MX5 seatpost
    XT 970 175mm cranks
    MRP LRP roller kit
    SRAM PC-990 chain
    Magura 160mm rotor
    Magura 180mm rotor
    Bontrager p/v tubes
    Hey CactusC:
    What? No gravity dropper? You may bust 32 pounds when that is put on
    24 hours in a day, 24 beers in a case. Coincidence?
    - Stephen Wright
    a gd is in the plan. for now all im worried about is buildin it for local rides where its not needed. big tires, the super comfy turner branded velo saddle and big ass 31.8 fsa alloy bar/stem combo will join it makin it a 33 - 34lb pig.
    No, I'm NOT back!
    Reputation: CrashTheDOG's Avatar
    37 lbs. on the nose.
    DHX-C
    '07 66 SL
    King w/DT 6.1's
    4" GD
    Juicy Sevens
    trail fairy
    CC you'll like the new X9 I just swapped out my XO on the RFX (back on da Spot) for an 07 X9 felt no difference in performance but feel heaps better if I smash it up
    I think it looks better 2, I couldnt' imagine riding the RFX without a coil shock, Im loving this so much its hard for to go back to the DHXa on the Spot coil really does feel great.
    Anyways nice build cc look fwd to seeing it when done, I think FO and I have created a trend new for new Turners not built atleast for a few months good to see youre on track
    <o>></o>>
    MAXXIS 4C!
    Leatt FAQs
    ....just weighed in at a hair under 34lbs
    thanx ta. i rode the new x9 in moab and it was a instant love affair. cant say the same for my dhxc. much prefered the old ava to be honest. not as plush but heaps more consistant through the ride. the ccdb may be a totally diff story.
    No, I'm NOT back!
    frame - RFX ano black, large, w/ DHX 5.0 Coil<O</O
    fork - 2007 Marz 66 SL ATA
    headset - King
    stem - Deity
    handlebar - Deity
    shifters - Sram X7 twisters
    Brakes - 2006 Hope M6 front w/ 8” rotor, M4 rear with 180mm 8”. Steel braided lines
    seatpost - Thomson
    saddle - WTB Pure V SLT
    crankset - Shimano Hone 2-ring with bash
    Pedals - Shimano 646
    Chain - Sram PC951
    Cassette - Sram PG950 11-34
    f.derailleur - Shimano Deore
    r.derailleur - Sram X7
    wheelset - DT 5.1 rims / I9 6-pawl rear hub with 10mm thru axle running Hadley
    10mm x 135mm thru axle / Front 20mm hub
    tires – Maxxis Advantage
    seatpost clamp – Hope <O</O
    <O</O
    TOTAL WEIGHT = 35.7 Lbs
    Blackspire Stinger to be added
    Bodhisattva
    Reputation: The Squeaky Wheel's Avatar
    Quote Originally Posted by FoShizzle
    headset - King
    stem - Deity
    handlebar - Deity
    seatpost - Thomson
    Chain - Sram PC951
    <O</O
    And....
    Gravity Dropper to be added
    that is slander! i challenge you to prove i said such a stupid thing!
    but 1st he has to teach it how to curtsy.
    No, I'm NOT back!
    Bodhisattva
    Medium 6-Pack
    PUSH'd DHX with 550 lb Ti Spring
    X.0 Triggers & RD
    XTR Casette & FR
    Juicy 7 with 8" front/6" rear, steel Goodridge lines & DB levers
    Lyrik 2-Step
    King hubs/DT 5.1 rims/DB spokes
    2.4 Schwalbe Big Bettys F & R
    Cane Creek lock-ons
    ATAC Carbon XS pedals
    XT Cranks with 34/22 Ti rings & Gamut polycarb bash
    SRAM PC-whatever chain
    WTB Laser Ti saddle
    Thompson stem
    Gravity DH carbon bar
    And...a Gravity Dropper
    Oh Yeah !!!!!!!!!!!!!!
    Weight 33.8 pounds
    on a routine expedition
    Reputation: Marshall Willanholly's Avatar
    33.75lbs (5 spot seat stay, Push rockers)
    Outcast
    Reputation: Renegade's Avatar
    My RFX is heavy.
    Why?
    2002 frame; the beefiest of the RFX's.
    8.5 by 2.5 shock: bigger shock+ bigger spring = heavy.
    Old square taper bottom bracket [till I make a new bashring for my hollowtech 2 crankset].
    REAL tires, two ply side walls, not like those weight-weenie tires found on xc bikes.
    Flat pedals; not those weight-weenie egg-beater things found on xc bikes.
    It's at least 38 pounds. mabey more.
    I win; mine is the heaviest!
    P.S. I forgot the brakes. Eight inch rotors, front and rear, not like those blah blah blah.......
    in with the new, out with the old
    looser! my '02 weighs in at a cruise ship like 38.5lbs and thats before i added a chain guide worth another 1/2lb.
    '02 rfxc "this is the burleyest frame in the world. do ya feel lucky? well, do ya.... punk?"
    dhxc
    66 rc
    bmf wheelset - 521's/hope big un ft/xt r hubs
    2.5 nevy/groove stickys
    mallet m's
    hayes mag's
    8" rotors - the hope rotor can be used as a concrete cutter.
    fsa pig pro h/set
    e13 bash ring
    oooooooooold azonic dh h/bar - dbls as a howitzer barrel.
    990 cassette
    did i mention its still for sale?
    No, I'm NOT back!
    Outcast
    That's it, the gauntlet has been thrown down! I'm gonna bring my bike into town so I can weigh it properly. We'll see who has the heaviest burly man RFX!
    Lay off the Levers
    Quote Originally Posted by Renegade
    Better make that weigh-off an open invitation:
    Quote Originally Posted by Dawgprimo
    -44lbs
    -XL '00 RFX
    -Vanilla RC(pushed)
    Outcast
    Quote Originally Posted by Bikezilla
    Uh, maybe not:
    okay, I'll settle for fighting for second place.
    (Quote)
    P.S. I forgot the brakes. Eight inch rotors, front and rear, not like those blah blah blah.......[/QUOTE]
    Congrats on your 6" travel DH bike!!! Bwahhhahhhahhaa
    good thing you are used to sloppy seconds then.....
    Team Blindspot
    Reputation: S-Works's Avatar
    Quote Originally Posted by SkullCrack
    So, how much travel are you getting out of this set up?
    Astigmatic Visionary
    Outcast
    Quote Originally Posted by krispy@go-ride.com
    (Quote)
    Correction Kris, you mean my 7 inch travel dh bike:
    BTW Kris; congrats on your sub 32 pound 6 inch XC bike!
    Outcast
    I told you to stop hooking up with my wife Dammit!
    Whoa!? BADASS!!!!!!
    way more cool than my 31lb xc bike
