Results 1 to 3 of 3
    WB FLUID 110 oil levels?
    Only info I could find was on the 15 cc in the left leg... If anyone could help on the correct level amt in the damper side and weight that would be swell
    www.whitebrotherscycling.com manuals under the tech section, or call them...
    Reputation: bikesinmud's Avatar
    Dec 2005
    6 OZ. in the right leg as per WB tech, I use 5wt. and have had nothing but a perfect performing front end.
